Old 07-03-2007, 08:52 PM   #20581
Sigearhead's Avatar
Trader Rating: 68 (100%+)
as a matter a fact you would probably break less if you just take the balls off the diff and tighten is down rather than use a spool in the rear. There is no give to the spool and you could break outdrives, cvd's and all kinds of stuff in the rear of the drivetrain. If you run the tightened diff but not completely tight, just enough so that it won't slip under driving conditions but that it will under wrecking conditions then you might cut down on broken parts.
Sigearhead is offline   Reply With Quote
Old 07-03-2007, 10:37 PM   #20582
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Sigearhead View Post
If you don't hit you don't have to worry about it!!!
You gotta come with more originality than that! LOL
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-04-2007, 01:45 AM   #20583
Hi ..I would like to race the Mi3 in stock with rubber tires and on asphalt. How close is the set up if the kit has been built as per the manual? Would you recommend any changes?
The track is medium to large and medium grip.Thanks in advance.
Adrian.
ernie is offline   Reply With Quote
Old 07-04-2007, 02:17 AM   #20584
Mission Mad MI2's Avatar
Send a message via MSN to Mission Mad MI2
Default MI3
Ernie ,my son races in similar conditions to what you are enquiring about and with the factory setup ie .going by all the measurements .
He has already beaten his PB and did it on a cold and dusty track ,so I would be recomending the factory setup without hesitation .
Having said that he did need a couple of heats to get used to the feel of the new car as it reacted faster in his veiw to driver imput .
Also just to prove to ourselves it is a good setup he ran the car the next meet without change and was getting the same times .With consistancies in the low .22 s .
hope this helps, Mark
Mission Mad MI2 is offline   Reply With Quote
Old 07-04-2007, 02:19 AM   #20585
Default MI3
his previous car was the EC edition
Old 07-04-2007, 02:25 AM   #20586
Default .
apoligise for the double up guys was supposed to edit
Cheers Mark
Old 07-04-2007, 03:00 AM   #20587
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Hi guys,
Did anyone know the CV driveshaft steel axles that can fit/replace Mi3 alloy axles?mine snap!please help.
James khoo is offline   Reply With Quote
Old 07-04-2007, 05:28 AM   #20588
Cheers Mark
Thanks for your help Mark.
Old 07-04-2007, 05:50 AM   #20589
steveonamission's Avatar
hmmm does anyone know if you can buy like the alloy cvd shaft bit seperatly (dogbone whatever you like to call it) as mine are slightly bent to say the least after a bit of a ruff A final
Dont realy want to spend 25 on whole new set
steveonamission is offline   Reply With Quote
Old 07-04-2007, 06:07 AM   #20590
AdrianM's Avatar
The drive shaft will be available seperatly in a couple weeks.
Old 07-04-2007, 07:25 AM   #20591
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
what about the other half of the CVD (the "joint" assembly)? Will that be available separately also?
Old 07-04-2007, 09:17 AM   #20592
PW
PW's Avatar
Send a message via AIM to PW
They are already in stock U3233 (dogebone)
The axles are still back ordered and I don't remember the part number right now.
Top-deck is being looked into....
PW is offline   Reply With Quote
Old 07-04-2007, 09:20 AM   #20593
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
hey Paul let me know when you get the P-Dub bumpers in stock
Old 07-04-2007, 09:21 AM   #20594
PW
PW's Avatar
The Mi3 ones are
Old 07-04-2007, 09:22 AM   #20595
protc3's Avatar
hey paul,any plans on a 501x pdub bumper? marcos may be getting one and he may need it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
