Schumacher Corner
I ran the MI3 for the first time today and love the car. I had one problem with it though. After 4 5min races the rear blades on drive shafts were shot and need replacing. I only ran 27t stock so I thought they might of lasted longer than 4 runs. Has anyone had this problem and where is the best place to get replacements?
The EC had pin troubles but that got fixed with a new set of drive shafts. Now the MI3 also has pin troubles. How can that be? Weren't they fixed on the EC?
@woozer: The front blades wear out fast if running a spool and so do the rears if running mod, but 27T shouldn't wear out that fast. Sure you didn't stretch them too much when mounting?
R/C Tech Elite Member
On another note, I'm about to head out to our local carpet track to try my hand ad rubber tire carpet racing for my first time ever in 10 years of racing. I'm just praying I dont have one of those cars that traction rolls around every turn, as I really wont know what to do to fix it, lol.
Super Moderator
The EC foam chassis should have 1.5º rear toe from the kit. I guess you could get the plastic pivot blocks from the Mi2 and mount them with the ridge outward. This should give you 1º or .5º. Just out of curiosity, why would you want to run that little rear toe? That's going to be really hard to drive.
Super Moderator
Other than that im realy happy with the car
Hiya,
Thanks for the reply, i thought the EC Foam came with 2.5 rear toe? , if i ran the plastic mi2 blocks, wouldn't i only get it down to 1.5 ?. On my mission i always run 1 to 0.5 toe. The mission is easier to set toe with the turnbuckles, i could always mount front caster blocks and steering knuckles with some turnbuckles attached to the rear, to make an mi-EC rear
Super Moderator
Ive been doing a bit of rubber carpet back here in the uk, has PW got a setup sheet that can be posted, ive found the car to be realy quick, though slightly twitchy, and the other problem is for the first let say 2 - 3 laps the car struggles to find grip (been going with the chris ashtons test carpet setup)
How do the Tamiya springs sompare to the schuie ones? Blue Front and White Rear?
Been using this myself and really like it
Paul
I have a 5 month old Mi2EC for sale includes:-
new grey belts
new front wishbones NIP
full roll bar set
The car is very neat and tidy, only ever had a 27T stock run in it and is still very tight and clean. All delrin bits still very white and new looking. pictures available on request.
yours £100 + postage about £10.
May even throw a nearly new PF dodge 3 190mm bodyshell too.
PM me if you are interested.
cheers
new grey belts
full roll bar set
cheers
Hiya,
Jan the blades were already mounted when I purchase the kit so whether the were stretched from the factory I don't know.
With the rear end it is really free so I don't think there is a binding issue. How loose do you guys run your rear diffs. I run on ashphalt smooth surface.
new grey belts
full roll bar set
cheers
new grey belts
full roll bar set
cheers
Skiddins
