Old 09-17-2007, 12:59 AM   #21661
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Ran my car again today on the rug with rubber tires, getting better. The one thing I cant stand though is how the rear end just kinda trails around the track like its weightless, hoping that the extra traction at the IIC will help to solve the problem.
Old 09-17-2007, 01:29 AM   #21662
hey randy
i also did some extra testing on sat night ready for vegas, i dont understand your rear wag??
pm me your set up
i made a few small changes to mine and it was super dialled with excellent corner speed
thanks jimmy
jimmy..maddison is offline   Reply With Quote
Old 09-17-2007, 04:04 AM   #21663
Originally Posted by PW View Post
Build them, discharge them and then charge them fully at 4amps. Repeak (3 or 4amps) once a week you don't run them.
Ran my "big track" setup this weekend and the car was dialed! Made a few changes for the extreme tempature:
-2-hole pistons (drilled 1.2mm)
-40wt oil with Hybrid o-rings (35wt if you have stock o-rings)
-New med/flex rear arms
PW..med flex arms on rear only...why not front?have you tried flexy top deck?
I run on med grip Tarmac with rubbers(sorex 36)Have found Chris Ashton test day setup pretty good..just looking for a little more turn in.temps are usually 30degrees celcius
thanks Bob
Barger is offline   Reply With Quote
Old 09-17-2007, 07:50 AM   #21664
PW
PW's Avatar
Send a message via AIM to PW
thanks Bob
I just needed a little more stability in the rear, so I tried the med/flex rears. I will try the new fronts at the next race (Tony P tried the fronts and said they were awesome).
The flexy top-deck is no good (holds tweak)
Latest setup
PW is offline   Reply With Quote
Old 09-17-2007, 09:00 AM   #21665
yyhayyim's Avatar
Trader Rating: 26 (100%+)
new Med Flex rear arms for the Mi3? What's the part number?
yyhayyim is offline   Reply With Quote
Old 09-17-2007, 09:00 AM   #21666
abailey21's Avatar
Trader Rating: 35 (100%+)
U3250 rear's
U3249 Front's
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-17-2007, 09:39 AM   #21667
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
did you post your set-up?
signature'd
|<R1Z |> is offline   Reply With Quote
Old 09-17-2007, 10:15 AM   #21668
Originally Posted by jimmy..maddison View Post
hey randy
pm me your set up
thanks jimmy
It's still really close to my nats setup. Are you running a spool or 1-way on your car?
Old 09-17-2007, 10:30 AM   #21669
MagicMarker's Avatar
Latest setup
You rock!! Thanks Marker
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 09-17-2007, 11:29 AM   #21670
1way was much better to drive felt nice , i tried the overdrive pulley and it was garbage felt weird and over heated tyres,
can you send me your exact set up dude?
jimmy
Old 09-17-2007, 11:38 AM   #21671
JayBee's Avatar
Trader Rating: 31 (100%+)
Get back to work Skypilot!!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-17-2007, 03:28 PM   #21672
jimmy
My nats setup with AE silver rear springs, flat front inner pin, .5mm pro-squat, 3 hole 1.2mm pistons, and a 1 way.
Old 09-17-2007, 03:29 PM   #21673
Thanks PW
Old 09-17-2007, 03:39 PM   #21674
PW
PW's Avatar
Thanks PW
NP
Old 09-17-2007, 05:46 PM   #21675
JayBee's Avatar
Hey guys how important is the lil 'bridge' that's on the outside of the front arms? I really hate to think that the 3 arms that I have are totally useless because the bridge is broken
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
