Old 08-14-2007, 12:24 PM   #21121
mo
mo's Avatar
If he would just get the right pistons and finish putting my setup on, which is basically Randy's from the Reedy w/o the underdrive pully, then he could get back on the lead lap.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 08-14-2007, 12:25 PM   #21122
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by mo View Post
If he would just get the right pistons and put my setup on, which is basically Randy's from the Reedy w/o the underdrive pully, then he could get back on the lead lap.
until then...........he's just a failure
STLNLST is offline   Reply With Quote
Old 08-14-2007, 02:51 PM   #21123
PW
PW's Avatar
Send a message via AIM to PW
TOASTY
PW is offline   Reply With Quote
Old 08-14-2007, 03:20 PM   #21124
Randy Caster's Avatar
Trader Rating: 46 (100%+)
What he's describing about the car kinda sounds like my setup minus the overdrive.. I'm messing around with 3 hole piston setups now though Mo, you'd be proud!
Old 08-14-2007, 05:01 PM   #21125
couple questions
what do u hve to do to the tamiya 415 one way pulley to fit the schuie one way or spool?
what size are schuie turn buckles? ie 3mm 4mm 3.5mm? as in wrench size? cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 08-14-2007, 05:08 PM   #21126
Trader Rating: 56 (100%+)
Default Shumacher MI2EC VS Cyclone
I just picked up a nice Schumacher EC with a bunch of parts as well as a HB Cyclone. Now, the Cyclone needs about $100 worth of parts after further inspection to get it back into it's prime. The Scuie does not, it's just needs a basic rebuild/chassis prep.
Now the question is what is a better beginner touring car to race in stock class? Parts support for both are similar, so thats not a big deal and most of the folks here run Xrays. I figure either I gotta suck it up and spend $100 on parts for the Cyclone and rebuild it, or sell it and buy more tires for the Shumacher.
I am planning to run either one on a 13.5R brushless and a orion 4800 lipo if that helps
Any ideas?
dynamic_e is offline   Reply With Quote
Old 08-14-2007, 06:41 PM   #21127
Trader Rating: 15 (100%+)
Default failure
Clint no comments from someone who cant finish higher than next to last at a national.and is slowest on team tc5.And since your main goalis shit talking i will wad that thunder tiger up when i lap you.
I dont have the pulley but i think maybe i will go to stiffer front springs .I have tamiya whites and yellows .
AARON YOUNG is offline   Reply With Quote
Old 08-14-2007, 08:20 PM   #21128
The pulley makes the difference between that setup working or not in my opinion..
Old 08-14-2007, 08:32 PM   #21129
PW
PW's Avatar
If you guys get a chance, try the EC arms on the Mi3. You will need to modify swaybar mounting, but it seems to give more overall traction (this is for med/low-bite asphalt)
I mounted the front bar just like the old car, but used the front bumper screws to hold the bar mounts.
The rear bar will mount just like the Mi3 and you will need to drill holes in the arms for the ball-studs.
Old 08-14-2007, 08:44 PM   #21130
I just switched out the center steering mounts for about two hours and moved the mounting point forward and backwards and could only come up with about three degrees difference in akerman.Does anyone know what combo gives the least akerman effect? Also i think a big change was going to brushless ..The powerband feels different and have to dial in more brakes.
Old 08-14-2007, 09:13 PM   #21131
mo
mo's Avatar
I'm not running the underdrive pulley. The only time I ran it was the main at the nats. It made my car go from super spinout to push.
Old 08-14-2007, 09:16 PM   #21132
STLNLST's Avatar
I do recall stating that you get your problem solved so that we have a threat in stock this weekend....or did I not say that. Man...you sure are touchy now that you are a father.....ha ha ha ha Leave the mod to me and you will always be the king of stock.
Use Mo while you have him before he goes dirt for the winter.
Old 08-14-2007, 09:20 PM   #21133
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
A little more flex to generate more grip?
Jon Kerr is offline   Reply With Quote
Old 08-14-2007, 10:13 PM   #21134
JayBee's Avatar
Trader Rating: 31 (100%+)
Has anyone run the Checkpoint Money motor in the car yet? What was your brush/spring combo & FDR for a medium, tight high-grip track?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-15-2007, 05:16 AM   #21135
PW
PW's Avatar
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
