Old 09-21-2007, 12:16 AM   #21751
The Shrew's Avatar
Has anyone used the overdrive pully or the different wishbones ? What difference will they make make ?
The Shrew is offline   Reply With Quote
Old 09-21-2007, 11:17 AM   #21752
i havent used the overdrive pully yet, but i have used the flex wishbones only at the rear and they give alot more rear end grip but i would only use them outdoor.
jordan.norwood@ is offline   Reply With Quote
Old 09-21-2007, 01:06 PM   #21753
Trader Rating: 37 (100%+)
On gearchart.com they don't list the Mi3...
Can I just use the Mi2 20T pulley selection and get the same gear ratios at the Mi3?
Nexus is offline   Reply With Quote
Old 09-21-2007, 01:12 PM   #21754
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
but running the new smaller pulley may force you to interpolate.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-21-2007, 01:25 PM   #21755
abailey21's Avatar
Trader Rating: 36 (100%+)
I use the original mission with 1:8:1 option
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-21-2007, 02:09 PM   #21756
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I feel that overdriving the front end really helps with getting the car to steer in high speed corners off power. I dont notice as much of a difference on small tracks.
Old 09-21-2007, 03:25 PM   #21757
i thought on smaller tracks it heated tires more,
just my feel
jimmy
jimmy..maddison is offline   Reply With Quote
Old 09-21-2007, 04:31 PM   #21758
PW
PW's Avatar
Send a message via AIM to PW
I tested the overdrive pulley last weekend on a big nitro track. The track was super hot and over heating tires was a major issue. The overdrive pulley made the tires over heat much faster and it was harder to drive once they did over heat. It also made the car steer multiple times in high speed corners. I personally didn't like it in the heat and on a big track.
PW is offline   Reply With Quote
Old 09-21-2007, 09:52 PM   #21759
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by JayBee View Post
Sorry about the muddy details LOL....
The track is small/tight w/ some tight chicanes and a 40-50ft straight. The carpet is really starting to catch a groove so bite is pretty darn good. My Parma Pro 53's are 57.5mm; using Magenta/Magenta but last raceday I really dug the Indigo/Magenta set-up. Motor is CO27 w/F's and purple/red springs....
Any rollout suggestions folks? Darkseid, McGoo, PW, Randy, anyone? LOL
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-21-2007, 10:26 PM   #21760
Mr. McGoo's Avatar
I have been running on the vegas layout and have been floating around a 26-27mm rollout with a C027 (118/30-31)and around a 25mm(118/29) rollout with a good monster.
You might want to decrease a tooth or two due to having such a small back straight....i think that should be a good starting point....
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 09-21-2007, 10:34 PM   #21761
JayBee's Avatar
Thanks Goo
Old 09-21-2007, 11:05 PM   #21762
I've noticed that the easiest way to fix the double steering is to go up in shock oil weight. Ive been running 2 x 1.2 pistons with 50wt in front and 40wt in rear.
Old 09-22-2007, 10:32 AM   #21763
Send a message via AIM to adamliehr
So who all on the Schuie team is going to the iic?
adamliehr is offline   Reply With Quote
Old 09-22-2007, 10:45 AM   #21764
me
ARC/HobbyWing/ Protoform/ Team Integy/ R1 Wurks/ACTIVRC
HEWITT is offline   Reply With Quote
Old 09-22-2007, 12:42 PM   #21765
I'll be there. Got a busy 3 class schedule now too
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
