Old 08-26-2007, 04:26 PM   #21316
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Jonny Aird View Post
Hi PW
What's the reason behind running the front shocks in the inner hole for foams and then using a much stiffer spring/oil?
Have you tried something similar with rubber tyres?
Cheers
Jonny
I havent done it so I dont know for sure, but possibly to clear the shock end from the wider 28mm rim?
Old 08-26-2007, 05:56 PM   #21317
Static_racing's Avatar
Moving the shocks inboard on the arm will give you a big more steering. I softens the front alittle without having to make a spring/oil change. I ran my Mi2EC like that all the time with 35lb springs up front.
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 08-26-2007, 06:01 PM   #21318
POUNDITRACING's Avatar
what are some online places to buy an MI3.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 08-26-2007, 06:31 PM   #21319
Trader Rating: 18 (100%+)
I've got one in stock.
RT76 is offline   Reply With Quote
Old 08-27-2007, 07:52 AM   #21320
I guess after running Losi for a while I think too far into things, with the older car you had to make everything fit together (including the front shocks on the arm) so sometimes I look past the simple explination of maybe just wanting more steering lol.
Old 08-27-2007, 09:13 AM   #21321
has anyone tried the new flex wishbones yet? if so have you noticed any difference handing wise.
jordan.norwood@ is offline   Reply With Quote
Old 08-27-2007, 10:18 AM   #21322
PW has been using Mi2 arms (more flex) with good results it sounds like. The softer arm will give more traction on low grip tracks.
Old 08-27-2007, 11:48 AM   #21323
abailey21's Avatar
Trader Rating: 36 (100%+)
Wanted to let everyone know that we received the Med and Ultra Flex front/rear arms and another shipment of CVD's today, they'll be ready to ship tomorrow morning.
Adam
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-27-2007, 12:53 PM   #21324
Regional Moderator
Darkseid's Avatar
Got a question guys.
I'm in the process of switching my Mi3 over for carpet season. But one thing came up...
The front end, when set up according to the manuals carpet set up, seems awfully wide. With the "screw block spacers" set to 2.5mm front/1.5mm rear, the front end is wider than the rear. And that's with me having the 1mm spacers against the hexes, only in the rear.
Is this how things are supposed to be?
TLR 22...Tamiya F104...
Old 08-27-2007, 01:11 PM   #21325
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Mr. McGoo View Post
I am now starting to do some testing for 19T - and I still have my mid corner and exit speed - but upon entry - my car is pushing. I thought I might be overdriving it a bit - but even when I feel like I am not overdriving it - it just doesn't enter the corners like I would like.
mark, what is turn-in? that's a big discrepancy in everyone's mind. for some, it's the "cut" or transitioning right on-center. for others, turn-in is defined as all the way to the apex, including the off-power section used to transfer the weight forward. here's what i have recently committed to memory..:
first, there is x amount of grip available to distribute to all the tires. that said, something is going to have to give, so to speak, in order to change the balance.
* less castor will turn in harder at the expense of on power steering.
* antidive will turn-in harder right on center, but may push slightly off-power in low grip.
* shorter front links get to the apex faster, but again, make the car twitchier on center. even 2mm is very detectable here.
* harder oil sharpens the car up, but will flatten it out mid-corner
* more rear toe can sharpen the turn-in at the (occasional) expense of cornerspeed
* front camber gain (link inclination) will help drag the front end down off power, but you may pick up the "dig" again.
* the front bar will also quicken the car up on center, but, like antidive, can cause a mid-corner push if it's too heavy.
that's mostly front end stuff, but entry problems are usually front end related since that's the end that's loaded. it sounds like you're pushing through the apex, which is more than just on-center laziness..
here's a scenario that could work...
1) take away the castor. the car will turn-in harder to the apex which could solve your problems by itself. it will also get rid of the weight jacking that castor induces...
2) assuming that you now need more on-power/high speed steering since the car is staying flatter, you next soften the front spring, or stiffen the rear (depending on how you want the car to transition: stiffer = quicker).
3) perhaps you pull the bar off instead, or inaddition to.
4) now, the car balanced but still pushing mid-corner. next go to a more angled front link which will bind the front end down getting some of that dig back that you lost when you switched castor blocks.
5) still floating through the corners? adding rear toe will bind the rear back down, and often give the car more off power steering as a result of the increased decelleration. nobody likes to mechanically bind the car down, but it often translates into better and more consistent lap times. (for real )
by now you should be able to drive fairly hot into the 180's, but i'm guessing your car will feel suffocated off power.
setups are a process... the more you practice it, the better you will be.
sorry for the lengthy tutorial..
- roger blankenship -
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 08-27-2007, 02:10 PM   #21326
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You rule seanuts How can I be cool like you?
Jon Kerr is offline   Reply With Quote
Old 08-27-2007, 03:21 PM   #21327
Maybe an all male review at Bending Cornerz?
Old 08-27-2007, 04:30 PM   #21328
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
I have one question I am wondering what exactly are the effects of going to stiffer front shock oil on asphalt. I understand that it will take away turn in away but what about on power??
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 08-27-2007, 05:54 PM   #21329
JayBee's Avatar
Trader Rating: 31 (100%+)
That's gross Randy
BTW, I've built up my carpet car using C.Goetz set-up w/ the exception of my lowered shock towers. His shocks are 62.5mm, I built mine at 59.5mm. Is that cool as long as I can acheive proper ride height? I'm also using less rebound in the rear. As soon as our carpet is in I'll see how this works...
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-27-2007, 06:03 PM   #21330
Regional Moderator
Darkseid's Avatar
Anybody got any thoughts about that carpet setup question I had a couple post back???
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
