Old 07-10-2007, 03:09 PM   #20731
Tim Kowal's Avatar
R/C Tech Charter Subscriber
Originally Posted by seaball View Post
it's no wonder pw is seeking higher ground. schumacher will be hard pressed to find someone with half of the qualifications that pw had/has. in the two years working with him, it appeared to me quickly, that he was over qualified given his usual daily routine. for me personally, i hope that he stays close enough to schumacher/on-road that i will continue to have the pleasure of meeting up with him at the national races.
paul - i wish you luck in your next move. may you be used for your talents, and rewarded proportionately.
- bigpwfan -
Are we sure PW is leaving Schumacher? Is this opening his replacement or just additional help in the office?
Tim Kowal is offline   Reply With Quote
Old 07-10-2007, 03:17 PM   #20732
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by yyhayyim View Post
With all due respect JK I really doubt that...I have seen many T2'007 slam inot concrete parking side walls down the straight at full speed over 45mph and over shoot sweepers and hit the side walls...some walked away unharmed with only tweak issues to fix, others have broken a hub, arm, shocks popped off, or bent bulk head- but snapping them off? I have yet to witness such carnage on any car...
Sorry bud, but I saw it with my own two eyes. And it wasn't Harshguy. It was Calvin Simmons at BCR in Orange County. I was turn marshaling and I picked the car up off the track after it happened. Like Darkseid said, just because you've never seen it doesn't mean it's impossible.
On another, more important note. I'm very sorry that Paul has decided to leave Schumacher. He's been a great help to me over the last 3 years and I've learned a ton from him.
Paul, good luck in your new job. I'm sure we'll run into each other at big races sometime.
Jon Kerr is offline   Reply With Quote
Old 07-10-2007, 03:17 PM   #20733
Jon Kerr's Avatar
Yes, we're sure.
Old 07-10-2007, 03:26 PM   #20734
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
its confirmed
Old 07-10-2007, 03:40 PM   #20735
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Whaddafuxup!!!
Why has two of the best minds at SchumacherUSA decided to seek out other places of employment?? First Adrian, now Paul Getting the MI3 was gotten partially because of these two. Who else can I call up at ShuieUSA and talk shop with for 30min+ LOL. Is Shuie doing something wrong here?!
I do know though in the end we all have to do what we've gotta do....
tOo BaD, sOo sAd
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-10-2007, 03:42 PM   #20736
Super Moderator
Marcos.J's Avatar
tOo BaD, sO sAd
maybe is because you call him and bugg him for 30 minutes j/k
im pretty schumacher will still be helpful!! (with paul training the next person) and Im sure PW will still have a MI3 in hand
Old 07-10-2007, 04:31 PM   #20737
PW
PW's Avatar
Send a message via AIM to PW
Thanks guys for all the kind words!
Schumacher is going strong and I can assure you that customer service is still priority #1 with Shawn Palmer running the show
PW is offline   Reply With Quote
Old 07-10-2007, 04:36 PM   #20738
Regional Moderator
Darkseid's Avatar
But...but...but.... who's going to be on here to answer our persistent....non stop....on going....relentless.....repetitive...questions.
TLR 22...Tamiya F104...
Old 07-10-2007, 04:37 PM   #20739
PW
PW's Avatar
Originally Posted by psychosilence View Post
Hi PW, current setup as follows:
Chassis: Std 2mm
Top Deck: Stiff
Front:
Servo Saver: No
Screw block spacers: Front - 1mm Rear - 1,5mm
Wishbone Clips: Front - 2mm Rear - 2mm
Link washers horizontal: 3mm
Anti-roll bar: 1.2mm
Camber: 1,5 Deg
Link washers vertical: 3mm
Pivot block spacers: Front - 1mm Rear - 1mm
Wishbone shock position: outer
Shock bracket: most outer hole
Blue spring & 35 oil
Centre track rod is kit std
Hub has steering link on outer hole
Rear:
Screw block spacers: Front - 1,5mm Rear - 2,5mm
Camber: 1,5 Deg
Link washers vertical: 4mm
Pivot block spacers: Front - 2mm Rear - 2mm
Hub has link on inner hole with a 1mm spacer.
Wishbone shock position: 2nd from outer
White spring & 35 oil
Car feels very twitchy, tail swings out and very loose with 35 tires.
Thanks for the help in advance!
Try harder front tires.
Heaver front oil (5-10wt).
Remove spacer from rear hub.
Lay the shocks in (front and rear) 1 or 2 holes on the tower.
Old 07-10-2007, 04:40 PM   #20740
PW
PW's Avatar
I'm sure I will still be here, but maybe not as nice with my responses No more desk job either so no more rctech during business hours
Old 07-10-2007, 04:46 PM   #20741
Regional Moderator
Darkseid's Avatar
I'll keep that in mind!
Old 07-10-2007, 05:05 PM   #20742
Customworksking's Avatar
Trader Rating: 73 (100%+)
Wink car
what kid of servo saver u guy's running ? I got my car the other day and started mounting everything and wow close fit ..I know theres a pic some where here but i cant find it
Customworksking is offline   Reply With Quote
Old 07-10-2007, 05:44 PM   #20743
Super Moderator
Marcos.J's Avatar
futaba 9550
Old 07-10-2007, 05:47 PM   #20744
Wink sup fu
I ment the saver not the servo...........I have a 9550
Old 07-10-2007, 05:48 PM   #20745
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Damn it I felt my heart drop when I heard about this. It won't be the same without you at Schumacher.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
