Old 09-04-2007, 06:48 PM   #21451
Send a message via ICQ to Jan Larsen
Originally Posted by MattW View Post
The bulkheads are lighter (25-30g) but not thinner as far as i'm aware. For ref, my car weighed in at 1420 with 5 cell at the weekend. I happened to be standing with one of the HB guys as we both weighed our cars - and his was 1450 - and he stood on the podium at our national!!!
It is fair to say that i have done a bit of work to get it to that weight. Titanium pins/turnbuckles/ball joints, Titanium/Alloy screws, L/W Mazda 6 shell (although i reverted to heavy later in the meeting). Electronics are LRP Sphere TC, GM motor, KO 302 reciever, KO full size servo.
Me and a mate made an experiment and drilled quite a few holes in the bulkheads at strategic places, but that only shed like 10 grams, not really worth the effort. Glad to see the new bulkheads will loose up to 30 grams
I've got all the screws replaced with titanium (even the 4 ones in the LRP TC fan lol) and that shed quite some weight. Ti turnbuckles and pivot pins are in the mail, as is the lightweight S9550 Futaba servo (17 grams to save on that one alone!). Matt, what partnumber are the titanium balljoints? Also, are there plans on making titanium hinge pins?
Jan Larsen is offline   Reply With Quote
Old 09-04-2007, 07:13 PM   #21452
Originally Posted by PW View Post
The shims are hardened alloy.
thanks for clarification
Besercoe is offline   Reply With Quote
Old 09-04-2007, 09:29 PM   #21453
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by yokemad View Post
on the kit carpet setup it says 9mm Droop Is that a kind of printing error???
If somebody Share A good Carpet setup That would be great
9mm droop from lifted chassis to floor.
Measure the ride height. If it should be 5mm, set it there. Then lift the end of the car and set it back down on your flat board only enough so the tires touch, but there's no weight being placed on the suspension, then measure ride height again. It should be a 9mm now. The difference between static ride height and lifted height is your true droop. (4mm of droop in this case. 9mm lifted height - 5mm static ride height= 4mm true droop.) On the Mi3 setup sheet, it lists the chassis to floor dimension instead of the difference between the two as your droop setting.
Jon Kerr is offline   Reply With Quote
Old 09-04-2007, 10:00 PM   #21454
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hey Jon.. carpet track on Sunday?
Old 09-05-2007, 03:53 AM   #21455
yokemad's Avatar
thanx Jon
I always put the car on setup board then measure like 4mm or 5mm etc...so 5mm ride height ,7.5mm droop means 7.5mm-5mm=2.5mm droop???
are you racing on carpet on sunday?
cheers
yokemad is offline   Reply With Quote
Old 09-05-2007, 07:30 AM   #21456
Jon Kerr's Avatar
No sorry. I can't this Sunday. Family plans. I'm not racing Vegas so I'm not really hurting for carpet practice.
Old 09-05-2007, 10:01 AM   #21457
Regional Moderator
Darkseid's Avatar
Man, not running my TC much during the summer has left me way behind on the latest info. Lightweight bulkheads??? Didn't know anything like that was even in the works.
Personally, I'm more about adding weight. Locally, indoors on carpet, we run brushless/lipo in TC class, but still use the standard Roar weight minimum. Needless to say, running brushless/lipo, with foams, requires some weights to be added...or should a say a lot of weights tobe added.
TLR 22...Tamiya F104...
Old 09-05-2007, 10:11 AM   #21458
Sigearhead's Avatar
Trader Rating: 68 (100%+)
I have a great carpet set up. I would like to share it with you guys. I don't have an adobe setup sheet file to fill in and save and then post. All of the ones I go into you can fill in but you have to print them out. If any one of you guys has the file I can fill in, save, and then post please send it to me so I can fill it out and send you guys the setup. Paul sent me one once upon a time but I think I deleted the email.
[email protected]
Sigearhead is offline   Reply With Quote
Old 09-05-2007, 10:18 AM   #21459
I know you dont need to practice for Vegas, but dang man you gotta run that Mi3 sometime..
Old 09-05-2007, 10:20 AM   #21460
Send a message via ICQ to MattW
My car has standard bulkheads, but they have been drilled a little to save somewhere in the region of 12g.
My ball joints are Tir ones that i have had for quite some time. Not 100% sure if they still have any, i don't think so. However, some will be available soon. Titanium pins should be available at some point. Schumacher have a lot of other light weight bits available soon.
btw, jan, you only need to Ti screws to hold the fan on
You talk about it being a bucketload of cash, and yeah it is - but it's exactly the same as the other cars, as i tried to illistrate with the Cyclone companison.
MattW is offline   Reply With Quote
Old 09-05-2007, 11:09 AM   #21461
Jon Kerr's Avatar
I know. It's just sitting there. I'll get out there. Are they running carpet next Sunday? I maybe able to go then. I'm not leaving for Hawaii until Monday the 17th.
Old 09-05-2007, 11:14 AM   #21462
Skiddins's Avatar
I've had a search and can't find anyones carpet setup's.
Does anyone have a link to some of the good medium bite carpet/rubber setups.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-05-2007, 11:15 AM   #21463
[email protected]
Go to cutepdf.com and download the free software.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 09-05-2007, 02:00 PM   #21464
Yep, carpet track is open on the 16th as well, I'll be there.
Old 09-05-2007, 03:58 PM   #21465
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
If anyones intersted I have a set up sheet I made in excell that I developed for my mobile device ( samsung blackjack) I am pretty sure it would work on any device running wm5.0. e-mail me if interested.
Along those lines srw is right about cutepdf. It works great. I just decided to make a mobile version because I can view it anywhere I want, I can edit it however I want, I don't have to carry paper crap around everywhere, and the files are measured in kb, not in mb.
If you are running wm5.0 and want to edit and view word, excel,and powerpoint documents feel free to e-mail me and Ill send you the files you need for your phone along with my blank and filled in set ups (I think the foam set up a few of us here in texas are using is prety darn good. We;ll see how good when McGoo gets back from Vegas with some hardware
[email protected]
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
