Old 09-10-2007, 01:45 PM   #21556
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
wow. i am perplexed. i cut 0.050" off of mine, and they rub just a little.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-10-2007, 02:10 PM   #21557
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
THansk for taking the time to explain all that. Ill be cutting some plastic and filling y'all in when I get home
Old 09-10-2007, 05:22 PM   #21558
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by andrewdoherty View Post
I'll have to try it. It could have something to do with the amount of roll center shims and the shock tower positions too I suppose.
Was that with the lowered f. shock tower JB?
Sure is buddy I'm using Chris G's setup also but with some differences- lowered frt & rear shock towers, 2.5mm bottom, 50% rebound in the frt shocks AND third holes on the shock towers frt/rear. This set-up is pretty frickin' awesome so far on our low bite/no groove carpet. BTW, I'm runnin' Magentas on all 4 corners
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-10-2007, 05:29 PM   #21559
JayBee's Avatar
Originally Posted by SRW141 View Post
Yes I took 4mm off the short ball cups. Front shocks only. I use xray springs. I checked and it doesn't hit the the arms at all, even when compressed.
Ditto....
Old 09-10-2007, 08:14 PM   #21560
hey does any one know where i can get a pdf mi3 manual or a compiled word document version? downloading individual pages sucks
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 09-10-2007, 10:05 PM   #21561
I got it all together tonight. Heres what I found works perfectly . . .
materials:
1 lowered shock tower
2 AE spring perches
2 xray springs
2 schumacher shocks
2 long ball grippa ball cups
Procedure:
Cut 2 ball grippa ball cups down to roughly 12 mm in total length(other sizes might also work but this is where I first cut them and they worked. See note at bottom **). Thread shortened ball grippas onto end of schumacher shocks until shock length is 61 mm fully extended from end of aluminum cap to end of ball grippa. This will require threading the shock shaft almost all the way into theball grippas. Install lowered shock tower, xray springs and ae spring perches. Install 60 mm pro 53 Parma magentas onto Mi3. Turn shock collars to acheive ride height. Set droop. Enjoy newly instaled lowered shock tower with foam appropriate ride height. FYI io checked ride height with all the new shock positions and I could get any ride height and droop combo I'd ever want with the above setup. From 0-5 mm droop and 2-8 mm RH with
59-60 ish mm tires
** The short ball grippas that come with the kit for the shocks are about 14.3 mm long end to end. A standard ball grippas (the ones used elsewhere on the car) are 19 mm long end to end. I chose to cut down longer ball grippas so I would always have the 14.3 mm kit ball cups to use when I go back to rubber tires. In the end I think Seaball had it right about the cups needing to be about 1 mm shorter than the kit shock ball cups. That would give a ball cup that is about 13 mm long. I don't doubt that JB's 10 mm ball cups also work, but I also can't see how his AE perches are not resting on the arm. I can tell that mine are actually resting on the arm at one point in the suspension travel. If it becomes a problem Ill just shim it back to the corect length as seaball suggested. In moving the suspension through its travel I don't think the cup moves enough for ME to worry about it. We'll se once I get it onthe track though. If I get a weird tweak I'll know why
Shoot me any questions ya got. Its kinda alte so I probably didn't exp[lain this as well as I coulldve.
Old 09-10-2007, 11:22 PM   #21562
JayBee's Avatar
Actually buddy my ball grippas are 11.5mm. My perches do rest a tad on the arm at rest but with the two times I've been at the track- no problems.....YET! I'll keep a close eye on it though
Old 09-11-2007, 12:15 AM   #21563
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default shock bushing and washer
got a silly question.
I lost one of the Spacer Mouldings ...
the little plastic piece that goes on the upper screw shock mount, believe it's part number U613.
Question, is there something else I can use instead of the shui part.
Just looking for an option.
Do the TC5 shock bushings fit or any another options.
ohh..almost forgot....I have a bent axle/CVD pin ....shui is out of stock...does any other brand fit the axle?
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 09-11-2007, 06:55 AM   #21564
yyhayyim's Avatar
Trader Rating: 26 (100%+)
What's the part number for the Tamiya yellow springs PW and others used for on-road?
Tower has some tamiya Yellow springs but I just want to make sure they are the correct ones: http://www2.towerhobbies.com/cgi-bin...?&I=LXFAD6&P=7
yyhayyim is offline   Reply With Quote
Old 09-11-2007, 07:47 AM   #21565
PW
PW's Avatar
Send a message via AIM to PW
Don't tell him; he is trying to put them on his new Serpent car!!!
LOL...j/k
PW is offline   Reply With Quote
Old 09-11-2007, 07:54 AM   #21566
PW - On your setup, with the 3rd hole in the front hubs, do you literally drill a 3mm hole between the 2 existing holes? Just does not look like a lot of meat there.
Besercoe is offline   Reply With Quote
Old 09-11-2007, 07:59 AM   #21567
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Yeah he did you have to be perfectly dead center and you will actually go a little into the other two hole it will look like its scalpeled kind of like the shock tower holes. Hope this helps.
Bryan
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 09-11-2007, 08:22 AM   #21568
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You'd actually want to use a 2.5mm drill bit so that you can thread the ballcup through rather than having it just slide through.
Old 09-11-2007, 09:50 AM   #21569
Got it. I just got 10 mm from you saying you took 4 mm off from the shorter ball cups which measured about 14 mm on my car. In the end all that matters is that you have a cup thats roughly 11-12-13 mm. I am a bit bewildred as to how you got your shock length down to 59.5 mm though. I couldn't get past 60.5 with the cup threaded as far in as I coud get it. Weird . . .
Old 09-11-2007, 10:55 AM   #21570
yyhayyim's Avatar
LOL...j/k
That's cold, PW...I got a new Mi3 comming in this week...but they are going to also be run a Sepernt S400..
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
