Old 07-09-2007, 01:17 PM   #20686
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default MI3 ARMS
ARE THE MI3 ARMS DIFFERENT THAN THE ARMS ON THE EC?
IF SO WILL THEY FIT ON THE EC?
I DON'T REALLY WANT TO MESS WITH CAR TO MUCH. IT'S PRETTY MUCH DIALED FOR STOCK OR 19 TURN.
IT WAS JUST THOUGHT........
RED-LINE M03 is offline   Reply With Quote
Old 07-09-2007, 01:21 PM   #20687
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
they are the same the MI3 arms has another mounting hole for the sway bar mounting since is different from the ec
and if you use the mi3 arms on the mi2 you might not be able to use sway bars
Old 07-09-2007, 01:25 PM   #20688
THANKS SUCKER.............
Old 07-09-2007, 01:29 PM   #20689
Super Moderator
Marcos.J's Avatar
no problem fool give me a call later
Old 07-09-2007, 01:34 PM   #20690
heavy's Avatar
Trader Rating: 20 (100%+)
Also the Mi3 arms are narrower at the outer end where the rear upright mounts - you will loose teh wheelbase adjustment if you use them on your EC.
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 07-09-2007, 01:42 PM   #20691
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
They're a little more reinforced too.
Jon Kerr is offline   Reply With Quote
Old 07-09-2007, 03:38 PM   #20692
Trader Rating: 26 (100%+)
What's the best belts to use on the MI3 for mod (LRP X-11 4.5)? Do they grey belts hold up or are the standard black ones the go?
Cheers Andrew
CountryHick is offline   Reply With Quote
Old 07-09-2007, 04:03 PM   #20693
Jon Kerr's Avatar
Cheers Andrew
Stock black belts
Old 07-09-2007, 04:26 PM   #20694
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Randy Caster View Post
Just got done building my 5 cell car for the Nats, figured it's as clean as it'll ever be so I might as well take a couple pics before it gets packed for the trip to SIR.
Nice ride Randy C-ya when you get here....and bring some of those purple 'buckles
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-09-2007, 04:45 PM   #20695
yyhayyim's Avatar
Originally Posted by Jon Kerr View Post
Stock black belts
my front belt is wearing twice as fast as the rear...why?
yyhayyim is offline   Reply With Quote
Old 07-09-2007, 04:51 PM   #20696
Jon Kerr's Avatar
Make sure your set screw on the pinion can't touch the belt. When the car is running, the belts don't exactly stay in a straight line. They deflect up and down. The front belt can hit the set screw and start to wear away the teeth and make them fray sometimes.
Old 07-09-2007, 07:16 PM   #20697
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I have just enough of the purple turnbuckles to cover my cars unfortunately, I tried to order more but I cleaned Speedtech out lol.
Old 07-09-2007, 07:53 PM   #20698
POUNDITRACING's Avatar
you can count on Randy to have a very hot looking car.
How do the bodies look?
Pound It Paints - http://www.rctech.net/forum/painting-designs-graphics-photography/270707-pound-paints-raymond-ramirez.html
RC Reveled - http://www.teamrcr.net
POUNDITRACING is offline   Reply With Quote
Old 07-09-2007, 09:57 PM   #20699
Lookin good, sorry I forgot to call you about them, been super busy getting the stuff ready for the race this weekend.. Thanks again Ray!
Old 07-10-2007, 02:21 AM   #20700
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Originally Posted by John_S View Post
I got an xray 007 to try untill the mi3 came out to replace my aging mi2 ec. The first problem i had was seized bearings. The second problem i had was 2 broken bulkheads!!! i would have imagined the shock tower to break before the bulkheads at least. All in all i have never had a problem with my mi2 ec exept for the driveshaft pins but this was easily solved with steel driveshafts
ON WHICH CAR DID THE BULKHEADS BREAK
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
