Old 09-03-2007, 05:58 AM   #21421
yokemad's Avatar
hi guys
I have a silly question do you guys apply tyre additive before every heat or Once a day lasts till end of 3 heat 1 final???
Cheers
yokemad is offline   Reply With Quote
Old 09-03-2007, 06:51 AM   #21422
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I try to put my compound on the same for every run so the car is more consistant. Normally right around 20 minutes or so with my tire warmers. I try to do everything the same each round as best I can.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
wyd is online now   Reply With Quote
Old 09-03-2007, 07:27 AM   #21423
yokemad's Avatar
on setups usually says before 15min-20minute ,means I haven't got enough time to apply between heats...I'm also wondering how you team drivers clean and relube the Ball bearings cos I've bought my mi3 from a serious race driver and car extremely free and smooth I want to keep it in same condition but not sure If I'm doing wright treatment to bearings...I usually clean them with motor cleaner then sometimes wd40 then 1-2 drop oil which is for motor bushings very light one...I know some people use break pad cleaner what you can recomend ? After motor cleaner part finish do I have to wait for some time?
cheers
Old 09-03-2007, 07:29 AM   #21424
AdrianM's Avatar
cheers
Just run the bearings out of the box they come oiled so there is no need to clean them.
If you have no time for a 15-20 min soak of traction compound just do the best you can. Even 5 min is better then running nothing on the tires.
Adrian Martinez
Old 09-03-2007, 08:17 AM   #21425
yokemad's Avatar
Thanx Adrian
don't you clean and relube bearings regularly ? I personally clean all bearings after 4-5 race meetings...
Old 09-03-2007, 10:59 AM   #21426
JayBee's Avatar
Trader Rating: 31 (100%+)
I absolutely love this car!! 'Nuff said
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-03-2007, 11:11 AM   #21427
Jochim_18's Avatar
Got my MI3 put together I'll post some pics later. All I can say this car is by far abosulutely the best workmanship I've ever seen produced in a touring car. What's xray gonna say about this. I beleive this the new high laxury car on the market. This is a thing of beauty.
I've got all my electronics installed it's tight fit but I manage to have my electronics layed out nice and neat. Considering I'm running a Novak brushless system.
Old 09-03-2007, 01:39 PM   #21428
MagicMarker's Avatar
yokemad: I change out bearings pretty regularly. If I'm going to a big race, I make sure the bearings are all new and I clean them out with motor spray, throw them in a jewelry cleaner, and soak them overnight in some light weight oil. Then blow them out with an air compressor and I'm good to go. If I'm run in a club race - I just throw them in the car and let it rock.
L8R Marker
Team Schumacher USA - Team Trinity - Team McGoo Racing - Ken Graf/x - Mini Mafia [Dallas Chapter]
MagicMarker is offline   Reply With Quote
Old 09-03-2007, 02:33 PM   #21429
yokemad's Avatar
@Magic Marker
Do you use ceramic bearings and what are the advantages of them over the other ones?
are the ceramic ones needs to be relubing like the normal ones?
I put a really thin washer under the steering yoke and two O rings to take the slop off from turnbuckles and yoke cos there was too much slop up there how is your cars guys is that all same or is that my car only needs a cure for that bad slop???
cheers and Thanx for the tips
Old 09-03-2007, 03:38 PM   #21430
yokemad: I only use ceramics on the drive train (diffs, pulleys, and layshafts). I hit stuff and it seems to be too expensive to run ceramics in the hubs. I still treat them the same as normal bearings and it seems to work just fine.
As for Slop - I don't use o-rings anymore - I feel it has a tendency to bind at inappropriate times and can cause premature wear on parts from collecting dirt. I would say I have plenty of play in the ballcups but not too much slop. Once I get excessive slop I start replacing parts. Hope this helps.
L8R Marker
Old 09-03-2007, 06:27 PM   #21431
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You really don't want your steering completely slop free. This will make the car very twitchy unpredictable. If there's a little slop, it will allow for little imperfections in the surface. If there's no play at all, every little imperfection will change the direction of the car and it will feel like the car is wondering all over the track.
Jon Kerr is offline   Reply With Quote
Old 09-03-2007, 07:11 PM   #21432
yokemad's Avatar
thanx guys
You are great... I'll remove the O rings then...but I'll keep the shim under the steering post otherwise steering yoke goes up and down ... I also change the Aerial Post position It's at the centre of the chassis now...
Is there anyone have tried the Carpet setup of Chris Ashton from Mi3 Manual?
What are your thoughts about it...I just set the car with that setup do you think It is ok ?
Cheers
Old 09-03-2007, 07:23 PM   #21433
m3ndo5a's Avatar
Default More than I need
I got a back up kit for sale if anyone is interested. NIB
These are great kits.....
http://rctech.net/forum/showthread.php?t=179876
Peace
m3ndo5a is offline   Reply With Quote
Old 09-03-2007, 09:13 PM   #21434
Randy Caster's Avatar
Trader Rating: 46 (100%+)
We actually learned a lot about steering "play" the other day at Hot Rod Hobbies. I went up there with Cavalieri and Maifield to hang out and get laptimes for them. Basically run after run, Cavalieri was about a half second faster on his fast lap, normally these guys are head to head. What happened is Maifield glued his servo saver down because the track for the Shootout is always smooth and well groomed, but at this point it had been sitting out for a month or so and got all rutted up. Maifield's car hit every little bump in the track and made it very unstable, Cavalieri's car basically would just cruise over the little bumps without being affected much.
You dont see this as much in on-road racing because we dont deal with a lot of bumps and ruts, but there are still the little ones, and this is why I always recommend staying with the stock Schumacher ballcups. I personally dont do anything to them to make them fit more snug, don't feel they are sloppy enough to need it.
Old 09-04-2007, 02:51 AM   #21435
One thing that makes me wonder is how do you guys measure the camber and front toe with all the slop there is? My experience says the toe-in on Schumacher cars varies 1-1.5 degrees per side because of this slop (and it's like that since new), camber can vary 0,5 degree easily, so how should I interpret the numbers on the setup sheets
For my own reference I always measure toe at max toe-out and camber at max negative when I write down my setups.
olev is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
