Old 05-13-2002, 07:55 AM   #2056
Default Reedy Race
Are any of you guys going?
Phatz is offline   Reply With Quote
Old 05-13-2002, 08:05 AM   #2057
Regional Moderator
Darkseid's Avatar
I believe Racer X is a regular at the Reedy Race. Since he said below that he is working on a diff set up since the Reedy Race has a no oneway rule, I guess he is going to be attending again this year.
TLR 22...Tamiya F104...
Old 05-13-2002, 02:03 PM   #2058
Send a message via Yahoo to gfoster
hey guys I have seen and heard a lot about the roll center mod for the mission was wondering if you can tell me in detail how it works and what I will need to make it, also does this mod work on the rear of car. you can post here or e-mail me tqfoster@snip.net
thanx guys for info
gfoster is offline   Reply With Quote
Old 05-13-2002, 02:27 PM   #2059
cornerspeed's Avatar
gfoster- The front roll center mod raises the front lower arm inner hinge pin to the same level as the rear. This will add mid and exit steering to the car. If you raise the rear, that will take the steering away. So, if we were to lower the rear, the car would get more steering. Just as the Losi guys are doing.
Two ways of raising the front roll center.
Trim a piece of chassis material for under the steering bellcrank/hinge pin mount and the front pivot block. This raises the front lower hinge pins 2 mm. Then you will have to trim the alloy servo saver tube 2 mm to clear the upper deck and remove the 2 mm plastic washers from the inner steering turnbuckle ball stud( use a short ball stud in its place).
The other way is to get the Fireblade rear alloy toe blocks, 0 and 3 degree. Use the 0 for the rear of the hinge pin and the 3 for the front. The holes in these blocks are offset, so fit them so that the holes are up. You will also have to cut the steering bellcrank/hinge pin mount off. This will maintian the same bellcrank geometry.
Hope this is clear enough. Good luck. It is a fun modification to do.
cornerspeed is offline   Reply With Quote
Old 05-13-2002, 02:37 PM   #2060
To all that are going GOOD LUCK at the Reedy race!
I wish I could go, but I promised the family a trip to Disney World.
Make Schumacher proud! 8)
Old 05-14-2002, 06:57 AM   #2061
OK, Guys I need more steering from the apex of the turns on, I donot need anymore steering going into the turns. The Mission tuning guide is a little too ambigious for me, they tell you what the changes make, but not were on the track the changes happen. Where as my Losi XXX-S manual does, however on some issues the Schuie manual says the changes will do the exact opposite of what the losi does. I will post my current set-up as soon as I get home........
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-14-2002, 01:55 PM   #2062
Racer X's Avatar
Phats: If I had the oneway in, that would be the case, but with the diff, the turn in is what I would rate as 'good'.
Damon: No problem and good luck...
GFoster: Be careful with the front blocks (if you use the Fireblade parts). They can pull through the chassis in a bad crash (just don't have any bad crashes...lol). Other than that, the raised roll center is pretty good. I use the raised plate now, however.
Impact: I'll offer some suggestions once I see your setup...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 05-14-2002, 03:34 PM   #2063
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Hey guys when you make the front roll center mod with the Alum Fire Blade parts you will want to make a little brace that goes over the front two pices so you dont break the front of the chassis in a real hart hit. I will hopefully get some pic's of the brace that I have on my car over the weekend.
And good Luck to all the guys who where able to make it into the Reedy Race, do Schumacher proud and keep the streak alive in Stock well now its 19 turn.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-14-2002, 04:46 PM   #2064
RBLove's Avatar
Trader Rating: 72 (100%+)
Kevin K., Do you have a pic of that front roll center mod with the brace?
Thanks,
Rob Love
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 05-14-2002, 07:40 PM   #2065
nice avatar jonski
wilson10 is offline   Reply With Quote
Old 05-14-2002, 07:46 PM   #2066
Kevin K's Avatar
Rob I will hopefully have it up by the weekend or just after.
Old 05-14-2002, 07:56 PM   #2067
jonski's Avatar
Trader Rating: 233 (99%+)
Default Thanks
Thanks for it Wilson....tried doing my own, but it was too big. I saw yours and just had to have it.
Sorry
jonski is online now   Reply With Quote
Old 05-15-2002, 06:11 AM   #2068
Default My setup
Front
shocks-
55 wht. oil
no. 3 shuie 1 piece piston
gray spring
no. 2 on tower
no. 1 on arm
alloy hub carriers w/ lowball option
no. 1 inner chamber mount (upper)
0 deg. toe
0 deg. inboard toe
1 1/2 deg. chamber
3 on associated droop guage
Rear
shocks-
55 wht. oil
blue spring
no. 2 on tower
no. 1 on arm
3 deg. toe
0 deg. inboard toe
1 1/2 deg. chamber
For front caster I am using Yokomo caster clips which are a little different compared to Schuie units, one full clip and one half clip are the same thickness as 2 schuie full clips. I am using 1 small infront of the mount. I will measure this later once I get my guages out.
Tires-
CRC foams X-hard dual compound fronts (plaid) front
CRC foams X-hard fronts (purples) rear
Trinity Stratus
Fantom MVP
Old 05-15-2002, 12:57 PM   #2069
onaMISSION's Avatar
How do you think the mission is going to do at the worlds? I think they have a great chance of winning
onaMISSION is offline   Reply With Quote
Old 05-15-2002, 04:49 PM   #2070
well if yokomo doesn't hire half the racer in the world to basically run interferrence for a few of their drivers...... or maybe Losi will buy this worlds this year......... IF the drivers with THE BEST cars win we all know who will be celebrating!!!!!!!
.........AND it WON'T be a plastic car!!!!!!!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
