Old 10-02-2007, 10:22 AM   #21961
PW
PW's Avatar
Send a message via AIM to PW
McGoo...SO you going to build my Birds car for me
j/k...AWESOME run sucka!
PW is offline   Reply With Quote
Old 10-02-2007, 10:23 AM   #21962
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Mr. McGoo View Post
Thanks for the props Kling - yeah the car was SO dialed....i was calling Jimmy Maddison collect over in the UK!!!!
This was the easiest and best car i have ever driven in my life. I felt 100% confident that I could place this car anywhere I wanted to. I feel like the Mi3 turned a few heads as well b/c of how good Goetz and my car was looking....
My third qualifier I was down to 11.1's, 11.2's and a string of 11.3's. It is so bitter sweet - I was only 5 seconds out of the A, 1.5 seconds out of the B and that put me 23rd qualifier....you gotta love national level stock racing!!!!
Dawgmeat - i would have agreed with that statement 2 weeks ago, but I only made 3 changes from my home track which is low-med bite. I went one softer spring rate in the back, took the arm sweep out in front, and took .5 toe out of the rear. Other than that - I was running exactly what I was running back home.
I feel confident that this setup is pretty going to be a great base point for anyone running foams. I gotta give props to where props are due - my buddies Steve 'Magic' Marker & Andrew Doherty, as well as Goetz helping me iron this setup out.....
As for the PDF - it isn't allowing me to change my rear ride height and droop - they copy and paste each other.....so i am running 4.0mm ride height with 6.5mm uptravel
Love ya Man. Thanks for the props - it's all about the team. You know I'm proud to stand beside you each weekend and look forward to another weekend of racing with some of the best!!!
L8R AWD
Old 10-02-2007, 10:29 AM   #21963
theisgroup's Avatar
I think I am ok with that....Stanton looked great this weekend.....
correction. stanton's car looked great, not sure we can say that about stanton himself. lol
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-02-2007, 10:42 AM   #21964
Regional Moderator
Darkseid's Avatar
Hey guys, I have a question about the set up sheets. Both the standard carpet set up sheet and McGoo's sheet, showed shims under the ballstud on the rear hub.(3mm standard, 4mm on McGoo's set up)
My question is how the heck you pull that off!
I can't see how you can get that many shims under the ballstud without the ball cup hitting the tire rim. Maybe 1mm...maybe. But 3-4mm???
I know I must be missing something here, so what is it...
TLR 22...Tamiya F104...
Old 10-02-2007, 10:59 AM   #21965
Mr. McGoo's Avatar
use the long ball studs...it doesn't look like it will work but it does. Every now and then make sure that they haven't come loose.
I almost forgot....I had .75 shimms on the front hex and 2mm shims on the rear hex's.....it helped calm the car down quite a bit....
i will get a correct and complete setup sheet later on today.....
mm
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 10-02-2007, 11:01 AM   #21966
Mr. McGoo's Avatar
send it my way sucka!!!!! thanks for the props!!!!
Old 10-02-2007, 11:05 AM   #21967
Send a message via AIM to adamliehr
Hey Randy,
Shoot me an e-mail when you get a sec. I have a few questions for you.
aliehr@cantonbaptist.org
thanks in advance
adamliehr is offline   Reply With Quote
Old 10-02-2007, 11:05 AM   #21968
theisgroup's Avatar
I beleive both setups are with the aluminum rear hubs. they are shorter. Basically you want to shim up to the rim of the tire. I beleive there is about a 1mm clearance. we were also using the new big wheel parma tires
yang lai
Old 10-02-2007, 11:06 AM   #21969
Regional Moderator
Darkseid's Avatar
Ahhhhhhhhhh......okay.
Old 10-02-2007, 11:19 AM   #21970
MagicMarker's Avatar
L8R Marker
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 10-02-2007, 11:30 AM   #21971
Skiddins's Avatar
The alloy rear hubs, the ones with 1 deg rear toe, require 1.5mm under the ball stud to make them the same as the standard hubs.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-02-2007, 11:32 AM   #21972
theisgroup's Avatar
Skiddins
yeah, sorry, I was more thinking after all the shimming, that we had about 1mm between the top of the grippa and the wheel
yang lai
Old 10-02-2007, 11:39 AM   #21973
Skiddins's Avatar
A handling question.
The following photo is of my car starting to go into the sweeper at West London, so flat out in 27t at that point (The Mi3 of course ).
When my car is on the table the bodyshell is almost dead level along it's bottom edge, yet in the photo the back end is virtually scraping the ground.
Although I did quite well at that meet and the car felt OK, does this indicate that there is something I should be looking at with regard to the handling, is the back biting/diving too much into the corner?
Here is the setup I used;
BTCC Mi3
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-02-2007, 11:47 AM   #21974
Charles Godwin's Avatar
Looks normal to me.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 10-02-2007, 11:52 AM   #21975
POUNDITRACING's Avatar
to my untrained eye it just looks like weight transfer.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
