Old 07-31-2007, 05:13 PM   #21001
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Originally Posted by Randy Caster View Post
So whats the hot body for foam on carpet.. DNA?
Randy-Go with the lightweight DNA, its .025 thick so it won't explode on impact lmao
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-31-2007, 06:07 PM   #21002
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Between the mohawk and the DNA which is more aggressive?
Old 07-31-2007, 06:09 PM   #21003
Also, what setup are you guys running for Parma tires? I'm going to start building my kit in a couple days..
Old 07-31-2007, 06:13 PM   #21004
Mr. McGoo's Avatar
The DNA is more aggressive. I have found that it makes the car a little twitchier, but still plenty stable. You won't see too many DNA's in stock, but plenty of people run the DNA in mod b/c of the downforce it produces.
As for the Parma PRO53's - Goetz's setup in the manual has seemed to work pretty darn good for me. I am running on a low bite large track and I have had alot of luck with his base setup.
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 07-31-2007, 06:15 PM   #21005
I was hoping you'd say the Mohawk was more aggressive, I didn't think the DNA was aggressive enough when I ran it, lol.
I'll just build it to Goetz's setup unless he wants to chime in with some much needed changes
Old 07-31-2007, 06:26 PM   #21006
Mr. McGoo's Avatar
lol....One thing I know he has been playing with, and that I really liked (for what its worth) was raising my roll center 1mm all the way around. It really settled the car down for me and made it so much easier to drive. (2mm shims in back, and 1mm shims in front)
I also have changed the track rod back to the stock setting - the one he called for didn't give enough exit steering for my tastes. The wider track rod helped with my low bite situation....
I tried going softer in shock oil, but it made the car too soft - seemed to roll a little too much.
Old 07-31-2007, 06:36 PM   #21007
RBLove's Avatar
Trader Rating: 71 (100%+)
The DNA is aggressive, but provides a lot of traction and stability throughout the entire track. Probably the best all around body for carpet/foam (especially in modified)
The Mohawk seems a little more on edge to me. I think it frees the rear end of the car up more than the DNA. Perfect for stock racing. The DNA is more planted, but provides awesome steering throughout the entire turn.
Parma Alfa is a good option also. You probably need to get one of each and start testing now.
Don't forget Goetz's set up is for stock and 19 turn. Stock set ups almost never work for modified and vice versa.
RBLove is offline   Reply With Quote
Old 07-31-2007, 07:08 PM   #21008
Regional Moderator
Darkseid's Avatar
Originally Posted by RBLove View Post
Darkseid,
I think the stiff/wide/carpet top deck is needed more than the thicker chassis. Tracks these days are not producing the amount of grip we experienced a few years ago (except for CEFX Raceway).
Goetz can probably give better advice as he is the carpet specialist for this car, but save yourself a couple of bucks and try the stiff top deck first.
Is part number U3246 2.5mm Upper deck what I should be looking for?
TLR 22...Tamiya F104...
Old 07-31-2007, 07:13 PM   #21009
RBLove's Avatar
U3148 CF Topdeck Stiff - mi3
I am not a Schuie guy, but I believe this is what you need.
Old 07-31-2007, 07:24 PM   #21010
PW
PW's Avatar
Send a message via AIM to PW
That is the foam topdeck and will give you a very stiff car. The U3148 stiff topdeck still allows flex for rubber tire racing.
PW is offline   Reply With Quote
Old 07-31-2007, 07:54 PM   #21011
Regional Moderator
Darkseid's Avatar
Thats what I'm looking for then. The top deck for foam.
No carpet rubber for me this winter. After running foam for most of the winter, I ran rubber a little toward the end of last year, but found myself missing the foams. So this time I'll do all my rubber tire racing during the summer outside on asphalt.
Thanks guys.
Old 07-31-2007, 08:01 PM   #21012
PW
PW's Avatar
Thanks guys.
Sounds good!
Old 07-31-2007, 10:12 PM   #21013
I definately liked the DNA more than the Alfa last year, but will have to get a Mohawk to try out with the DNA.
Old 07-31-2007, 10:17 PM   #21014
POUNDITRACING's Avatar
sounds like I'm going to be bussy randy.
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 07-31-2007, 10:50 PM   #21015
lol, I was gonna give you a call tomorrow, but it looks like you already know.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
