Old 08-31-2007, 11:28 AM   #21391
yokemad's Avatar
can anyone send me a Carpet setup for Mi3 please???...It's gonna be rubber tyres 27T stock 6 cell,Stock Chassis and top deck,med-high traction
what tyres and addictive you can recomend
Thanx in advanced
yokemad is offline   Reply With Quote
Old 08-31-2007, 11:52 AM   #21392
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Originally Posted by POUNDITRACING View Post
What's the deal with the Orion 4800 Lipo in the MI3. I read something on the other thread but I didn't finish reading it yet.
I'd stick to regular nimh stuff for now, dont know if Lipo is really allowed at too many tracks out here yet.. Tell Ilene youll be at my place, should work, its not the track at least.
Old 08-31-2007, 12:24 PM   #21393
skypilot's Avatar
Trader Rating: 14 (100%+)
hey guys, my track, SIR is about to install carpet for the winter, was thinking about 5 cell mod, any recommendations on which chassis to use.
skypilot is offline   Reply With Quote
Old 08-31-2007, 12:29 PM   #21394
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
use the MI3 5 cell chassis!!! if you are running brushless its perfectly balanced!!
Old 08-31-2007, 01:15 PM   #21395
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
It works fine all you have to do is run a shorter ackerman which is better anyways.
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 08-31-2007, 01:46 PM   #21396
Practically needed to use the foam chassis on the asphalt it had so much bite, I cant imagine how high the carpet bite will be up there lol.. Anyway I preferred the 6 cell chassis with the batts forward over the 5 cell chassis. I'd go with the thick 6 cell chassis if I were you.
Old 08-31-2007, 02:51 PM   #21397
skypilot's Avatar
thanks guys,
randy, i actually have used the thick chassis at SIR, and it worked great.
i will put that on and get a 5 cell one to try.
i did get a chance to run 5 cell 3.5 novak on foams at a large parking lot track with med bite, i haven't had that much fun since i don't know when. of course i never finished a heat... something about not suppose to pull the trigger on a mod motor like you do on a stock motor.
Old 08-31-2007, 08:51 PM   #21398
abailey21's Avatar
Trader Rating: 35 (100%+)
Exclamation
Quick question, I’m picking up a duratrax ice tomorrow morning and I need to know what size power supply to pick up? I’m going to head to radio shack cause I hear they have some decent deals, but what size do I need? I want to ultimately run to Ice’s off one power supply, I was thinking 25-30 amps? Any suggestions?
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-31-2007, 09:03 PM   #21399
Trader Rating: 71 (100%+)
Originally Posted by abailey21 View Post
Quick question, Iím picking up a duratrax ice tomorrow morning and I need to know what size power supply to pick up? Iím going to head to radio shack cause I hear they have some decent deals, but what size do I need? I want to ultimately run to Iceís off one power supply, I was thinking 25-30 amps? Any suggestions?
Radio Shack sells a 25 amp switching power supply for about $100. You could run three Ice chargers charging at 8 amps each
RBLove is offline   Reply With Quote
Old 08-31-2007, 09:53 PM   #21400
try more like 4 as power=voltage times current so:
25amps x 12 volts=300 watts
so 9volts (what a pack peaks at so worst case all four packs peak at once)
9 X 6amps charge rate x 4 chargers= 216 watts theirfore ur safe as running 4 long as u dont charge 10 cell packs at 8 amps lol
i use a 20 amp and its sweet runs charger warmers motor cooler discharger even charges my phone
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 08-31-2007, 10:22 PM   #21401
POUNDITRACING's Avatar
hobby people sells a 13.4 amp for $40. it actually puts out about 20a.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 09-01-2007, 06:23 AM   #21402
abailey21's Avatar
right on, thanks guys
K.C.C.O.
Old 09-01-2007, 03:54 PM   #21403
yokemad's Avatar
Hi
I'm still looking for a good carpet setup and d which tyres and addictive you recommend???
LRP Vtec 24R or carpet dragons or foams???
cheers
Old 09-01-2007, 04:13 PM   #21404
Customworksking's Avatar
Trader Rating: 69 (99%+)
Default set down
Randy has a good starting point from the nats U can find it here aa few pages back
Customworksking is offline   Reply With Quote
Old 09-01-2007, 04:45 PM   #21405
Is that setup working well for rubber tires on carpet?
It might be easier to find it on Schumacher USA's website in their tech area..
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
