Old 06-19-2007, 06:35 PM   #20281
mitchsterbrau's Avatar
thanks andrew!
looks like i'm going with a one-way or bally,
there is NO traction where i'm running.
cheers again for the advice.
mitchsterbrau is offline   Reply With Quote
Old 06-19-2007, 06:43 PM   #20282
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
sure thing bro.
More Kerr bait . . .
Can *anyone* suggest what difference I might feel if any betwen widening the rear of my Mi3 at the hexes versus widening it at the bulkhead?
Old 06-19-2007, 08:56 PM   #20283
Some Lipo install pics. Pictures worth a thousand words. Ive had plenty of collisions with thsi setup and had no signs of any problems. I ran my corally like this for almost a year too with no failures.
I used a couple 3mm shims under the lower center track rod mounting bracket to raise the track rod to clear the LiPo.
Schumacher Corner-.jpg   Schumacher Corner-b.jpg   Schumacher Corner-c.jpg   Schumacher Corner-d.jpg   Schumacher Corner-e.jpg
Old 06-19-2007, 10:20 PM   #20284
Trader Rating: 26 (100%+)
Default CVD Chatter
O.K. Here goes. Has anyone else notice the amount of CVD chatter the MI3 has when you have the wheels off the ground turn full lock and apply a SMALL amount of throttle (I have glued the 2mm shims to the front hubs and correctly set my EPA)? I was wondering if anyone has a fix for this as it seems to develop a lot of vibration through the front end. I'm not 100% sure but I think it was doing the same thing on the track as well. This may also be accelerating the destruction of front drive shaft components. What I was wondering was has anyone tried any of the new track rod sets as I believe the problem maybe developing from excessive Ackerman effect creating a large slip angle on the inside wheel, making the CVD transmit through a larger angle and causing the vibration.
Other peoples thoughts, experiences?????
Andrew
CountryHick is offline   Reply With Quote
Old 06-20-2007, 03:56 AM   #20285
Trader Rating: 22 (100%+)
Originally Posted by andrewdoherty View Post
sure thing bro.
Widening at the bulk head will also affect your shock angle and lay your shocks down a little bit and you will also have to adjust your camber which will be longer. Where as at the wheel your only affecting at that point.
fastasu2 is offline   Reply With Quote
Old 06-20-2007, 03:59 AM   #20286
Andrew
I have not notice this. I did however when I built mine notice that the CVD seemed like they were binding. I took them apart and put grease into them and they are alot smoother and have not noticed any chatter yet.
Old 06-20-2007, 05:23 AM   #20287
steveonamission's Avatar
Andrew
Hi, yes i had quite a lot of chatter when i had the car off the ground it like shook the whole car, however i didnt think into it too much and now have used ther car half a dozen times. Now i have hardly any chatter now, maybe it takes time for everything to settle in, however it did seemed to improve when i recieved my new drivehshafts, the ones with the updated pins.
Ok hope this helps
Steve
steveonamission is offline   Reply With Quote
Old 06-20-2007, 05:45 AM   #20288
Thanks Steve, I think my kit has the updated shafts. They came with the flat spot on the CVD pin (Looked like it was done by hand?) I will give it a few more runs and see if it improves. Has anyone tried a different brand of CVD in their car?
Old 06-20-2007, 06:36 AM   #20289
theisgroup's Avatar
Andrew
one thing to remember is that our cars do not really have "CVD". so as you turn your wheels closer to full lock they will bind. just take one out and then pin the cvd with the wheel axle straight and then bend it slightly at the universal you will feel resistance.
I have seen this question posted on almosted every car thread. and the reason is that we all used the same thing. it really is a universal joint and not a true "CVD'. Now I do not have a losi, but they build a true "CVD" and I would think that they would not have this problem. if you want more on this, check out http://rctech.net/forum/showthread.php?t=91463
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 06-20-2007, 06:50 AM   #20290
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
sure thing bro.
Nice! Good question though. I've never really tried it. Taking out the wheel shim and widening the inner hinge pin location would change your shock angel, camber link length, and your outer hinge pin location in the wheel. All of these will change the handling of the car. Maybe something to play with at the track sometime.
Jon Kerr is offline   Reply With Quote
Old 06-20-2007, 07:06 AM   #20291
theisgroup's Avatar
one thing it does is that the wheel will now rub on the arms. at least in the rear. I uhm "lost" the shim that the kits come with. so i ran mine without them. now the arms in the rear rub on the wheel
yang lai
Old 06-20-2007, 07:21 AM   #20292
mo
mo's Avatar
sure thing bro.
Widening it at the bulkhead will move the pivot point farther out, making the rear end roll less, which will generally take away a little rear traction.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 06-20-2007, 09:12 AM   #20293
thatnks for all the helpfull insight guys.
Yang-were you running your bulkheads wide, and using the 1 mm spacers? I have 1mm spacers you can have. Remind me on Sat.
Old 06-20-2007, 09:15 AM   #20294
theisgroup's Avatar
i actually shimmed at the bulkhead and then ran a thin spacer. but I have room to add another space. I need to measure out the spacers I have. they are a team tamale custom jobby. he cut hex spacers for me.
yang lai
Old 06-20-2007, 09:57 AM   #20295
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
Yang...
ya need to convince Larry to make some schui stuff...
Chubs...and bling steering knuckles...
hurry..hurry....
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
