Old 08-20-2007, 09:04 AM   #21211
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Originally Posted by Jon Kerr View Post
Unfortunately that's really all you can do. IB cells are so fragile and unpredictable. Even leaving charge in them doesn't always work. Kind of one of the reasons I've been doing so much nitro racing lately.
That really is a sh!tter aint it. I might just try and make a few 4 cell packs and get a 12th (any excuse hey) after the national.
Looks like i will have to buy some new cells this weekend.
Thanks for the help folks
Matt
raving-monkey is offline   Reply With Quote
Old 08-20-2007, 09:36 AM   #21212
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hey Jon, do you have a BL setup with the 5 cell chassis for BCR? I ran on Saturday but had the off-road ESC that has a lower temp cutoff that we didnt know about, so I had to switch to brushed, but the power I had with brushless was rediculous, however my car rolled too much for even me, and I think a flatter setup might help the laptimes a lot with the BL stuff...
Old 08-20-2007, 10:16 AM   #21213
randy
you got pm dude
jimmy
jimmy..maddison is offline   Reply With Quote
Old 08-20-2007, 12:40 PM   #21214
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Randy, I sent you an Email with my last setup from BCR. I think I'm going to go up to Tamiya next Saturday to go watch Patrick win TCS.
Jon Kerr is offline   Reply With Quote
Old 08-20-2007, 12:44 PM   #21215
Originally Posted by ROBORAT View Post
will the mi2 steel cvd bones be a direct fit to the mi3? sorry if this is a dumb question. its just that there's a source locally for the steel cvd bones and would be good to know if these actually work on the mi3.
They will work, but you really MUST use the 1mm spacers then AND you have to drill the center hole of the washers to 5mm, because Mi2 originally used the wider hexes and the 5mm part of the shaft is longer.
Of course you can also use Mi2 hexes and the conical washers that were used between hex & hub, they will give the same width, then forget about the washers.
olev is offline   Reply With Quote
Old 08-20-2007, 12:51 PM   #21216
Jon Kerr's Avatar
Randy, Email got kicked back. I guess I had the wrong one. What's your Email?
Old 08-20-2007, 01:57 PM   #21217
PW
PW's Avatar
Send a message via AIM to PW
Here is a killer big track/med-high bite setup for the Mi3
Side notes: Used Muchmore rebound foam (2 whites per bladder) in front and rear shocks.
Mi2EC arms front and rear.
Carefully drilled middle hole on steering blocks.
Front swaybar is mounted using the EC mounts (used front bumper screws).
PW is offline   Reply With Quote
Old 08-20-2007, 02:39 PM   #21218
JayBee's Avatar
Trader Rating: 31 (100%+)
Has anyone played around with the Parma Alfa yet. How is it on asphalt vs. carpet?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-20-2007, 03:54 PM   #21219
Trader Rating: 15 (100%+)
I tried the wide steering center link and 6 degree blocks and my car was dialed saturday.Car had killer steering in and out.Also raised the rear roll center almost all the way up.
AARON YOUNG is offline   Reply With Quote
Old 08-20-2007, 04:25 PM   #21220
JayBee's Avatar
Anyone?.....I know there's a few of ya out there running on carpet. What are your body choices?
Old 08-20-2007, 04:38 PM   #21221
Mr. McGoo's Avatar
I haven't ran the alpha lately - but it won many a championships before the Mohawk came out. The Alpha and the Mohawk are more carpet foam oriented. I have been testing the Mohawk and the DNA back to back with stock/19T foam.
I feel the Mohawk frees up the rear end just a tad and is a bit less aggressive than the DNA.
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 08-20-2007, 04:48 PM   #21222
abailey21's Avatar
Trader Rating: 36 (100%+)
thanks for emailing that to me this morning
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-20-2007, 04:49 PM   #21223
JayBee's Avatar
Thanks Marc
Any other opinions?
Old 08-20-2007, 05:20 PM   #21224
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks Marc
Any other opinions?
JayBee.... its good for AT LEAST a tenth.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-20-2007, 05:53 PM   #21225
abailey21's Avatar
I'm still using a DNA 1, no help here, i have a Mazda 6 on the way that everyone and their brother keeps telling me to get????
K.C.C.O.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
