Old 07-27-2007, 08:37 PM   #20956
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I was told by a birdie that xray 1* rear hubs will work on the Mi3. Has any one done the testing/math to determine the shims are required to bring the ball on the xray hub up to the stock height or up to the same height as the 1* shui hubs? I also jsut realized, for anyone else wanting to run an xray 1* rear hub, te outer hinge pin dia on te xray is smaller than the schui. I am guessing the xray is 3 mm pin while the schui is a 1/8th inch pin. Nothing my dremel and a stock motor bushing reamer won't fix .
Old 07-27-2007, 09:53 PM   #20957
adamge's Avatar
Run those foams right down to the glue!
I don't have an Mi3, but can't you just back off the bottom ball cup? I sometimes have to do this on my xray with near-glue foams.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 07-27-2007, 11:05 PM   #20958
adamge, thats what I was talking about. Just checking to make sure I wasn't missing something. I am jsut going to run them at 63 mm and see if I have any problems. If I do have problems Ill be sure to let y'all know.
AWD
Old 07-27-2007, 11:16 PM   #20959
Mr. McGoo's Avatar
AWD
go to bed!!!
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 07-27-2007, 11:59 PM   #20960
Randy Caster's Avatar
Trader Rating: 46 (100%+)
AWD
You can get the lowered shock towers to solve the problem. Lengthen your shocks too much and you'll bottom out the piston on the bladder..
Old 07-28-2007, 01:52 AM   #20961
Originally Posted by Mr. McGoo View Post
go to bed!!!
make me!
. . .besides . . .when else am I going to spray a one color wonder, set up my car for practice before racing tomorrow, eat, and pack up my stuf for the morning??? Sheesh!
Thanks for the reminder about the bladder Randy. I have it on good faith from another racer that the top of the shaft just touches the bladder at 63 mm. If I need any more droop , I'll just throw the lowered tower on there.
-Marc, Which end of the car were you having trouble getting down to ride height with Thursday? Was that with or without the lowered tower on that end?
Old 07-28-2007, 02:23 AM   #20962
anyone tried the new 2 piece top deck?
Barger is offline   Reply With Quote
Old 07-28-2007, 03:00 AM   #20963
yes i have tried the new two piece top deck, first of all it tweaked my car and the handling of the car was just all over the place so i went back to the stock one.
jordan.norwood@ is offline   Reply With Quote
Old 07-28-2007, 11:57 AM   #20964
mutley001's Avatar
Originally Posted by mutley001 View Post
Has any one got a good one way setup for the mi3 for rubber tyre carpet they could help me with please.
Cheers
Paul
Anyone? Or does everyone run the spool on carpet?
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 07-28-2007, 02:18 PM   #20965
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
i believe jeff jenkins ran a spool in carpet(with a corally) with foams send him a pm
Old 07-28-2007, 02:54 PM   #20966
mutley001's Avatar
Thanks Marcos but i'm after a one way setup for rubber tyre on carpet.
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 07-28-2007, 05:23 PM   #20967
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Just got back from my first day on the MI3, fairly productive. Car was very good in a medium bite situation towards the end of the day, made a ferw changes to suit me better for the Goetz setup. I am running 0 degree hubs, and .5 degrees of toe in on the rear arms. Softened the oil in the rear to 20 wt, moved the shocks out on the towers one hole front and rear. Car seemed to free up a little and gave really good initial steering.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-28-2007, 05:24 PM   #20968
Super Moderator
Marcos.J's Avatar
Paul
my bad i didnt read it completely
Old 07-28-2007, 08:14 PM   #20969
Checking for understanding herer . . .
You ran 0* stock plastic rear hubs, and ran a total of .5* of rear toe in? Would you mind sharing how many spacers front and rear you were using to attain .5*? Were you running the parma dubs?
Sorry for all the questions, jsut trying to get some knowledge in my head.
AWD
Old 07-29-2007, 10:49 AM   #20970
Moderator
Andrew-I'll check the car when I get home today from work
SMC Racing
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
