Old 05-20-2002, 01:35 AM   #2101
Send a message via ICQ to JesseT
Jonski:
The carpet upper deck should do the trick. Also check that your rims are true and the rubber (if running rubber) is well glued. If the problem persists, running a slightly stiffer insert in front definately helps. I also used to have the rolling problem with my Mission on high byte carpet.
BR/ JesseT
JesseT is offline   Reply With Quote
Old 05-20-2002, 07:27 AM   #2102
Trader Rating: 71 (100%+)
PW - Kevin K.,
Ran my car yesterday for the first time. I was very impressed. I was able to run some of the fastest times on the track in stock and mod. I started with Paul's Snowbirds set up and made changes from there.
Everybody was pushing out the door and was turning in on a dime The steering is unbelievable. I LIKE IT
C-ya,
Rob Love
RBLove is offline   Reply With Quote
Old 05-20-2002, 07:38 PM   #2103
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Rob....Glad to hear that the car is working well off the board for ya.
Jonski......try adding more front camber or moving the ball stud on the arm to the outer hole if its on the inner hole in the front. You can also lay the shocks in more on the tower as well and get the stiffer sway bars if you dont have them. What tires and inserts are you running?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-20-2002, 08:28 PM   #2104
jonski's Avatar
Trader Rating: 224 (99%+)
Default Tires
I am running the Eagle C32 tires with Top Blue molded foams. They are an incredible tire for the money. Some guys that have ran them at my current track said they like them better than the Sorex tires. I haven't put them to a comparision test for myself yet though.
Kevin K - I went over your set-up that you gave me and I had quite a bit of things off. Like the ball-studs on the hubs were to the inside instead of the outside. Going to try to get it as close to yours as possible and try it again.
Thanks for your help guys.
Jon
//// Hitec Lynx 4S / B6 / SC5M ////
jonski is offline   Reply With Quote
Old 05-20-2002, 08:31 PM   #2105
jonski's Avatar
Default Stiffer Upper Deck
JesseT - I am going to get the top deck soon ( I hope). So I will also be trying it. Thanks for the idea, never really gave that any thought.
Thanks,
Jon
Old 05-21-2002, 05:30 AM   #2106
Default Setup help
Hi all,
I'm driving an Mission (and axis2 raincar) too.
I have a big race coming on a high speed big scale circuit with mainly turns with a radius of 2-3 meter/yards. I need advice with the camberlink settings!!! How do I need to setup my car ???
For a picture of the racetrack look at http://www.evmc.nl/index-eng.html under the racetrack button
Thanks in advance Sandor
Sandor is offline   Reply With Quote
Old 05-21-2002, 07:53 AM   #2107
Regional Moderator
Darkseid's Avatar
Had a pretty good race weekend. Finished forth in the A-main at both the short track and big track. Even though the computer screwed up and showed me as 6th and a lap down at the big track. Thankfully, everyone actually in the race, knew where we finished. Man did the TC3 and XXX-S guys go through a lot of parts on Sunday. The carnage was amazing!
I think I finally found a set up that I can use at both tracks. So I don't have to completely change my set up between 11pm Sat. and 7am Sun.!
I've noticed that my front diff builds up an enormous amount of black material on the face of the pulley teeth that actually engage the belt. Without gently cleaning off the pulley faces with a X-acto blade, my drivetrain developed the now well known "high spot" as I rotate it without the pinion engaged. This is the only thing I can think that is causing this "high spot". After cleaning the diff faces, the problem went away.
Anyway...all in all, a good weekend for the Mission.
TLR 22...Tamiya F104...
Old 05-21-2002, 12:36 PM   #2108
Ian S's Avatar
darkseid- i found the same thing, when racing on carpet i would get a lot of fuzz on the rear belt and diff pully making a very noticeable high spot. After cleaning it felt a lot freer. I think it makes more difference on the rear than the front because of the rear belt being so tight and the front being loose.
Ian S is offline   Reply With Quote
Old 05-21-2002, 12:39 PM   #2109
rcfiend's Avatar
Trader Rating: 26 (100%+)
Does anyone know if there is a hobby store in the southern california area that sells the Schumacher. I've tried ultimate hobbies for the last 3 weeks and they haven't had one. I currently drive the Losi XXX-s and I wanted to compare the two. Any former Losi drivers here?
rcfiend is offline   Reply With Quote
Old 05-21-2002, 01:10 PM   #2110
Regional Moderator
Darkseid's Avatar
Ian S: I race on asphalt. I'm not getting anything at all on the rear belt or rear pulley. Just the front pulley.
Old 05-21-2002, 01:14 PM   #2111
Racer X's Avatar
RCFiend: SpeedTech RC sells it and stocks all the parts. I want to say they are around Diamond Bar (it's been awhile since I lived in So Cal), but they are a sponsor of this board (and have their own thread) and have a website you can go to to find the address. Schumacher will also have a display (I believe) at the Reedy Race this weekend...If nothing else, come by and I'll show you my car.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 05-21-2002, 01:21 PM   #2112
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Sandor,
Try the setup in the manual on the left side with the red/blue springs. It works well as a good starting point for asphalt tracks. With all of those sweeping turns in your track I think you won't have any problems.
BigDogRacing is offline   Reply With Quote
Old 05-21-2002, 01:33 PM   #2113
rcfiend, I have been running a Losi off and on for quite some time. I recently switched to the Mission. The biggest differences I felt were acceleration, corner speed, steering, and endless tuning options. I found the Mission to be far more superior in these areas. I race on carpet with foams and it is extremely hard to be fast on a competitive level. The Mission is extremely fast in stock and of course in modified.
It's a great car and if it is in your budget give it a shot. I am sure you will not be disappointed.
Give Adrian a call at Schumacher and I am sure he can direct to a dealer. He will get you in a car!
Rob Love (Ohio)
Old 05-21-2002, 01:36 PM   #2114
cornerspeed's Avatar
I would like to add the Mission is more durable.
cornerspeed is offline   Reply With Quote
Old 05-21-2002, 03:19 PM   #2115
rcfiend's Avatar
Racer X:
Thanks for the input, Speed Tech is unavailable until after the Reedy Race. I wanted to try and get one for the Reedy Race. I also heard that a distributor was available in San Diego. What's your name, I'll definetly stop by and check out your car. There's a guy at So Cal who runs a mission in mod and he's pretty fast with it.
RB Love:
Do you honestly feel that the Schumacher has more corner steering than the Losi? The only reservation I have about purchasing a Mission, is the parts are a little more expensive than the Losi, is this true.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
