Old 07-26-2007, 03:11 PM   #20941
Originally Posted by PW View Post
Replacment CVD "axles" are now in stock along with most other parts for the Mi3
PW - what is the part number for the new cvd/axle pin?
DOTMAN is offline   Reply With Quote
Old 07-26-2007, 03:51 PM   #20942
Customworksking's Avatar
Trader Rating: 73 (100%+)
Originally Posted by StephenSobottka View Post
I will be getting my Schuie on the rug with foams this saturday for some testing...Goetz and I will start trying to get everyone prepped for Vegas!
Don't forget us rubber tire guy's ...also what do u guy's think the mi3 is the best 19 turn or stock ...I am running both my xray in 1 class and the mi3 in the other
Customworksking is offline   Reply With Quote
Old 07-26-2007, 04:19 PM   #20943
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Be much easier to just run the Mi3 in both classes and switch the motor out. 2 different cars means 2 different setups and 2 different feelings, gonna make it harder at the beginning of your run when your getting settled into the car.. Not to mention, Weylin smoked everyone last year in 19 turn rubber with basically the same suspension, now we just have a lot more adjustability and a car thats much easier to work on than the Mi2.
Old 07-26-2007, 05:59 PM   #20944
PW
PW's Avatar
Send a message via AIM to PW
U3234 single axle
U3026 single pin, grub screw, and barrel
PW is offline   Reply With Quote
Old 07-26-2007, 06:37 PM   #20945
Regional Moderator
Darkseid's Avatar
Originally Posted by Jon Kerr View Post
Try limiting your droop all around by 1mm. How much droop are you running right now? You do want some body roll and how much is kind of a personal preference. I don't like my car to roll over a whole lot, but you watch Randy's car around the track and it rolls like crazy. But that's how he likes it and he's fast with it.
Right now, I running everything dead on with the PW asphalt set up. Droop and all.
I'll try limiting the droop next time out to see how I like it.
TLR 22...Tamiya F104...
Old 07-27-2007, 08:49 AM   #20946
Mr. McGoo's Avatar
took the Mi3 out on foams for the first time yesterday - all I can say is that within 2 battery packs I was going just as fast as I was with my previous car. the track I am running it is a low bite LARGE flowing track with a couple of switch backs
I used Goetz's kit setup but started out with lowered shock oil all the way around 40/20. The felt easy to drive, but still had some push in it.
I then raised up my rollcenter's 1mm all the way around - that helped A TON!!
The car still felt sluggish. It didn't "pop" out of the corners. I had to slow down too much in order to get around the corners. I was still running fast, but it wasn't there.
A fellow teammate was running the stock track rod, so i changed out the track rod the setup called for and threw on the stock track rod, and that definitely felt like it gave me a more responsive steering - which is what i needed.
It was time to leave the track after doing all of that - but I did drive my fellow teammates car. He basically was running the same setup I had went to, but had 50/40 shock oil, he had the 1 degree rear hubs (i didn't), thin sway bar up front, shorter "stock" track rod moved forward two holes, and his front shocks on the arm were on the outside hole.
I was able to go consistently faster with his car than with mine. I am thinking my lower weight shock oil is a major factor, and possibly the shorter track rod.
All in all - I was VERY happy with my first day out on foams. I will update again after tomorrow's racing.
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 07-27-2007, 09:36 AM   #20947
mutley001's Avatar
Has any one got a good one way setup for the mi3 for rubber tyre carpet they could help me with please.
Cheers
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 07-27-2007, 09:39 AM   #20948
Regional Moderator
Darkseid's Avatar
Starting to turn my thoughts slightly to our indoor season. So I was wondering what people are doing with the spool up front while running carpet foam?
Is it what you want to run, or is a diff up front a better call?
Old 07-27-2007, 09:40 AM   #20949
Super Moderator
Marcos.J's Avatar
Trader Rating: 179 (100%+)
diff
Old 07-27-2007, 10:13 AM   #20950
U3234 single axle
Thanks, Paul
Old 07-27-2007, 10:31 AM   #20951
Wink
now that u say that you right......U think if I get it running good in 19t it will be as good in stock....I allways wanted to try 19 and stock w/the same car..
Old 07-27-2007, 10:34 AM   #20952
Regional Moderator
Darkseid's Avatar
Originally Posted by Marcos.J View Post
diff
Thanks Marcos
Old 07-27-2007, 10:54 AM   #20953
90% of the time if it works good in the faster class it will be super dialed in the slower class..
Old 07-27-2007, 06:54 PM   #20954
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
As long as I have enough threads in the ball cup at the ends of my shocks, is there any reason I wouldn't want to lengthen my shocks? I ran them all at 62 mm with the standard shock towers, 3 mm of shims for the roll centers, stock chassis, 54 mm foams, and Xray white springs and I found my shock length was limiting my droop, not the screws. I only needed about 1 mm more length in the shock to reach. Or am I just crazy to run small tires like that and Im going to hear "run bigger tires"?
Old 07-27-2007, 07:33 PM   #20955
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
I run my shock at 63mm front and rear,droop 10mm front and rear for rubber,the car is perfect!
James khoo is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
