Old 07-13-2007, 11:51 PM   #20806
Sigearhead's Avatar
Trader Rating: 68 (100%+)
From running asphalt only sparingly and mostly on carpet it seems like racers on asphalt normally don't run 6 degree caster on asphalt like we do on carpet because when running a spool the car tends to push on corner entry and theoretically less caster is more corner entry and less mid-exit-corner steering where as the more caster is less corner entry and more mid-exit-corner steering. The car with 6 degree blocks is supposed to do what John Kerr said, push on entry and mad steering on mid and exit. From my own experiences though on carpet 6 degrees of caster gives you more overall steering everywhere.
I have seen setups from Xray guys and Corally guys running 3, 2, and even zero caster on asphalt. I would assume that would be guys that drive very hard into the turns and they need that initial turn in more than anything else, hit the breaks and rip it out of the corner.
Sigearhead is offline   Reply With Quote
Old 07-14-2007, 12:14 AM   #20807
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
When running the EC I ran 2 deg castor blocks a lot. Just about everywhere I went the car was better on initial turn-in with 2 deg blocks than with 4. I'm yet to try with the mi3
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 07-14-2007, 12:44 PM   #20808
Send a message via ICQ to Jan Larsen
Got my first asphalt session with the car today...man was that thing planted or what! Could concentrate all my effort into tire/sauce testing. No maintenance required at all. Even the blades looked like new after 9 packs of 3.5 brushless and a stupid amount of speed
Also tested the Vantage 190mm carbon wing cut down to size. Very happy with that, dosen't go out of wack in a roll over like lexan wings do, which can end you a heat DQ. No chance of that with the carbon wing.
Jan Larsen is offline   Reply With Quote
Old 07-15-2007, 01:57 AM   #20809
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
How is anyone able to save an electronic version of THEIR OWN setups using the blank PDF form? I get the stupid "You are not able to save the data you typed in this form. If you would like a copy for your records please print this form out"
I can print them I know, but I don't want to have to cary paper versions in this the digital age! Plus its easier to "share" my set ups with buddies. Any solutions? I am about to make my own set up sheet in excell or word just to have an editable version!
AWD
Old 07-15-2007, 03:43 AM   #20810
bender's Avatar
AWD
You need to install a postscript pdf printer - basically a "virtual" printer that saves your edited file as a pdf rather than printing it out.
Do a google search for "Pdf form filler" or "cute pdf" - both of these are free programs that work well.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 07-15-2007, 05:10 AM   #20811
lol . .I spent all night creating this by hand in excell :0 Oh well. Ill probably finsih it anyway now. Oops. . .I will have to zip it and attach it. RCTECH don't like the file.
Old 07-15-2007, 05:43 AM   #20812
scott_g's Avatar
Exactly what Bender said. Go to www.cutepdf.com and download the free cutepdf program. Then fill in the pdf form using acrobat and "print" through cutepdf to save. Easy, and it works. And it's free...
Old 07-15-2007, 07:16 AM   #20813
perfect guys, thanks
AWD
Old 07-15-2007, 08:59 AM   #20814
Customworksking's Avatar
Trader Rating: 73 (100%+)
Smile body
has anyone tried the new EastCoast bodies yet if so what one ?
Customworksking is offline   Reply With Quote
Old 07-15-2007, 01:52 PM   #20815
Yeh...I tried a Mazda6....In my opinion they are crap!!!!!they are a hard plastic of some sort and very brittle...they split and crack at the smallest impact....I broke the MI3 front shock tower because the body broke in the bonnet area and exposed the tower to the BIKE that was lying on the track.Have heard of simmilar problems from others
Barger is offline   Reply With Quote
Old 07-15-2007, 03:55 PM   #20816
adamge's Avatar
Barger, you are referring to the EastCoast Mazda 6?
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 07-15-2007, 05:46 PM   #20817
yyhayyim's Avatar
Trader Rating: 26 (100%+)
How have the MI3 done at the ROAR nats?
yyhayyim is offline   Reply With Quote
Old 07-15-2007, 05:56 PM   #20818
I think Randy finished 3rd in 19T.
Congrat's Randy
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-15-2007, 06:24 PM   #20819
PW
PW's Avatar
Send a message via AIM to PW
Congrats to Randy for his 3rd place podium finish!!!
PW is offline   Reply With Quote
Old 07-15-2007, 07:09 PM   #20820
Red face caster
congrats to Randy as well 3rd19t and won the B in Mod
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
