Old 08-25-2007, 09:12 AM   #21301
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
Originally Posted by Jochim_18 View Post
One more thing what part of this car is the weakest point if there is any so I know which part I should buy????
extra cvd bones
Old 08-25-2007, 10:14 AM   #21302
UK.hardcore's Avatar
hey,
i recently bought an mi3 (online), but dont have it yet.
i'm wondering if there are any precations are tips to make it better?
i know to leave those rings off the pulley's.
UK.hardcore is offline   Reply With Quote
Old 08-25-2007, 11:48 AM   #21303
JayBee's Avatar
Trader Rating: 31 (100%+)
What foams are you carpet munch'rs running? 2xPink-Orange/2xPurple or 2xPink-Orange/Pink?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-25-2007, 05:53 PM   #21304
abailey21's Avatar
Trader Rating: 36 (100%+)
2X Pinks F/R
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-25-2007, 07:39 PM   #21305
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Team Schumacher laid it down today at the ROAR Region 2 onroad today. 3 of the 4 Team drivers where in the A in stock touring and Steve Walters the loan privateer all made the show. Team Drivers Tim Getchell finished 2, I was third and Mike Kling was 5th and I think Steve was 8th.
We all worked together to help get the best setups for each of us in this brutally hot and humid summer day.
It was a great day as are MI3's all worked great.
Ran th new alloy driveshafts today and they worked great.; Very nice.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 08-26-2007, 04:44 AM   #21306
If you are into crashing (like me), get a spare upper deck. I think I've gone through 3 of them by now. Other than that, the usual, front and rear lower arms, maybe C-hubs... I have actually broken only one front arm besides the top decks, so in my experience the top deck is the weakest link
olev is offline   Reply With Quote
Old 08-26-2007, 04:49 AM   #21307
yokemad's Avatar
hi guys
I just rebuilt my mi3s rear diff but after a Lap diff screw getting loose almost come out off from diff...
does any of you have any idea what cause of that screw getting loose
thanx in advanced
yokemad is offline   Reply With Quote
Old 08-26-2007, 04:54 AM   #21308
did you lock it with the set-screw?
does anyone use trakpower lipo's in the mi3?
A racecar is only as good as the mechanic who build it.
Old 08-26-2007, 08:27 AM   #21309
Mr. McGoo's Avatar
Alright fellow Schuie drivers - i need some help. I have my car pretty much strapped when it comes to stock. It has great entry, mid, and exit cornering.
It has been one of my favorite cars to drive - EVER!!!
I am now starting to do some testing for 19T - and I still have my mid corner and exit speed - but upon entry - my car is pushing. I thought I might be overdriving it a bit - but even when I feel like I am not overdriving it - it just doesn't enter the corners like I would like.
I don't use a sway bar with stock, but it really settled my front end down with 19T. W/O the sway bar in 19T - my car digs in at the apex and kills my corner speed.
So here is my setup I landed on yesterday - but its still not there - any and all help would be much appreciated....
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 08-26-2007, 08:30 AM   #21310
JayBee's Avatar
Anyone know in Chris Goetz Carpet Nats set-up, if he was using the lowered shock towers? It doesn't seem like it but I have 'em on my car and wanted to know if having them on will affect the set-up?
Old 08-26-2007, 08:53 AM   #21311
Mr. McGoo's Avatar
I don't think he was since he was running the prototype....
If you put up your stock tower to the lowered tower - you will see you have some of the same shock holes, but not all - it will change your shock angles and lengths, you will also need to shorten your shocks to make ride height
Old 08-26-2007, 09:06 AM   #21312
JayBee's Avatar
Thanks Marc
Old 08-26-2007, 12:46 PM   #21313
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You have a lot of stagger in the springs, I'd think you'd want to run around a 30lb rear spring with the 35lb front, same with the shock oil, 50/30 is a big gap there too. Slightly lower front ride height than the rear. Stand the front shocks up a hole. I like running a little anti-dive to get the car turning in a bit harder.. Theres lots more you can do, but give a few of those ideas a shot.
Old 08-26-2007, 04:06 PM   #21314
PW
PW's Avatar
Send a message via AIM to PW
That is a pretty standard stagger in weight spring/oil for foams since we run the inner hole on the front arm.
McGoo...Try the front anti-dive Take a little arm-sweep out of the front.
PW is offline   Reply With Quote
Old 08-26-2007, 04:14 PM   #21315
Jonny Aird's Avatar
Hi PW
What's the reason behind running the front shocks in the inner hole for foams and then using a much stiffer spring/oil?
Have you tried something similar with rubber tyres?
Cheers
Jonny
XRAY | Hudy | Spektrum | Moorespeed | MB Models | Serpent |APE
Jonny Aird is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
