Old 06-14-2007, 01:30 PM   #20191
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by CountryHick View Post
I"m sure you can find this stuff in the States somwhere, but because I live in Australia I got mine here.
http://www.techflex.biz/index.html
these guys are actually in florida!
http://cableorganizer.com/wire-management/
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-14-2007, 01:46 PM   #20192
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Hey guys
Just an update
i do believe the Shui USA has the 2.5 bottom deck and the lower shock towers in stock.
top plate hasn't arrived yet
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 06-14-2007, 01:52 PM   #20193
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by olhipster1 View Post
Just an update
They also have 96t 64pitch spur gears in stock as well for the guys running 13.5 motors.......
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 06-14-2007, 01:59 PM   #20194
IslandBwoy's Avatar
Originally Posted by Marcos.J View Post
isnt Minreng in Florida??
I'll take that for a yes ??!?!!
IslandBwoy is offline   Reply With Quote
Old 06-14-2007, 08:54 PM   #20195
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Don't ask me how I discovered this . .
but have no fear about the strength of the arms on the Mi3.
(I managed to bend an inner hinge pin without breaking the arm it was in. In fact the arm doesn't even have a scratch and the hinge pin looks a bit "S" shaped!)
Thanks to McGoo for helping me with the set up today. 'preciate it bro!
Old 06-14-2007, 09:00 PM   #20196
MikeR's Avatar
Trader Rating: 15 (100%+)
How do you guys feel about the flexible droop stops? Too much carbon milled out maybe on the stock chassis?
MikeR is offline   Reply With Quote
Old 06-14-2007, 09:54 PM   #20197
reilly's Avatar
Hey Jimmy,
First welcome to the team, nice job last weekend.
Second, dyeing the white plastic parts you can use clothing dye
in the states it's brand called Rite.
hope that helps.
James
reilly is offline   Reply With Quote
Old 06-15-2007, 06:54 AM   #20198
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
with the last chassis, the pivot block screws were nearly inline with the droop screw, so the flex was on a single axis (bow). the new design of the mi3 allows for the smallest overhang, at the expense of a solid downstop. they probably could have used a third screw in each bulkhead, perhaps drilling the hole for the sway bar mount all the way through. the 2.5mm chassis should help, however, there will still be some additional flex in the ears compared to the old car.
seaball is offline   Reply With Quote
Old 06-15-2007, 07:47 AM   #20199
chris72983's Avatar
Finally finished my Mi3 last night, Check out that date, I had mine before anyone
chris72983 is offline   Reply With Quote
Old 06-15-2007, 08:03 AM   #20200
Static_racing's Avatar
The flex in the ears threw me for a loop at first too. When measuring droop above ride height just pull up at the shock towers. Do not hold the wheels.
If your using a doop gauge, I just set my mark and give the top of the hub a little tap and then re-measure.
Static_racing is offline   Reply With Quote
Old 06-15-2007, 02:35 PM   #20201
which one is the one u use is it the nylon braid or what? there is about 20 different wraps there lol
aus jd 2703 is offline   Reply With Quote
Old 06-15-2007, 02:44 PM   #20202
justin lessard's Avatar
Send a message via AIM to justin lessard
You ready for the Sedan Challange?..ygpm
justin lessard is offline   Reply With Quote
Old 06-15-2007, 05:27 PM   #20203
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Originally Posted by reilly View Post
Hey Jimmy,
hope that helps.
James
James...ready for cleveland/vegas?!?!?!?!? hahaha
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 06-15-2007, 05:45 PM   #20204
Man, I wish I was going. My car was REALLY good at Jackson
I'm going to be in Minnisota with my wife for two weeks
Old 06-15-2007, 06:05 PM   #20205
hey how do u guys get your wires coming out of ur esc to be horozontal in stead of vertical like what its normally like? i wanna try it to see if i can thread them under the top deck?
cheers
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
