Old 10-03-2007, 01:23 PM   #22006
Customworksking's Avatar
Trader Rating: 71 (100%+)
Post iic rubber tire 19t and stock setup
front...
1way
.5 toe in
screw block spacers 1mm frt and rear
wishbone klips 2mm frt 2mm rear
link washers 3mm..ie 1 2mm and 1 1mm
ride heigth 5.5mm
droop 2mm uptravle over ride heigth..or 5 on hudy guage
roll-bar 1.40...gold in coloer
caster block 4deg
camber 1.5 to 2 keep checking all 4 tires because they change
link washer 1mm
horizonal pin
Pivot blocks spacers 1.5mm
shocks..3hole I ran 30wt 40wt and 50wt and found 40 the best
spring...AE blue
2nd hole in on shock tower outside hole on a arm
from frt to back 3rd hole on center track rod plate
med/short plate
rear settings:
drive heigth low frt and rear ie:diff/1way set to low
toe: i ran 2 and 2.5 try both
screw block spacers front 2.5 rear 1mm
quik klips 2mmfrt 2mm rear
link washer horizontal 2.5mm
ride height 5.5mm
droop 3mm uptravle or 4 on hudy
roll bar 1.40 gold
camber 1.5 deg
link washer 3mm
inboard pin horizonal
pivot blocks spacers 1.5 on all 4
shocks 40wt 3hole
Silver AE spring
3rd hole in on shock tower
2nd hole in from outside on a arm
short camber link
motor orion19t and co27 116 spur 29 final drive 7.20
dope full rears 1/2 frt 70 to 80% dual rate
let me know if I missed anything ..this is a good setup for med to high bite
I tried both stiff and kit top deck ...I felt very happy with this set-up
Mazda speed 6 body......
Customworksking is offline   Reply With Quote
Old 10-03-2007, 01:38 PM   #22007
POUNDITRACING's Avatar
thanks for the help in advance
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 10-03-2007, 01:38 PM   #22008
turbodog's Avatar
Originally Posted by yokemad View Post
To All team drivers :could you please give us some tips how to keep our cars free and smooth like your cars...
threatments to the driveshafts,ballracers,belts etc...
cheers
While the stock bearings are good, the ceramic bearing set (U3171) is the best I've used!!
turbodog is offline   Reply With Quote
Old 10-03-2007, 01:38 PM   #22009
Originally Posted by Darkseid View Post
I just use regular corally style plugs to plug into the pack. I made sure that my solder joint (wire-to-plug) was as flat as possible so that it would fit under the bulkhead. To do this, I just soldered the wire to the corally style plug at a 90* angle as usual, then ground the solder joint a little flat with a rotary tool.
If you really need more space, you can take a little material off the 3200 case to allow the wire to fit under the bulkhead better, but it really isn't neccesary.
I even added a little tab onto the wire so that I can charge the pack without taking it out the car.
I'll throw a pic of the car up. If you want a better pic, I can take one.
can oy ugive me a pic from the other side and from the to zoomed in?
Old 10-03-2007, 02:34 PM   #22010
MagicMarker's Avatar
Pound: here's a link of some pics I took of my car and the lipo they are pretty close up. Look about half way down the page.
Bodies Painted By Ken McKinney
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 10-03-2007, 04:33 PM   #22011
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Numan said "Nice Tamiya towel" lol
Old 10-03-2007, 04:33 PM   #22012
I am now forced to use Lipo. What is everyone using.
Numan and Caster both say
"why??!!"
lol
Old 10-03-2007, 04:35 PM   #22013
Did you have to cut anything? Different stearing rack?
Old 10-03-2007, 04:36 PM   #22014
dawgmeat's Avatar
Mcgoo or seaball in both your set-ups u used team tamale castor block, are these prototypes or caan they be ordered?
dawgmeat is offline   Reply With Quote
Old 10-03-2007, 05:21 PM   #22015
Regional Moderator
Darkseid's Avatar
Yeah, I can get you some better pics. I'll get them up soon.
TLR 22...Tamiya F104...
Old 10-03-2007, 05:24 PM   #22016
Regional Moderator
Darkseid's Avatar
Hey, that was from my TA05 days. A car that served me quite well for 2 seasons.
And besides, I still race Tamiya mini, so I do still have a reason to have a Tamiya towel.
Does Schumacher even make a pit towel?
Old 10-03-2007, 05:35 PM   #22017
I got a Schumacher pit towel about two years ago. I would they still have them.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 10-03-2007, 05:36 PM   #22018
abailey21's Avatar
Trader Rating: 36 (100%+)
yeah we have them
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-03-2007, 05:39 PM   #22019
Regional Moderator
Darkseid's Avatar
Originally Posted by abailey21 View Post
yeah we have them
I'll have to take a look. Got a part#?
Thanks in advance.
Old 10-03-2007, 05:42 PM   #22020
Regional Moderator
Darkseid's Avatar
Here you go Poundit:
These are close ups of the plug under the bulkhead. As you can see, if you keep the solder joint low, or grind it down after you solder it, then it doesn't come close to the bulkhead, thus no shorting concerns.
The only issue is if you use thick 12 guage wire(as I did). It fits snug under the bulk head. But its really not an issue. you can take a little insulation off the wire with an xacto blade, or take a little material off the battery case to let the wire sit lower, or just use 14 guage wire. Any of those work, and let the pack fit easily.
Another thing I have pictured, is the little tab(aka a cut off end of a cheap battery bar ) I use for charging while the pack is still in the car. All I do is unplug the negative wire, then clip the charger alligator clips to the tab and the negative port in the battery. Easy, and no battery removal except for when the car needs heavy repairs and the battery needs to be charged at the same time.
Hope these help...
Schumacher Corner-3200-closeup.jpg   Schumacher Corner-3200-closeup_3.jpg   Schumacher Corner-3200-closeup_4.jpg   Schumacher Corner-3200-closeup_2.jpg
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
