Old 06-07-2007, 10:27 PM   #20041
Regional Moderator
Darkseid's Avatar
Well I just found out today that I put about a season's worth of wear on one of my front universals. Some how I had a wheel crack during my last race and apparently it was grinding on my front suspension arm. This somehow caused my unversal parts to grind badly.
The only reason I even found out was because I noticed my pin easing out of the universal. So I went to tighten up and re-threadlock the grub screw, and I find all these metal shavings.
So I cleaned everything up, filed off some sharp edges that resulted from the grinding parts, and used some Tamiya anti-wear grease on both front universals.
Luckily the grinding didn't seem to do much. And the universal seems to be working just fine. Just a reminder to everyone to keep an eye on those front universals. Even when everything seems fine, it doesn't hurt to give them a close inspection.
TLR 22...Tamiya F104...
Old 06-08-2007, 10:52 AM   #20042
I was setting my droop last night and I had to crank down on the downstops to get it under 3mm. Is that normal for you all as well?
Also, I noticed the collars on my shocks are in about the middle of the shock threads, seems kinda odd to me but could be normal. Anyone have close ups of their downstops as well as their shock collars and how far down there are on the shock thread for 2-3mm of droop?
thanks
sf85 is offline   Reply With Quote
Old 06-08-2007, 11:13 AM   #20043
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
thanks
You do have to crank them in a bit more than the old car not having the riser plates like the old car. Here's some pics of my car.
Schumacher Corner-dscf0228.jpg   Schumacher Corner-dscf0230.jpg   Schumacher Corner-dscf0231.jpg   Schumacher Corner-dscf0232.jpg
Jon Kerr is offline   Reply With Quote
Old 06-08-2007, 11:20 AM   #20044
Thanks Jon for the quick response! Mine are about the same with the exception of my shock collars being down even further than yours are. I'll see how it goes on the track tomorrow
Old 06-08-2007, 11:22 AM   #20045
Jon Kerr's Avatar
What tires are you running, what ride height are you trying to get, and how long are your shocks?
Old 06-08-2007, 11:25 AM   #20046
Same exact setup as PW's FSEARA setup.
CS27's
Front ride height 5mm
Rear right height 5.25mm
Shock length 61.5mm
Old 06-08-2007, 11:26 AM   #20047
CS27's
Shock length 61.5mm
Sorry, only 1 change, 35wt shock oil
Old 06-08-2007, 11:30 AM   #20048
Jon Kerr's Avatar
There's the difference, I run 4.5mm front and 5mm rear ride height. Plus I think CS27's are a little smaller diameter diameter than the RP30 that are on my car. Both are considerably smaller than Sorex tires.
Old 06-08-2007, 11:48 AM   #20049
Makes sense now
Old 06-08-2007, 11:55 AM   #20050
Jon - did you have to shave your rear arms at all?
Schumacher | Novak | P-dub Racing | Orion | Airtronics | Team Stream
Old 06-08-2007, 12:06 PM   #20051
Jon Kerr's Avatar
Nope. Where did you need to shave them?
Old 06-08-2007, 12:33 PM   #20052
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
seaball is offline   Reply With Quote
Old 06-08-2007, 12:44 PM   #20053
Jon Kerr's Avatar
Originally Posted by seaball View Post
LOL. I heard some stories about you at Reedy.
Old 06-08-2007, 02:37 PM   #20054
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
hey skip i have your harness ready for you tomorow!!
Old 06-08-2007, 02:39 PM   #20055
Outer edge where the wheel turns around it. The tire was rubbing from going off a long straight into a fast corner. Talked to PW about it and he said he had to shave his down too.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
