Old 06-17-2007, 05:26 PM   #20236
Originally Posted by woozer71 View Post
Jan the blades were already mounted when I purchase the kit so whether the were stretched from the factory I don't know.
With the rear end it is really free so I don't think there is a binding issue. How loose do you guys run your rear diffs. I run on ashphalt smooth surface.
I also run stock and have always run my belts loose..but with the MI3 I found by having the belts one notch looser than the book the rear belt was causing a noise...binding...the front belt was ok but have since found it wearing from rubbing on the steering
Barger is offline   Reply With Quote
Old 06-17-2007, 09:21 PM   #20237
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Well nobody showed up for rubber tire carpet racing today, so I threw XRay 25 & 30lb springs on my asphault car, a front diff, and 2 upper decks and raced foam. Seriously no other changes to the car and I TQ'ed 19 turn by a lap. This car is pretty amazing to me, no other changes but what I listed to my Reedy Race setup and it was able to go that fast.
Unfortunately I wasnt able to stay for the mains, but with how good my car was, I kinda doubt they would have gone much different from qualifying.
lol, it was kinda funny watching my foam tire car going around the track with a Mazda 6 body.
Old 06-17-2007, 09:31 PM   #20238
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You run double pink, double pink orange Jaco's?
Sorry I couldn't make it today. Fathers day stuff. I'll be at BCR asphalt on Saturday next weekend.
Jon Kerr is offline   Reply With Quote
Old 06-17-2007, 09:32 PM   #20239
Jon Kerr's Avatar
PW- I just Emailed an order to you. Don't think I'll have time to call in tomorrow.
Old 06-17-2007, 09:40 PM   #20240
Jon...Have you heard anything about replacing the fron cvds as the pins are breaking
Bob
Old 06-17-2007, 09:52 PM   #20241
Jon Kerr's Avatar
If you're having trouble with the pins on the CVD's, call up Schumacher. They'll get you taken care of. PW posted a couple of days ago what the issue was and how they've fixed it. I think it was over hardened pins or something. I have yet to have a problem with mine, but I know there's been a handful of people who have. I don't think they're going to have the new CVD's in for another week or so though.
Old 06-17-2007, 10:31 PM   #20242
Yep, non wraps. I really could have used a ton more steering, but cant expect too much from a foam car with an asphalt setup on it lol.
Old 06-17-2007, 10:34 PM   #20243
Jon Kerr's Avatar
Should have just taken out a bunch of rear toe.
Old 06-17-2007, 11:14 PM   #20244
Hiya
What benefit does one get by overdriving the front (by using a smaller pully on the 1way or spool) , i have seen a few tamiya setups where they use a smaller pulley on the front, what benefit does this give, and how would you do it on the Schumacher?
MoonTrap is offline   Reply With Quote
Old 06-17-2007, 11:15 PM   #20245
Didnt want to change it too much and have to go through remembering what all I changed when I want to run it outdoors.. lazyness at its finest lol.
Old 06-17-2007, 11:15 PM   #20246
mutley001's Avatar
Originally Posted by mutley001 View Post
How do the Tamiya springs sompare to the schuie ones? Blue Front and White Rear?
Paul
Anyone help with this?
Cheers Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 06-17-2007, 11:17 PM   #20247
Originally Posted by MoonTrap View Post
Hiya
I run overdrive on my asphault spool setup, basically it makes the car a lot more aggressive turning in, and I feel it helps the car power out of the corners a little better as well. Check out my Reedy Race setup on the Schumacher website, the whole setup with the overdrive works really well.
Old 06-17-2007, 11:34 PM   #20248
whoopass's Avatar
Originally Posted by Skiddins View Post
Rob, what are you going to run now?
Skiddins
gone and bought a Scythe. its not bad to be honest.
whoopass is offline   Reply With Quote
Old 06-17-2007, 11:48 PM   #20249
Thanks for the reply randy.
Is the 414 pulley the same as the ta04 ?, also what teeth is it?
Is there any other pulley one can use, like the xray 34t one?, as it is hard to find parts for the 414/ta04
Old 06-18-2007, 03:03 AM   #20250
Anyone had problems with Mi3 topdecks breaking? Last weekend we ran 2 cars (only 2nd time out for both cars) and both broke the topdecks. Mine literally split in half, while the other one still stayed together, but is broken nonetheless
We did have some nice flights, but on my car nothing else was bent or broken, the other one broke rear lower arm as well.
I have to say I have never had a topdeck break throughout the 10 years I have raced Schumacher touring cars... the Mi3 one looks a lot more fragile as well than the previous ones, but still, this came as a complete surprise. One more thing to stock up.
olev is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
