Old 07-09-2007, 08:32 AM   #20671
Tim Kowal's Avatar
R/C Tech Charter Subscriber
Originally Posted by yyhayyim View Post
Not to an Xray...they make sure to make the strongest most realiable parts, like diffs/outdrives, axles, dogbones, pins, arms, etc...parts that are most often prone to break in hard crashes, Xray makes sure that on their cars these are of the highest strength and quality to minimize damage...its something Schumacher and everyone else can learn from. Why should it take HB CYclone 3 versions of their car to finally get some decent strength CVD's, diffs, diff screws? Schumacher got the HD Spool right the first time fo the Mi3, and its very strong and durable...so why not put the same thought and effort into the axles, bones, pins, and every else that needs reinforcements? The Arms on the MI3 are very strong- just as strong and durable as Xray or Yokomo arms. Put so far, I have found that the inner hinge pins are weak, and the bone pins snap pretty easily or keep getting loose, and we the users have to get stuck inprovising on ways to make the parts work, like dremmeling the pins so that the set screws "sit" when tightened and the pins stay in place...Why should we be left modifying parts or make adjustments to them for them to work? These things should be taken care of ASAP by Schumacher, not us....its frustrating- but worse...the cost of having to replace the weak cvd's or bones/pins...ouch!! Same thing goes for other cars, and it really sucks when you have to be shaving off caster blocks, cutting axles, top decks, motor mounts, bulkheads, shocks, etc to get the car to work right...if the cars are made right, none of these head aches would emmerge...Now Schumacher's MI3 is a great car w/ a great design. It just seems that there are little pesky issues in the details of some parts. And that's what we hope to see fixed immediately...its just that for me personally, after driving Xray's for some time, these issues are new to me and messing with parts to ge them to work right was not something I had to do with my old Xray T2's...
I just switched to the MI3 after years with XRAY (since the T1 with pillow ball suspension) and I have to say that Xray has problems also. The blades need replacing after every few runs with a spool, the driveshafts bend and or break in a front end collision, screws pull out of front steering knuckles and rear hubs. So to say an Xray is without teething problems is incorrect. I have yet to break any part on the MI3 that wasn't due to my error, not the manufacture. And I believe it is much easier to deal with Schumacher USA about these small problems than with Xray. Just my .02 cents............
Tim Kowal is offline   Reply With Quote
Old 07-09-2007, 09:34 AM   #20672
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
WORD
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 07-09-2007, 09:42 AM   #20673
100% AGREE I've owned a Schumacher TC for about 14 months now. Service has been great. I haven't had much problem with the cars at all. The only time something breaks is when I hit something. After every weekend of racing you need to do maintence of your race car and check to see if your pins are coming loose. Sometimes you need to check them after every qualifier. Just like every car you own.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-09-2007, 09:59 AM   #20674
John_S's Avatar
I got an xray 007 to try untill the mi3 came out to replace my aging mi2 ec. The first problem i had was seized bearings. The second problem i had was 2 broken bulkheads!!! i would have imagined the shock tower to break before the bulkheads at least. All in all i have never had a problem with my mi2 ec exept for the driveshaft pins but this was easily solved with steel driveshafts
John_S is offline   Reply With Quote
Old 07-09-2007, 10:08 AM   #20675
Static_racing's Avatar
At least Schumacher USA has parts and warranty replacements, Good luck finding parts for the competitions new cars.
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 07-09-2007, 10:13 AM   #20676
Great point Mike. Schumacher has always stepped up with faulty parts. And the only ones has been the CVD's pins. When I bought my Mi2 EC and was breaking pins, Paul sent me the stronger pins. On my Mi3, one of my front cvd pins come loose after every couple runs. You just need to check them. When I owned a Xray they would never send me replacements of faulty parts.
Steve Walter
Old 07-09-2007, 10:18 AM   #20677
Tim Kowal's Avatar
I forgot all about those damn bearings, besides seizing, they ruined the plastic parts they melted which no one had at track, end my day early. That was even after I had lubed them as instructed and only after about 10minutes run time.
Old 07-09-2007, 11:51 AM   #20678
psychosilence's Avatar
Hi PW, current setup as follows:
Chassis: Std 2mm
Top Deck: Stiff
Front:
Servo Saver: No
Screw block spacers: Front - 1mm Rear - 1,5mm
Wishbone Clips: Front - 2mm Rear - 2mm
Link washers horizontal: 3mm
Anti-roll bar: 1.2mm
Camber: 1,5 Deg
Link washers vertical: 3mm
Pivot block spacers: Front - 1mm Rear - 1mm
Wishbone shock position: outer
Shock bracket: most outer hole
Blue spring & 35 oil
Centre track rod is kit std
Hub has steering link on outer hole
Rear:
Screw block spacers: Front - 1,5mm Rear - 2,5mm
Camber: 1,5 Deg
Link washers vertical: 4mm
Pivot block spacers: Front - 2mm Rear - 2mm
Hub has link on inner hole with a 1mm spacer.
Wishbone shock position: 2nd from outer
White spring & 35 oil
Car feels very twitchy, tail swings out and very loose with 35 tires.
Thanks for the help in advance!
psychosilence is offline   Reply With Quote
Old 07-09-2007, 11:52 AM   #20679
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Originally Posted by mitchsterbrau View Post
the CVD's are faulty. i hit nothing at all. normal driving killed it.
no point blaming driver fault, the part is faulty. confirmed here too.
this was an australian purchase......
so we are left with the UK div dealing with it.
sloooooooooooooow mooooooooootion british.
it's been a real bad experience in total after paying so much
and getting no driving time in over a month of purchase.
all i can say is, if you're thinking about buying one. don't.
it's too much to pay for no racing time. the chassis i received is a total blem.
i am left with nothing to use, after selling other chassis to buy it.
? did you build the arm mounts like the book shows. if you didn't the car will end up being like 200mm and the pins will be half way out of the drive cups..
If you go back threw a couple of pages (probly like 25) you'll find other people have done the same thing..
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 07-09-2007, 11:53 AM   #20680
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
The Service that Schumacher & PW provide and excellent and go beyond what most manufactures provide. On top of that PW also is on Tech helping guys out along with other Team Schumacher drivers. If you need help and support Schumacher is an excellent choice.
ST Racing Concepts (STRC)
Old 07-09-2007, 12:32 PM   #20681
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default CS service
Schui's US customer service is bar none the best out there..
i've called with a few questions...they made time to answer them..
when I was placing orders...they suggested to take of certain parts from the list since I would NOT need them for carpet. No other company has does that before for me.
had a shock tower that was frayed in the box, my guess during shipping...
they sent a replacement out.. the only question they asked was "what was my address" shipped priority... zero charge.
try and get that from Xray...?????? last time i called Xray for a part problem..they pretty much just ignored it. Remember the bulkheads weren't even...had to shim out to get equal width....Never heard from them again.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 07-09-2007, 12:36 PM   #20682
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Just got done building my 5 cell car for the Nats, figured it's as clean as it'll ever be so I might as well take a couple pics before it gets packed for the trip to SIR.
Schumacher Corner-img00106.jpg   Schumacher Corner-img00107.jpg   Schumacher Corner-img00108.jpg
Old 07-09-2007, 12:42 PM   #20683
Customworksking's Avatar
Trader Rating: 73 (100%+)
Wink xray
The only thing xray has is Paul L the last race at trackside Paul helped me every time i asked in total say 3hrs + he did it for everyone for 3 days on his own time...
Customworksking is offline   Reply With Quote
Old 07-09-2007, 12:46 PM   #20684
seaball's Avatar
Send a message via Yahoo to seaball
the blackness is killer, sir. i too, shall unleash mine in a few weeks.
seaball is offline   Reply With Quote
Old 07-09-2007, 01:02 PM   #20685
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I really don't think I want to see what you have to unleash.
Jon Kerr is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
