Old 09-13-2007, 12:55 PM   #21616
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Skiddins View Post
Raise front roll centre, or to be really lazy, just spread superglue over the sidewall of the front tyres to stop them distorting during cornering.
Skiddins
uuumm, i'm not that darn lazy.
skypilot is offline   Reply With Quote
Old 09-13-2007, 12:59 PM   #21617
skypilot's Avatar
Originally Posted by Randy Caster View Post
I dont have much rubber tire carpet racing experience, but if Im having problems with traction rolling I usually just go down a step on the rear springs and it takes care of it.
well thats just too easy. but makes sense, when i went to a harder front spring to make it loose it actually dug in more. thanks.
Old 09-13-2007, 12:59 PM   #21618
POUNDITRACING's Avatar
NO, we have the thunder boats this weekend. Zooooooooooommmmmmmmm.
Can you say sunny San Diego with lost of alcohol and half naked women? I met a porn star last year.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 09-13-2007, 01:07 PM   #21619
Send a message via ICQ to MattW
Actually, superglued sidewalls is something that is widely used on rubber tyres on carpet, it reduces the sidewall flex.
Less caster can help as well.
MattW is offline   Reply With Quote
Old 09-13-2007, 03:21 PM   #21620
Customworksking's Avatar
Trader Rating: 71 (100%+)
Red face
Originally Posted by skypilot View Post
ok guys, not sure if i need help or just need to stop being lazy, local track (sir) installed carpet, outdoor pavement still going strong also, carpet on friday, pavement on sunday, last night i ran the car on carpet with pavement setup and on sorex premounted 28's, (spec tire for upcoming traveling point series) car starts of off good and as expected it traction rolls when tires get warm. not wanting to rebuild the shocks and make a tons of adjustments, any quick and easy tips to get the car to work, i do have the thick top deck, 2.5 chassis and 5 cell chassis, like i said, i'm just being lazy and not wanting to switch the car back in forth. oh and this was with a 10.5 brushless and madza 6 body. maybe i should build a carpet car and just use the medium arms for outdoor.
1 raise roll center
2 add 1mm of droop frt & rear
3 add camber
4 sway bars
theres few
Customworksking is offline   Reply With Quote
Old 09-13-2007, 03:26 PM   #21621
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Dang I was hoping to see the durability test on a Mi3 this weekend... o well, have fun anyway
Old 09-13-2007, 05:18 PM   #21622
yokemad's Avatar
@MattW
Do you mean Front Wheels only or both front and REar wheels also Is that Both sides of the Wheels that you can superglued...
Cheers
yokemad is offline   Reply With Quote
Old 09-13-2007, 05:48 PM   #21623
abailey21's Avatar
Trader Rating: 36 (100%+)
Thats better than any hole in the wall bar i'll try and sneak away too
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-13-2007, 06:58 PM   #21624
Whats up guys, just wanted to give another heads up about some new (and old) parts that might make life easier. Schumacher came out with some new diff rings, found out a way to make them completely flat, no need to sand or anything, pretty cool. I just built a diff using them and it is better than any diff I have built with sanded diff rings, absolutely no high spot at all.
There's only one problem, they share the same part # as the old Mi2 diff rings (U2408) and of the 5 pairs I got, only 1 pack had the new rings. Hopefully I cleared out the old stock and they will be shipping only the new rings from now on. You can easilly tell which are new and old, as the new ones dont look like they've been punched out, both edges are completely square.
These rings don't have a notch like the Mi3 rings do, if you want the matching outdrives without notches, order U2572 and U2571 outdrives.
Old 09-13-2007, 07:25 PM   #21625
Are you trying to say that I like to run really tight lines?
Old 09-13-2007, 08:06 PM   #21626
JayBee's Avatar
Trader Rating: 31 (100%+)
So just to clarify Randy, will the 'new-style' diff rings fit on the MI3 outdrives?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-13-2007, 08:41 PM   #21627
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I know I'm not Randy, but I am certain they will fit. The Mi2 diff and the Mi3 diffs differ (ha ha) in that the Mi3 diff has indexed outdrives and matching rings. The Mi2 diff is not indexed and neither are the corresponding rings. So Mi2 rings work on an Mi3, but Mi3 rings won't work on an Mi2.
If I remember corectly one of the better team drivers has a preference for the non indexed rings because if some how the diff gets realy tweaked theres no chance that the ring will ride up on the indexed section and cause the diff to lock. It will just rotate and remain flat. I wanna say it was PW or Mr. Kerr or . . .?
Old 09-13-2007, 09:11 PM   #21628
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
believe Andrew is right.
the MI2 rings fit the MI3 diff....
I've run the MI2 in the front...I found the diff to need less work just a guess probably the rings...but the diffs basically felt the same in nature.
I bought the Mi2 diff at the suggestion of the Shui
could be wrong but the MI3 rings are little less in price....it's been a while since I've ordered them.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 09-13-2007, 09:15 PM   #21629
Tight against the outside wall.
Old 09-13-2007, 09:16 PM   #21630
Looks like your question got answered.
Having rings that dont lock will also help with the life of the diff, rather than the diff balls slipping on the rings, the rings will slip on the outdrive.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
