Old 09-24-2007, 05:20 PM   #21811
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks for ALL the responses dealing with bodies guys. I'm pretty much sold on the Mazda Speed6 for asphalt, now I just play with wing positions/height. As for carpet, I'm loving the Mohawk. I have a DNA1 all gussied up but don't know which car to mount it on (my asphalt/rubber car, 27t-19t or my carpet/foam, 27t one) The G6 sounds like it might be something to play with though.... I'm in the same boat as Darkseid though, since my driving has improved ALOT I have quite a few painted (expensive) bodies laying around.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-24-2007, 06:15 PM   #21812
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Mitch P. View Post
Ray your car looked alot better. Patrick got his body crunched and I guess he fell back to ninth. I cant wait to get an onroad.
Good to hear you guys are getting full heats from what it would sound like.. Is anyone running mod or just 19 turn?
Old 09-24-2007, 06:24 PM   #21813
there were like 15 or so running 19t. the track is too small to run mod, plus there was only 4 people running that class. that was my first time out there but it seemed like 19t is the class right now.
Mitch
Mitch P. is offline   Reply With Quote
Old 09-24-2007, 07:31 PM   #21814
Old 09-24-2007, 08:05 PM   #21815
IslandBwoy's Avatar
I'm about to drop a brushless 19t in for the first and am wondering how different the gearing is from the brushed motors are. Where are you guys starting for about a 100 ft. track?
IslandBwoy is offline   Reply With Quote
Old 09-24-2007, 09:29 PM   #21816
POUNDITRACING's Avatar
I'm at 5.5.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 09-24-2007, 10:25 PM   #21817
Finally got the pics taken of the cars for the IIC. Here they are!
Edit: Hmm, might be too big, I'll work on getting them up when I get back from the race.
Old 09-24-2007, 10:58 PM   #21818
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Hey guys. Just got home about an hour ago. I was going to try and head up to Vegas Saturday and Sunday, but I found out I have to work Saturday. Oh well, after this last week, the credit card needs time to cool off anyways. Good luck to all the guys heading out for Vegas.
Jon Kerr is offline   Reply With Quote
Old 09-25-2007, 05:24 AM   #21819
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
Novak 10.5 5-5.5fdr, orion 10.5 with a little timing 5.2 FDR
Old 09-25-2007, 05:40 AM   #21820
Regional Moderator
Darkseid's Avatar
Novak 10.5- 5.45 to 5.50fdr
TLR 22...Tamiya F104...
Old 09-25-2007, 05:41 AM   #21821
Skiddins's Avatar
Originally Posted by Charles Godwin View Post
Very different set-up compared to mine at the KOGP but my car was also a bit loose but the smoother you driven it the faster it got (made the 19t A final). If it wants to spin on entry i'd try 1mm on the front Links (Vertical) or put less front droop on the front (6mm - turn droop screws in). If it feels edgy on exit i'd either change the castor to 2*, or change the rear droop (4mm - turn droop screws out), try 4mm on the Horizontal Link Washers or lenghten the rear wheelbase by 0.5-1mm.
Chaz
Out of interest, what was your setup for the KO?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-25-2007, 07:31 AM   #21822
boon's Avatar
hey guys, just build my diff up with the new diff rings and there seems to be a good 0.5-1mm slack between the outdrive and the diff ring! is this normal? is it a more snug fit when you use the non-notched outdrives?
also, after the diff was build there seemed to be a high spot somewhere, rebuilt the diff again and its still there any ideas what might be causing it?
All the best in vegas! whoever is fortunate enough to make the trip
any help appreciated
boon is offline   Reply With Quote
Old 09-25-2007, 07:34 AM   #21823
Regional Moderator
Darkseid's Avatar
Foam tire question...
Last year, I ran Parma Cyan/Magenta and it worked well. But I'm looking to run the Jaco Prism's this season and while they have Magenta, I'm not sure what they're equivalent to the Cyan tire would be. Anybody know?
Also, what are you guys running for regualar grip carpet.(regular-as in not nationals level traction). The standard carpet set up from the manual list Magenta, which I assume means magenta all around.
Old 09-25-2007, 08:17 AM   #21824
IslandBwoy's Avatar
Thanks guys.
Old 09-25-2007, 09:51 AM   #21825
Sucks that you cant make it.. next year I guess!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
