Old 06-29-2007, 12:25 AM   #20476
mitchsterbrau's Avatar
hey guys, thanks again for putting so much effort into this thread.
and making such good responses in such short time.
it's been a massive help.
got a buildup thread, maybe u might find the pics useful....
http://www.ausdrift.net/phpBB2/viewtopic.php?t=2820
schumacher have been great getting replacement parts out fast
for anything that came faulty in the box. eccentrics & CVD joint.
mitchsterbrau is offline   Reply With Quote
Old 06-29-2007, 12:41 AM   #20477
theisgroup's Avatar
Originally Posted by olhipster1 View Post
before I go post up in the sale thread...
local track just closed...so selling off my MI3 (3 battery packs thru it)...with parts, 2.5 top/lower decks, lower shock towers and quite a few parts.
only tested on carpet.
If anyone is interested drop me a PM
that sucks dude. the first person I convince to run a schui on carpet and now has to sell.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 06-29-2007, 01:06 AM   #20478
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
i'm still not believing it....
plopped quite a bit of change to get a new car ready for this season...and bammmm...
I will say...3 packs thru it....and it's absolutely the best car i've driven...
any little change made to it..and it responds..no null effect with the Schui...
for those lucky to get a Schui on carpet foam/rubber...it's going to be the bomb.
on the bright side...i don't have to smell Paragon for the next 8 months... :P
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 06-29-2007, 06:55 AM   #20479
hey on the ec can u run the front hinge pins with no shims and no spacers at all just flat on the chassis?
also can u run 3mm of shims plus riser in the rear?
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 06-29-2007, 08:24 AM   #20480
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
cheers
You're really going to the extremes there on both ends. I never ran the blocks that low in the front but I don't think you can do it because the arms will rub on the chassis. You shouldn't need to go that far. Same in the rear. You shouldn't need to go that far with the roll centers. At the most, go to only 1mm under the front blocks.
Try using pin angle to get the steering you want like I suggested.
Jon Kerr is offline   Reply With Quote
Old 06-29-2007, 07:34 PM   #20481
Trader Rating: 15 (100%+)
I ran my ec with the front arms shaved on the bottom with no shims on carpet.And had 1mm shims in the rear.
AARON YOUNG is offline   Reply With Quote
Old 06-29-2007, 10:04 PM   #20482
Jon Kerr's Avatar
That's carpet though. He's running asphalt. You shouldn't need to go that far on rubber tires.
Old 06-29-2007, 11:35 PM   #20483
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Forget about the 1/8 scale and come race at BC tomorrow Kerr!!
Old 06-29-2007, 11:36 PM   #20484
any idea's why my setting seems so extreme?
should i run blue front springs or change shock oils etc etc?
cheers.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 06-30-2007, 01:39 AM   #20485
Jon Kerr's Avatar
I gotta get a nitro fix. And what the Hell. Orion? When did this happen? I take it this means you will be running BL at the nats.
Old 06-30-2007, 01:47 AM   #20486
Jon Kerr's Avatar
cheers.
I still think you need to just put the front roll center to 2mm (riser plate only) and 3mm (riser plate + 1mm) in the rear. 30wt in the front and 35wt in the rear and white springs all around. Where is your front inner camber link location? If you have no risers under the diffs, (which if you still have those in, you should take those out) you should have drilled a hole 2mm above the high hole in the tower, or used the carpet tower. Then use pin angles (kick up, anti-squat, etc...) to work on getting more steering. Don't use both kick up and anti squat though. One or the other. How much droop are you running? That can have a lot to do with getting steering into the car. Where is the car pushing. Going into the corner, mid corner, or coming out? Or everywhere?
Old 06-30-2007, 01:53 AM   #20487
yep done all that my camber lings are in the high position on the standard towers. 30 wt all round
running bout 5mm droop rear and 3mm front.
oh i removed all diff risers.
and its mainly when im at neautral throttle now before it was when i was on power and neutral now its only neutral.
ill try 35wt rear oil and some anti-squat or kick up which is more effective for what?
finnally ill drill holes 2mm up, is that 2mm centre to centre or from the edge of the top whole?
cheers its much much better just seeing how far i can go before the rear end gets loose.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 06-30-2007, 05:56 AM   #20488
justin lessard's Avatar
Send a message via AIM to justin lessard
I dont think horsham will be closed for too long...
justin lessard is offline   Reply With Quote
Old 06-30-2007, 06:43 AM   #20489
Static_racing's Avatar
They better not be~!
Horsham's the only place I can practice for Rubber Tire on Carpet. Gotta get ready for Vegas!!
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 06-30-2007, 09:00 AM   #20490
Jon Kerr's Avatar
You drill the hole only if you're using the standard asphalt towers. You drill it 2mm center to center. All you're doing is compensating for when you take out the 2mm diff riser plate that brings the whole front end down. I would try kick up first. It tends to give more mid corner steering and make it rotate more in the middle of the corner. Also, where do you have your wheelbase settings?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
