Old 09-01-2007, 05:48 PM   #21406
hey quick question to all u fast guys which is your pick
lrp tc spec
or novak gtb spread spektrum version and of course why?
cheers btw if ur sponsored please say u are
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 09-01-2007, 07:02 PM   #21407
Randy Caster's Avatar
Trader Rating: 45 (100%+)
lrp tc spec
I personally run the LRP because it is said to be better with the Orion brushless equipment that I use. Havent tried a Novak firsthand to know for sure, but that is what I was told.. The Novak stuff seems to work fine when using a Novak motor if thats what you plan on using.
Old 09-01-2007, 11:13 PM   #21408
skypilot's Avatar
Trader Rating: 14 (100%+)
i have the novak and the lrp, i like the lrp better, easier to setup, and when changing to brushed motor, less wiring hassle.
skypilot is offline   Reply With Quote
Old 09-01-2007, 11:15 PM   #21409
Originally Posted by POUNDITRACING View Post
He wants me to go up there and build it with him.
You can take mine too.
Mitch P. is offline   Reply With Quote
Old 09-02-2007, 07:05 PM   #21410
PW
PW's Avatar
Send a message via AIM to PW
Got to run my "big track" setup today on a med size track and it was still awesome! Not sure if anyone has had a chance to try it, but it's the best setup I've had in years
PW is offline   Reply With Quote
Old 09-02-2007, 08:33 PM   #21411
AdrianM's Avatar
Have you posted it here...if not could you?
This sucks...I used to just walk over to your desk and you'd hand it to me...lol!
Adrian Martinez
Old 09-02-2007, 08:41 PM   #21412
so who took over pw's job as a pro driver?
also is it true schumacher are releasing light weight mi3 bulk heads red it a few pages back?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 09-02-2007, 08:44 PM   #21413
AdrianM's Avatar
Well, PW is still the fast guy on the team. Randy Caster is right there too.
The guys at Schu USA are not hard core racers but PW and I are still here on Schu Corner along with the rest of the Schu drivers around the globe to offer support and share info.
That said Shawn Palmer has done some great things to get the team more organized so everything is looking good.
Adrian Martinez
Old 09-02-2007, 08:46 PM   #21414
oh so he will still run schumacher at majors?
sorry i think im a bit slow today
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 09-02-2007, 08:49 PM   #21415
AdrianM's Avatar
Well....uh...Schu UK has cut travel funding for the US team so I dont know for sure.
Adrian Martinez
Old 09-02-2007, 09:42 PM   #21416
PW
PW's Avatar
Here is a killer big track/med-high bite setup for the Mi3
Side notes: Used Muchmore rebound foam (2 whites per bladder) in front and rear shocks and MuchMore green o-rings.
Mi2EC arms front and rear.
Carefully drilled middle hole on steering blocks.
Front swaybar is mounted using the EC mounts (used front bumper screws).
Unfortunately Schumacher has no Pro-drivers
Old 09-02-2007, 10:03 PM   #21417
Mr. McGoo's Avatar
except for the McGoo.......
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 09-02-2007, 10:13 PM   #21418
PW...what would you change on your big track setup for a bumpy med track?
Barger is offline   Reply With Quote
Old 09-03-2007, 05:35 AM   #21419
Skiddins's Avatar
Saw the ligtweight bulkheads for the first time yesterday, they are being manufactured so it will be a while before they come in, apparently they shave 30g off the weight.
They don't look too different, they are slightly narrower, so extra shims have to be used to keep the pivots etc where they normally are and they are made froma better alloy.
Where the motor mounts, instead of having the large oval with slots in it most of that metal is missing and you just get two slots for the motor screws.
Should have taken some photo's Doh!
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 09-03-2007, 06:21 AM   #21420
Jonny Aird's Avatar
Skiddins
Hi Skiddins
Jonny Dronfield told me it needed extra shims to keep the same set up, but after speaking to Phil Booth he said that they cannot be narrower, as the eccentrics for the diff wouldn't fit. So no extra shims are required.
Jonny
XRAY | Hudy | Spektrum | Moorespeed | MB Models | Serpent |APE
Jonny Aird is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
