Old 07-25-2007, 11:24 PM   #20926
Trader Rating: 71 (100%+)
Those are Losi JRXS Type R ball cups.
RBLove is offline   Reply With Quote
Old 07-25-2007, 11:26 PM   #20927
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Aahhh, you should know, I got those out of your spare parts box!!!
Sigearhead is offline   Reply With Quote
Old 07-25-2007, 11:36 PM   #20928
adamge's Avatar
Sigear, your camera is focusing too far away. You need to set it to macro mode to tell it to focus on the nearest objects. On a most digital cameras, macro mode is indicated by a flower icon.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 07-25-2007, 11:49 PM   #20929
Sigearhead's Avatar
Yeah, I hear you. I took those pics back in May when I first got the car and took a bunch of them in a hurry to show a buddy. I figure they were good enough to show what I was talking about though.
If you need clearer pics I can take some but you'll have to wait til tomorrow. I'm about headed to the sack.
Old 07-26-2007, 12:03 AM   #20930
Korey Harbke's Avatar
Originally Posted by andrewdoherty View Post
I'll fess up . . .Im the fellow Mi3. I had RPM ball cups on at the track today and was only able to clear 1 mm of shims without any rubbing (1.5 mm rubbed just a tick as evidenced by the tiny shaved section on top of the cup.) I got home tonight and threw on the ball grippas on the outside of the turn buckles and while they are thinner I am still left wondering how 3 mm of shims made it under the wheel. I am runnig the stock rear hubs, parma magentas, stock turnbuckles and had seaballs foam setup on the car. The only thing I can imagine is if there are different height ball studs included in the kit and I happen to have the tall ball studs in the rear hub. (I do realize there are 2 different lengths to the threaded sections, but I didn't notice any short or long "necks" on any of the ball studs.)
I know I'm not a schuie guy... but are you running the new parma pro 53 line of tires? They have a bigger rim... you can fit more shims under the ballstud with these tires on the car most likely. Thats what Goetz was running most like as he was one of the key people helping in the development of the new wheel.
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-26-2007, 12:13 AM   #20931
-Korey
You're right Korey. I forgot all about that. So if you're not running the Pro 53's Sigearheads solution will work, BUT Chris' setup is not going to be the same with jaco's or bsr's. You may have to run a slightly lower roll center to get the same effect.
Old 07-26-2007, 12:48 AM   #20932
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You could always just cut the top off of the stock ballcups to give it the same effect as well. Probably wont be quite as strong, but I've never broken one that I've cut like that..
Old 07-26-2007, 05:46 AM   #20933
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Thats exactly what I did Randy
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-26-2007, 07:00 AM   #20934
PW
PW's Avatar
Send a message via AIM to PW
Sup guys...Everyone is missing one key point on seaball's setup; the optional 1 deg rear hubs The optional hubs (U2741) are not as tall and require shims to get it back to standard height.
PW is offline   Reply With Quote
Old 07-26-2007, 08:31 AM   #20935
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
indeed. i got so many pm's about this, that i assumed the manual was printed wrong! however, it is not. if you use the 1* optional hubs (u2741), as pw mentioned, the 3mm shim will fit well, and will give about a 1mm gap when used with a pro-53 wheel and standard balls/cups.
the kit setup has been great for the few locals that have put the car down. i think the r/c's could be a bit higher with the pro-53's as they induce more body roll. i like 8.5mm from the bottom of the chassis f/r with these tires (assuming 4-4.5mm r/h and reasonable tire diameter)
for you ladies running in low bite to prep for vegas, try using lighter oil. the kit seals are tight (not sticky, just tight) and they really make the overall dampening feel heavy. keep them lubed with oil in the cartridge as well. if overdamped, you won't feel the effect of spring changes like you should.
last footnote for now: the kit setup was developed with irs 33# fronts (blk), and xray 17# rears (wht). those of you using xray springs, be aware that most of them are 1.5 - 2lb softer than rated. you'll need the bright red up front to duplicate the irs black. the next step softer than the kit would be xray 33# fronts (plum), and schu 16# rear (wht), which might be a good combination on low bite.
good to see some foam tire activity here.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-26-2007, 09:03 AM   #20936
b-man777's Avatar
Default schumacher cars and team
hey all:Was woundering who's on the schumacher team at this time and whitch team drivers will be at the '07 iic race?Also can someone clear up the rumors of schumacher getting back into the off road electic 2wd and 4wd buggy scene?Thanks for the info
b-man777 is offline   Reply With Quote
Old 07-26-2007, 09:20 AM   #20937
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Boy, you guys all rock. Just what I needed to read before I head out to the track.
I was runnig the "old" parmas with the RPM's so Ill have to cut em down like stevie said.
peace
Old 07-26-2007, 12:58 PM   #20938
PW
PW's Avatar
Replacment CVD "axles" are now in stock along with most other parts for the Mi3
Old 07-26-2007, 01:03 PM   #20939
Tim Kowal's Avatar
PW, I bet you have been a busy little elf, sending out all the care packages today, since that "huge" order of spares arrived in today! I will thank you in advance for mine! Can't wait for the good ol' UPS Man tomorrow!
Tim Kowal is offline   Reply With Quote
Old 07-26-2007, 02:31 PM   #20940
Moderator
I will be getting my Schuie on the rug with foams this saturday for some testing...Goetz and I will start trying to get everyone prepped for Vegas!
SMC Racing
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
