Old 06-25-2007, 02:00 AM   #20386
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
So I think I am hearing most of y'all just run the plastic servo horn in the kit without any servo saver. Since the kit servo saver is not recomended (so I read) has anyone found a servo saver that works for the Mi3?
Old 06-25-2007, 02:34 AM   #20387
I used a Kimbrough servosaver...fits straight on ..no problems
Barger is offline   Reply With Quote
Old 06-25-2007, 04:05 AM   #20388
heavy's Avatar
Trader Rating: 20 (100%+)
I used teh plastic horn with no servo saver and stripped teh gears in a metal geared Futaba servo.
In desparation I used the kit servo saver and found out it actually works pretty good no jamming open or any of that stuff - pleasantly surprised.
Apaprently the Kimborough Mid size servo saver is the GO - I've got one on order from Tower at the moment.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 06-25-2007, 05:59 AM   #20389
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
anybody looking for Ti-Nitride hinge pins for the MI3 the pins for the Losi Type R are a near perfect fit part #LOSA6094
Old 06-25-2007, 06:55 AM   #20390
My Mi3 was AWESOME this weekend at the Sedan Challenge in Frederick, MD. I tried a couple of different things in practice on Friday. And ended up going back to my normal setup. When traction came up by the 3rd round, made one small change and the car was right there. Qualified 17th out of 39 and finished 12th.
Latif drove my car this week. He likes the new car. Maybe we can get him back into racing again. Latif did the anouncing this weekend.
Congrat's to Justin on his "A" Main finish yesterday.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-25-2007, 07:07 AM   #20391
Skiddins's Avatar
Originally Posted by aus jd 2703 View Post
ok if that doesnt work? lol
sorry used the blue spring to transfer as much weight as possible and it still didnt unsettle the rear end
To try (what have you got to lose)
Short front wheelbase
Stand rear shocks up more
Lean front shocks in
Camber links in lower hole (top stock guys at my track run with these lower with standard towers)
Add rear roll bar.
Check hinge pins etc are not bent and wishbones are not binding etc.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-25-2007, 07:10 AM   #20392
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Steve your car looked good the few times I saw it on the track. Too bad I couldn't stayed longer to watch but had a good anyways. Your car is getting better all the time and especially since you had a few weeks to run it.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-25-2007, 09:04 AM   #20393
Regional Moderator
Darkseid's Avatar
Had a good run with the car again yesterday. Another second place. Took some pretty good impacts(including destroying someones car in a full speed impact on the straight), but no damage to the front universals.
One thing though. I am running the full PW set up on the car(on asphalt), but I'm not getting the low speed steering I need from the car in the tight sections. I had to get my dual rate up to 98% just to get close to what I wanted.
Any suggestions?
TLR 22...Tamiya F104...
Old 06-25-2007, 09:35 AM   #20394
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Move the outer steering links to the forward hole on the steering knuckle. That'll give you a lot more steering all around. I don't run anything but that now.
You'll need to re adjust your endpoints and toe settings when you do this.
Jon Kerr is offline   Reply With Quote
Old 06-25-2007, 10:10 AM   #20395
chris72983's Avatar
Jon, I have my car setup with your setup, from reedy. I havent ran it yet but I am going to this weekend or the next. At this point do you think it is still a good starting point or have you changed up some stuff after having some more testing time?
chris72983 is offline   Reply With Quote
Old 06-25-2007, 10:11 AM   #20396
The Evicerator
Jon Kerr 1 16th di da dee!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-25-2007, 10:43 AM   #20397
i have my diff at the back abit loose at the moment, do you think if i tighten it up a little it will give me more rear end grip?
jordan.norwood@ is offline   Reply With Quote
Old 06-25-2007, 10:44 AM   #20398
Jon Kerr's Avatar
It's still a very good setup. It has a lot of steering. But the track I've been running at is odd because all but one turn is off camber so you need steering there that would be way too much anywhere else. So I've made some changes that gave even more steering and it's working really well now. the only major difference is the front camber link height, rear toe, shock location, and front pin angle.
Old 06-25-2007, 10:48 AM   #20399
Randy Caster's Avatar
Trader Rating: 46 (100%+)
DI DA DEE!!
Old 06-25-2007, 11:13 AM   #20400
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Andrew,
I'm using the black Kimborough....fits very nice in the 2.5 deck...they have a well placed cutout just for the servo saver fitting.
with the kimborough I'm using the top corner hole and just chopped off the rest of what wasn't needed.
servo is sitting about 1mm lower in height when compared to the Schui one.
but i didn't like the way the Schui spring was rubbing on the servo.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
