Old 08-13-2007, 12:55 PM   #21106
skypilot's Avatar
Trader Rating: 14 (100%+)
GREAT showing by the Mi3 yesterday here in the NW. it was our Biggest annual outdoor race of the year, our "SUMMER SIZZLER". the Mi3 TQ'd MOD, 19t, and 13.5 brushless.
skypilot is offline   Reply With Quote
Old 08-13-2007, 12:59 PM   #21107
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Originally Posted by PW View Post
Sup everyone...Just checking in on my lunch break
BTW...Moving sucks, but it's going to be worth it (apt to house)
You have no idea man. I am so happy now that we bought our first house. Yeah it sucks being broke, but I don't have to fight for a parking spot anymore, Listen to somebodies loud music, the neighbors fighting, I could go on and on. I do kinda miss the neighbor fighting thing though. It was always cheap entertainment.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 08-13-2007, 01:01 PM   #21108
Great Job. Thats Awesome.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 08-13-2007, 05:58 PM   #21109
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Where is JConcepts anyway?
Old 08-13-2007, 07:42 PM   #21110
Trader Rating: 18 (100%+)
Don't forget your commanding victory in 13.5
No question, the Mi3 is an awesome racecar
RT76 is offline   Reply With Quote
Old 08-13-2007, 09:22 PM   #21111
Trader Rating: 15 (100%+)
Default steering
Has anyone tried all the different steering center mounts. from the wide to the short..any info.Im having a little problem getting the kind of steering i want out of the car.It pushes all the way to the middle then soon as power is applied it gets loose.I started with randys setup then went to 2 deg blocks and a few other things and it didnt seem to help.
AARON YOUNG is offline   Reply With Quote
Old 08-13-2007, 09:24 PM   #21112
Super Moderator
Marcos.J's Avatar
Trader Rating: 167 (100%+)
try PW's reedy set up
Old 08-13-2007, 09:25 PM   #21113
STLNLST's Avatar
Trader Rating: 19 (100%+)
better get it under control in time for Sunday. We gotta win every class we sign up for. Mod and 19 turn are taken care of but we need another ringer in stock. Harsh may need some help.
STLNLST is offline   Reply With Quote
Old 08-13-2007, 09:38 PM   #21114
mini-dub's Avatar
Trader Rating: 16 (100%+)
Dont know about the other steering mounts, I never tried them. If my car were like that I might try standing up your front shocks, leaning in rear shocks, lighter oil all the way around, thinner rear bar, lowering outer rear camber link, or more front droop.
mini-dub is offline   Reply With Quote
Old 08-13-2007, 09:57 PM   #21115
Default already did
I tried the front shocks all the way out and rears all the way down with no swaybar in front.also tried kickup and pro squat.I will put on pws setup for some practice.Iam maxed out on dual rate also i would like to be able to dial some in or out if i need to.
Old 08-13-2007, 10:09 PM   #21116
sounds like i did a similar set up with my mi2 not to long ago no steering but setting all aimed at more steering?
might be to over gripped in the front causing to much weight transfer to front their for over loading the tires
maybe try going the other way get some more rear weight transfer ie stiffer front. this happended to me and a mate told me just try this and it worked car was better.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 08-13-2007, 10:44 PM   #21117
justin lessard's Avatar
Send a message via AIM to justin lessard
Running to much dual rate can make the rear end loose on exit...sounds to me like what steering you do have is coming from the front of the car....If the duel rate is at 100% try running it at 65-70% and freeing up the rear to get more rotation.
justin lessard is offline   Reply With Quote
Old 08-14-2007, 05:28 AM   #21118
Aaron the setup I have posted on the page back works great for me running stock. For outdoors I go one softer front sway bar, spool and go with 2 to 2.5 front droop. In the rear change to 2 degree toe and I start out with 1.5 of camber on the rear. I set my left to right throw on my steering so that the wheels don't chatter with the spool. It ends up being around 60% each side. And I run around 70% dual rate. If you get a chance try the setup.
Steve Walter
Old 08-14-2007, 05:41 AM   #21119
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
If anyone is looking for a car I have my car and parts up for sale in the for sale forum.
Aaron....have you tried more castor and making the rear link longer like the outside on the hub and lower the inside ball stud more. MY car did the same thing and this was one of the changes that I made and it helped.....this was on carpet with rubber tires.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-14-2007, 10:22 AM   #21120
Did you use the overdrive front pulley?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
