Old 09-15-2007, 07:50 AM   #21646
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey fellas, what's a good starting rollout w/ 60mm & a C027?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-15-2007, 03:56 PM   #21647
skypilot's Avatar
Trader Rating: 14 (100%+)
whats rollout?
or,
rollout schmo out, gear it till it melts then back off a tooth.
skypilot is offline   Reply With Quote
Old 09-15-2007, 03:59 PM   #21648
skypilot's Avatar
btw, decided not to be lazy and put the thick chassis and top deck on, jaco 2xpink and 2xpink orange, 13.5, holy smokes that was fast and fun. problem thou, wore out the foams in one night, is that normal??
Old 09-15-2007, 06:49 PM   #21649
porsche928gs's Avatar
porsche928gs is offline   Reply With Quote
Old 09-15-2007, 06:52 PM   #21650
justin lessard's Avatar
Send a message via AIM to justin lessard
if its brushed 27.5..brushless idk
justin lessard is offline   Reply With Quote
Old 09-16-2007, 05:53 AM   #21651
Static_racing's Avatar
What is the track like? Is it open/tight or large/small? Are there lots of tight switchbacks or is it a roval? All of these things matter when measuring rollout. I'd start with a 28mm rollout and tune from there.
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 09-16-2007, 10:24 AM   #21652
skypilot's Avatar
track is SIR (they laid carpet for the winter over the asphalt) our wed, fri, and sunday racing is on liverc.com (usually)
Old 09-16-2007, 12:21 PM   #21653
boon's Avatar
hey guys, bit off topic here..
just got some new cells hot from the factory and not sure what to do with them as there is no racing for a few weeks!
should i build them, charge, discharge, equalise and put a bit of juice back in them for the next few weeks or just leave them be with the charge they have in them from the factory? btw there IB's
boon is offline   Reply With Quote
Old 09-16-2007, 12:35 PM   #21654
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Do exactly what you said and cross your fingers that you don't loose cells.
Jon Kerr is offline   Reply With Quote
Old 09-16-2007, 01:22 PM   #21655
STLNLST's Avatar
Trader Rating: 19 (100%+)
i'd build them and then put some charge into them and pray for the best:batma n:
STLNLST is offline   Reply With Quote
Old 09-16-2007, 01:38 PM   #21656
boon's Avatar
when i said "hot out of the factory" i mean, just out of the factory, not that my cells where actually hot as far as i know there isnt a problem with the cells just wondering what is the best way to store them before the next race
cheers for the help
Old 09-16-2007, 03:08 PM   #21657
PW
PW's Avatar
Send a message via AIM to PW
cheers for the help
Build them, discharge them and then charge them fully at 4amps. Repeak (3 or 4amps) once a week you don't run them.
Ran my "big track" setup this weekend and the car was dialed! Made a few changes for the extreme tempature:
-2-hole pistons (drilled 1.2mm)
-40wt oil with Hybrid o-rings (35wt if you have stock o-rings)
-New med/flex rear arms
PW is offline   Reply With Quote
Old 09-16-2007, 03:40 PM   #21658
Been working on a rubber/Carpet setup, We'll see how good it is in Vegas.
I'll have the rest of the Team there to help and depending on how good it is, I'll make sure its posted.
Team Driver For:
Old 09-16-2007, 04:03 PM   #21659
yokemad's Avatar
That would be Great Mike Many People waiting for a Good Rubber Setup...
Wish you a best Luck in Vegas
yokemad is offline   Reply With Quote
Old 09-16-2007, 04:49 PM   #21660
Thanks bro
Team Driver For:
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
