Old 06-28-2007, 03:40 PM   #20461
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by protc3 View Post
no more posts at 3:00AM for adrian
Hope Adrian doesn't get another punch to the throat when the boss gets back into town
PW is offline   Reply With Quote
Old 06-28-2007, 03:51 PM   #20462
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-28-2007, 03:56 PM   #20463
theisgroup's Avatar
Default carpet chassis
Originally Posted by Sigearhead View Post
Can you post some pics? Mine will be on it's way soon and I'd like to see what it looks like.
carpet chassis
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 06-28-2007, 04:21 PM   #20464
Skiddins's Avatar
Can someone please explain the different effect of rear toe at the hubs versus rear toe at the inner pivot pins.
Which is best?
A Combination?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-28-2007, 04:50 PM   #20465
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by yyhayyim View Post
Its really not that big of a deal...unless you like to ram thru walls every lap, like Marcos
hey it takes alot of skill to hit every wall on every lap
Old 06-28-2007, 04:54 PM   #20466
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
before I go post up in the sale thread...
local track just closed...so selling off my MI3 (3 battery packs thru it)...with parts, 2.5 top/lower decks, lower shock towers and quite a few parts.
only tested on carpet.
If anyone is interested drop me a PM
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 06-28-2007, 04:55 PM   #20467
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Which is best?
A Combination?
Skiddins
Using outboard rear toe allows the car to rotate better and carry more cornerspeed through the turns since there is less of an angle on the arms and the pins.
Sigearhead is offline   Reply With Quote
Old 06-28-2007, 05:13 PM   #20468
hey guys mi2 ec question:
im running 2mm shims under my rear pivot blcoks plus the riser. how much can i run with out damaging the chassis?
finally jon kerr i did the changes u mentioned and added more rear droop and shortened the rear wheel base. what else can i do to get more mid-exit corner steering?
the car is amillion times better than before but im seeing how far i can push it. thanks for your help
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 06-28-2007, 05:24 PM   #20469
Super Moderator
Marcos.J's Avatar
having the front shocks inclined more than the rear should give you a little more mid-corner steering
Old 06-28-2007, 05:24 PM   #20470
JayBee's Avatar
Trader Rating: 31 (100%+)
Skiddins-
You're rollin' a MI3 for goodness sake, clean up that wire'n!!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-28-2007, 05:32 PM   #20471
JayBee's Avatar
So you guys that have or have tested the 2.5mm chassis-
I have one and wondered if it's worth trying on med. to high-bite asphalt? I do want one of those 2.5mm kits too, where can I find 'em?
Old 06-28-2007, 06:04 PM   #20472
AdrianM's Avatar
Old 06-28-2007, 10:21 PM   #20473
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You could also try kick up in the front. Do you have the pivot blocks all the way to the riser plate in the front? If not do that first. If so, add a .5mm shim under the forward front blocks. This should give more mid corner steering but it may take away some turn in.
Jon Kerr is offline   Reply With Quote
Old 06-28-2007, 10:30 PM   #20474
JayBee's Avatar
Not everybody answer at once
Old 06-28-2007, 10:34 PM   #20475
Jon Kerr's Avatar
Everyone's in bed except us.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
