Old 05-25-2002, 02:53 PM   #2146
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
ImpactPlayr....Ok the whole castor thing is a tricky subject. One thing that I have noticed on the Schumacher cars is with the large amount of castor that they have stock IE:6 to 12 deg when the wheels turn and the suspension is compressed like in a corrner there is about a 2 deg camber gain depending on the pos. of the upper arm and ball stud. Ok so normaly more castor will help with mid corner and exit but with this car you get increased camber gain which will lead to loss of traction in the middle and exit of the corner. I have tried running rear arms in the front and shaved a little off the back side of the front upper suspension mount to take out more castor. Now I can run 0deg castor and up to 12deg of castor. I like the car best with 2 deg castor and 2 deg kick up in the front which is a total of 4 deg of castor. But the way the suspension on our car is designed we get reactive castor with kickup in the front, so this means that the castor will increase as the suspension is compressed.
So what you said about with less castor you feel the car has more exit steering is correct. Because with the lesser deg of castor the camber gain is less which means more grip through the start and exit of the corner.
The way I run my car with so little castor and kick up the car turns in very well and changes direction even better. Now it does not get half way through the corner like it did and it just lack the grip needed to complete the corner.
One thing that I noticed that lead me to what i did was that I was always going through more front tires(rubber) then rear tires. Meaning they were wearing far faster then the rears and they were the same compound and same inserts.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-25-2002, 03:29 PM   #2147
jonski's Avatar
Trader Rating: 224 (99%+)
Default Castor
So, when I see set-up sheets that say 0, 2, 3, etc degrees of castor, they are running the rear arms on the front? That is the lower arms correct? With the right upper arms?
Jon
//// Hitec Lynx 4S / B6 / SC5M ////
jonski is offline   Reply With Quote
Old 05-25-2002, 06:22 PM   #2148
FYI...Andrew Cartwright of the NW and driving a Mission is TQ at the Reedy race in mod after 2 quals!! Looking good for Schu
Silver is offline   Reply With Quote
Old 05-25-2002, 07:33 PM   #2149
jonski's Avatar
Default REEDY RACE
Can we get the results on-line anywhere?
Old 05-25-2002, 08:20 PM   #2150
not that I know of. Been getting updates from Andrew. He just lost TQ by 2 seconds. 1 more qual tomorrow.
Old 05-26-2002, 02:33 AM   #2151
Kevin K's Avatar
Jonski....thats correct the only way to get less castor is to use rear lower arms in the front as the stock arms have castor built into the outside where the pivot ball goes.
Yeah lets get some results please...........
Old 05-26-2002, 08:03 AM   #2152
jonski's Avatar
Default Castor
So, if I run the rear arms up front, what amounts of castor could I get? Pushing the upper arms forward/mid/rear would obtain what amount of castor?
Old 05-27-2002, 08:33 AM   #2153
Regional Moderator
Darkseid's Avatar
Well I tried running my Mission without the sway bars this weekend at the short track. It was much more nimble, but not as predictable.
Did pretty well at both tracks, the car is handling very well, no matter what set up I try! Now I just have to find a way to get some more speed.
TLR 22...Tamiya F104...
Old 05-27-2002, 06:10 PM   #2154
King-G's Avatar
Send a message via ICQ to King-G
I read over in the reedy race thread that the schumacher guys at the race were trying alot of mods....anyone have any info on what the mods were?..pics would be even better...
with the roll centre mod in the front...is it possible to use modified rear pivot blocks?..or must you use the fireblade parts?..
King-G is offline   Reply With Quote
Old 05-28-2002, 12:48 AM   #2155
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Default Re: Castor
good question.
BigDogRacing is offline   Reply With Quote
Old 05-28-2002, 12:50 AM   #2156
Hey you guys are going to love this- we made EDITable setup sheets for the Mission- you can make your own to look just like the PROS setup sheets- here's the link- check out our local club's site while you're there.... http://home.midsouth.rr.com/memphisrc/setup.htm
I worked my butt off on this one guys, so if you want to use it on your site, please give credit to the club. Thanks.
Hey Adrian- I might let you guys use this one.... my agent will call you...
Old 05-28-2002, 01:17 AM   #2157
Kevin K's Avatar
Big Dog....thats not totally correct if you see Jonski was asking about the rear arms in the front which will reduce the amount of castor. The rear arms do not have castor built into the outside where the pivot ball goes like the front arms do. So the amounts of castor will be different also the position of the rear arm in the front will naturally be a little further back in any position then the front arm. This is do to the where the pivot ball goes on the rear arms is positioned more towards the rear of the car...if you follow what Im saying. So the amounts of castor if you used the rear arm would be different then if you used the front arm.
Jonski.....I have to measure the amount of castor with a stock upper bulkhead as the one on my car is shaved to reduce castor even more. When I get a chance to do this I will let you know.
Old 05-28-2002, 06:26 AM   #2158
Oh, sorry Jonski, I wasn't paying attention to the fact that you were asking about the rear arms... my bad
Old 05-28-2002, 07:53 AM   #2159
Regional Moderator
Darkseid's Avatar
BigDog: whats the difference between your EDITable sheets and just entering your settings onto Schumacher's blank setup sheet in Word then renaming it and saving it? My sheets end up looking just like the pro sheets you can download off of Schumacher's site, except with my name and settings.
Old 05-28-2002, 09:31 AM   #2160
Well, I personally like the quick reference sheet where you can see the postions marked on teh graphics- and it looks cool too. But in your case, I think you should use the Word version since you seem to like it so much.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
