Schumacher Corner
Regional Moderator
I remember PW mentioning this from way back when, but I totally forgot about it.
Steve,
Your car looked very good. How bout getting a PDF together so I can compare it to mine. My car was good got down to about 11.1 after some help from latif but I still needed more steering. As soon as I get a PDF together I will post it.
Fred - were you running a one way? I know it made a huge difference when I switched.
One-way, arms back, front arm sweep, rear arms forward. It just wouldn't turn through the center.
Just pray for rain , I know I want to go back already
It's still a very good setup. It has a lot of steering. But the track I've been running at is odd because all but one turn is off camber so you need steering there that would be way too much anywhere else. So I've made some changes that gave even more steering and it's working really well now. the only major difference is the front camber link height, rear toe, shock location, and front pin angle.
MJ- thanks for that. If I run the Type R hinge inner pins, will they stay in the pivot blocks? Isnt that the reason for the 2.5mm screws on the Mi3 pins to hohold them and prevent that they slide out? maybe the Type R's also are grooved to accomodate 2.5mm screws at the ends? I could be wrong...
Super Moderator
Anyone know where I can get some rear Mi3 inner hinge pins? I hope Schumacher USA or Fasttrack will have them in, so I can run this week...
Tim Help!!! Any news when they'll be in?
Super Moderator
Super Moderator
I can't wait to get the Mi3 on the track again. My car was so smooth to drive.
R/C Tech Elite Member
Off the subject, but I'm trying hard to find something, and nobody seems to have it in stock. I'm looking for a KO Propo PDS-2413 servo, anyone seen it in stock anywhere by chance? Need to have it in my hands early next week!
Just call Ko-Propo they will sell directly to the customer.
