Old 07-23-2007, 08:16 PM   #20911
Default Thanks
Just wanted to give mad props to Favian AKA Sigearhead. He was very helpful with setups and probably one of the nicest people I've met on the boards. Thanks again!
jstikes is offline   Reply With Quote
Old 07-23-2007, 08:31 PM   #20912
Customworksking's Avatar
Trader Rating: 73 (100%+)
Default iic
1 iic lid done 4 more to go speed 6 and mazda 6
Customworksking is offline   Reply With Quote
Old 07-25-2007, 03:28 AM   #20913
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
ttt
Old 07-25-2007, 01:44 PM   #20914
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Schumacher team drivers- of late, some of you have gone to the short/med rod, versus the stock long/med or med/med rods...why and what changes have the cars produced using the short/med rod?
Also, check out this video of an Mi2 w/ 3S Lipo and mod motor being speed tested and trying to pass real cars in Europe...
http://www.youtube.com/watch?v=lC5cc...elated&search=
Is that you, Ashton?
yyhayyim is offline   Reply With Quote
Old 07-25-2007, 03:57 PM   #20915
mo
mo's Avatar
Running the short steering link and moving it forward 2 holes to even out the tie-rods makes the steering more linear and smooths the car out.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 07-25-2007, 04:03 PM   #20916
yyhayyim's Avatar
but is the steering faster/sharper?
Old 07-25-2007, 05:32 PM   #20917
Regional Moderator
Darkseid's Avatar
I haven't reported in for a while, well because I've mainly been running Mini and nitro. But I got the Mi3 back out for the first time in a while. It was still running good, didn't have any lack of steering, and the car generally felt very good.
Only thing I'm looking for at this point is to minimize the body roll I seem to be getting. I've got thicker sway bars, but I'm worried that running those or trying stiffer springs will cost me traction on asphalt.
TLR 22...Tamiya F104...
Old 07-25-2007, 05:52 PM   #20918
hey guys whats your opinions on the integy set up station 2?
the one available in multiple colors?
im trying to save money and just wondering if its compareable to the hudy system except is doesnt have tweak or ride height gauges etc.
any opinions would be appreciated
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 07-25-2007, 06:04 PM   #20919
I have one. The only thing I use it for is to set camber and set my front toe. Check my rear toe sometimes. Speedmind makes a really nice one for the same price.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-25-2007, 08:42 PM   #20920
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Try limiting your droop all around by 1mm. How much droop are you running right now? You do want some body roll and how much is kind of a personal preference. I don't like my car to roll over a whole lot, but you watch Randy's car around the track and it rolls like crazy. But that's how he likes it and he's fast with it.
Jon Kerr is offline   Reply With Quote
Old 07-25-2007, 10:10 PM   #20921
Mr. McGoo's Avatar
quick question - Seaball's foam setup in the manual calls for 3mm shims on the rear hub - has anyone else tried this and made it under the wheel - a fellow Mi3 made it to the track today and was only able to get 1.5mm of shims in there....
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 07-25-2007, 10:22 PM   #20922
RBLove's Avatar
Trader Rating: 72 (100%+)
He is probably not running the Schuie ballcup, but something more along the lines of the X-Ray style (open with the swivel ball). Also check to see what ballstud he is running. If he is running a shorter ballstud you will not get the same effect as you would be much higher. I would definitely recommend trying his setup as he is flat dialed on the rug these days.
Sigearhead would know. You out there Fave?
RBLove is offline   Reply With Quote
Old 07-25-2007, 10:56 PM   #20923
I'll fess up . . .Im the fellow Mi3. I had RPM ball cups on at the track today and was only able to clear 1 mm of shims without any rubbing (1.5 mm rubbed just a tick as evidenced by the tiny shaved section on top of the cup.) I got home tonight and threw on the ball grippas on the outside of the turn buckles and while they are thinner I am still left wondering how 3 mm of shims made it under the wheel. I am runnig the stock rear hubs, parma magentas, stock turnbuckles and had seaballs foam setup on the car. The only thing I can imagine is if there are different height ball studs included in the kit and I happen to have the tall ball studs in the rear hub. (I do realize there are 2 different lengths to the threaded sections, but I didn't notice any short or long "necks" on any of the ball studs.)
Old 07-25-2007, 11:18 PM   #20924
Sigearhead's Avatar
Trader Rating: 68 (100%+)
I use the Xray style in the back and was able to clear 3mm no problem, any more and it WILL rub.
As you can see in the pic (sorry it's not that clear) I have 3mm with the Xray style cups. I run foam tires and no rubbing.
Sigearhead is offline   Reply With Quote
Old 07-25-2007, 11:21 PM   #20925
Sigearhead's Avatar
As you can see with the tires on it's pretty darn close but it doesn't rub. That's about all you can run without it rubbing though...
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
