Old 07-13-2007, 06:04 AM   #20791
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Thats the plan! I'm hoping to run faster next week with a little improvement on my set up. After all the races I took Steve Marker's Mi3 for a 5 lap spin with his radio etc and ran faster in those five laps with his car than I did all day with mine. By the end of the 3rd lap I felt confident enough to push it 100%. So I'll see if I can get some of that confidence in my car for the Rumble. As for 1/12th . . .I dunno what to do, but I gotta do something if I want to catch Wes, Derek Tim, and McGoo. Maybe Ill run 6 cell!
Old 07-13-2007, 06:14 AM   #20792
Trader Rating: 68 (100%+)
Just kidding dude good luck see you in a couple of weeks.
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 07-13-2007, 07:10 AM   #20793
Trader Rating: 36 (100%+)
Originally Posted by andrewdoherty View Post
Is this the new lipo schumacher is making?
http://www.rctech.net/forum/attachme...hmentid=232367
I am curious if the new lipo will accept a 2C charge rate.
Does the new lipo have a part # at Shumacher yet? If not how does one order?
http://www.racing-cars.com/usa/produ...ecnumber=47387
Should be in stock from what Paul posted in the past but the online store has not been updated.
Nexus is offline   Reply With Quote
Old 07-13-2007, 10:52 AM   #20794
John_S's Avatar
Default need more steering!! in mi2 ec
hey guys i was just wondering if you could help with my setup for my mi2ec as i require more steering. Im racing outdoor asphalt in the uk, doing mainly 19turn. My current setup is.
Front:
ride height: 5
anti roll bar: none
caster: 4
no kickup or anti dive
toe in :0
roll centre: riser +1
camber: -1
wheelbase: med/long
oil:35
spring: schu wihte
piston 3
droop: 4 on gauge
carpet towers used and second hole from outside
outside hole on wishbone
rear:
roll bar: silver
ride height: 5
toe in: std
wheelbase: med/long
oil; 35
spring: schu white
piston 3
droop:3
1mm shim under rear link
carpet towers used and in second hole from outside on tower and wishbone
tires rp30 preglue
mazda speed 6
Thats it guys hope you can help as im dying for steering!
i tryed puttin rubber o rings under the front topdeck screws to create more flex but i felt it made the car inconsistent
John_S is offline   Reply With Quote
Old 07-13-2007, 11:50 AM   #20795
Sigearhead's Avatar
where is the position of your steering hub carrier?
try the inside hole if you don't already have it one that one.
You can raise your rear rollcenter by .5
Go down to 30 wt oil fr/rr
try 3 droop in the front and 4 in the rear
you can always try antidive
I would also try arm sweep
Sigearhead is offline   Reply With Quote
Old 07-13-2007, 12:44 PM   #20796
John_S's Avatar
i have them in inside holes. How do you acheive arm sweep on the mi2? The only way i can see would give crazy amounts of sweep by turning the hinge pin mounts around
Old 07-13-2007, 01:38 PM   #20797
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You can do arm sweep on the EC with the extended pivot blocks. (Dont' have the part number off had.)
For more steering, you could lower your front roll center to just the blocks on the riser plates, or add some anti squat. Also, you're going to think I'm crazy, but put the silver sway bar back on the front. I always lost steering when I took the front bar off. I'd do that first then try lowering the front roll center, and then the anti squat.
Jon Kerr is offline   Reply With Quote
Old 07-13-2007, 02:31 PM   #20798
John_S's Avatar
ok cheers guys thanks for the help how much anti squat would you recomend?
Old 07-13-2007, 02:48 PM   #20799
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
just out of curiosity, why doesn't anyone run 6* castor blocks on asphalt? for foam tires, that's usually the first place we start. castor will add steering unquestionably, and will do it in a manner that offers on-center smoothness. is that not desirable on asphalt?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-13-2007, 03:02 PM   #20800
At our indoor asphalt track I run 4* with a oneway and when I race outdoor asphalt with spool; I always seem to go with a 6*. The steering feels more consistant with 6* and a spool outdoors. I've tried the 6* with the oneway on the indoor asphalt and the car oversteer mid and exit.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-13-2007, 03:25 PM   #20801
Jon Kerr's Avatar
The few times I tried it on the old car, it just felt strange. It made the car fell pushy on entry and then it would try to spin out mid corner. I was thinking about trying it on the Mi3 next time I'm at the track though.
Old 07-13-2007, 06:45 PM   #20802
Skiddins's Avatar
Has anyhone else noticed that when you set the rear toe in according to the manual (every 0.5mm washer is approx 0.6 deg) you actually end up with more than it says
I used the 1 deg rear hubs and removed the 0.5mm washer from the rear pivot block, this should have given me 2.4 deg of rear toe (with the rear 0.5mm washer in place the car should have 2 deg rear toe, remove that then use the hubs, 2 deg - 0.6 deg + 1 deg = 2.4, however, when I used my toe guages I actually have closer to 3.2 deg!
Is there something abvious I'm misreading or will I need to get the gauges out everytime?
I haven't yet used the guages to measure the standard settings.
***Does the kit setup provide 2.4 deg of rear toe?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 07-13-2007, 06:49 PM   #20803
Skiddins's Avatar
Front:
ride height: 5
anti roll bar: none
caster: 4
toe in :0
camber: -1
wheelbase: med/long
oil:35
spring: schu wihte
piston 3
droop: 4 on gauge
rear:
roll bar: silver
ride height: 5
toe in: std
wheelbase: med/long
oil; 35
spring: schu white
piston 3
droop:3
tires rp30 preglue
mazda speed 6
Is your droop measured on a 'stepped' guage, if so, try 4 front and 5 rear.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 07-13-2007, 07:34 PM   #20804
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Skiddins
When you removed the 0.5mm shim at the pivot block(0.5mm=0.6 degree),2.6 degree - 0.6 degree =2 degree.add up 1 degree toe block=3 degree.
Cheers
James khoo is offline   Reply With Quote
Old 07-13-2007, 10:28 PM   #20805
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
on the old car I ran it and i loved it now that you brought it up i will have to try it on the new car anybody have expierience w/ it on the mi3 if so let us know
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
