Old 09-17-2007, 05:11 PM   #21676
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by JayBee View Post
Hey guys how important is the lil 'bridge' that's on the outside of the front arms? I really hate to think that the 3 arms that I have are totally useless because the bridge is broken
The arms will have a lot more flex without the bridge there. If it's cracked just drop some glue on it, better than nothing.
Old 09-17-2007, 08:57 PM   #21677
Mr. McGoo's Avatar
I agree with Randy - the arms will flex much more, but as Randy stated - a little drop of glue will help get you by.
I have noticed that these really aren't "break away" arms - they are more "run-flat" arms like the real sports cars of today. I have only broken a few arms, and of those times, the arms usually just cracked and didn't fully break away.
This is great in the fact that it lets us finish the race, but on the other hand if you aren't looking for those cracks, you might misinterpret it as a tweak or ill handling car....
So with that said....crack kills
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 09-17-2007, 08:59 PM   #21678
Mr. McGoo's Avatar
I am posting up my setup that I currently have with my stock/19T Mi3. For 19T i go one spring step softer in the rear.....
This has been one of the best handling cars I have ever owned. I am really diggin' this car and I am pretty darn excited about Vegas!!!
edit...just realized I didn't put what tire compound I was running....Magenta all around....
Old 09-17-2007, 09:12 PM   #21679
JayBee's Avatar
Trader Rating: 31 (100%+)
McGoo what rear lower shock position are you running? It's missing from your set-up sheet
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-17-2007, 09:14 PM   #21680
skypilot's Avatar
Trader Rating: 14 (100%+)
check your pm's
skypilot is offline   Reply With Quote
Old 09-17-2007, 09:14 PM   #21681
Mr. McGoo's Avatar
oops...i am all the way down on the furthest hole - closest to the diff....
Old 09-17-2007, 11:26 PM   #21682
justin lessard's Avatar
Send a message via AIM to justin lessard
what?!..lol..closest to the diff..thats unique.
justin lessard is offline   Reply With Quote
Old 09-18-2007, 04:35 AM   #21683
Static_racing's Avatar
I've cracked only one arm and didnt even notice it on asphalt. Tim Getchel ran his car like that for about a month and still was TQ at our track.
CA will get you by heat by heat, but as soon as you touch somthing it will crack again. The std arms will take a beating, thats for sure
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 09-18-2007, 04:51 AM   #21684
theisgroup's Avatar
it is a fast setup. McGoo is running the same laptimes as a 13.5 but I know he does not run 7mm ride height in the rear. I am sure that it is 4mm and 7mm lift
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 09-18-2007, 07:09 AM   #21685
Mr. McGoo's Avatar
Old 09-18-2007, 09:10 AM   #21686
Charles Godwin's Avatar
LW bulkheads and parts are in at Schumacher UK (according to the Sept Newsletter).....just ordered mine
Chaz
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 09-18-2007, 09:51 AM   #21687
yokemad's Avatar
still august news letter on the website...
yokemad is offline   Reply With Quote
Old 09-18-2007, 10:00 AM   #21688
Tim Kowal's Avatar
R/C Tech Charter Subscriber
New parts are on UK Website
Tim Kowal is offline   Reply With Quote
Old 09-18-2007, 10:15 AM   #21689
Regional Moderator
Darkseid's Avatar
Most of the set up sheets that I'm seeing for carpet (including Mr. McGoo's) are showing guys running a servo saver. I ran all outdoor season without one, but am thinking about adding it for the carpet season.
Now I haven't been keeping up on what the general consensus was about what was the best method(last I saw was the Kimbrough medium), but I thought that most of the methods guys were using caused clearance problems with the wider "stiff" upper deck.
So how are guys getting around clearance problems?
Comments along with pics are definitely welcome.
Thanks in advance.
TLR 22...Tamiya F104...
Old 09-18-2007, 10:30 AM   #21690
seaball's Avatar
Send a message via Yahoo to seaball
Default steering arrangement
i have implemented a sweet system using the following components:
carpet chassis/upper
kimbrough heavy duty saver
standard servo mounts
the extra material on saver ear needs ground , but when centered in the cutout (widthwise) it will clear the bulkhead and top deck. sorry, no camera at the moment.
now the best part (imo) is what i figured out with the adapter. i flipped it upside down, and attached the servo plate from the bottom (with short button head screws), and the trackrod attaches from the top with it's own set of screws. so the plates are separated by the adapter. this puts the servo plate low enough to get keep it near perpendicular to the horn at the end points, but leaves the trackrod where it was, so that bump steer isn't affected.
i rule. (i was having doubts about this recently)
i like the medium length track rod when used with the kimbrough heavy duty saver. saver ball mounted in long centered hole on the kimbrough.
maybe i'll bust out mspaint and really show my skills...
- harold petrie -
also, i noticed the plates fit loosely over the adapter. that can lead to movement upon contact. to fix this, i ran a few coats of c/a on the i.d. of the plates. just something i thought i'd mention. now they press on, which will help keep things from shifting.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
