Old 06-06-2007, 02:14 PM   #19996
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Here is my MI3 with 5-cell set up it weighs 1369grams w/o the body and 1485 with, Im sorry my wiring is not as neat as PW but I tried
Old 06-06-2007, 04:12 PM   #19997
Regional Moderator
Darkseid's Avatar
Lookin' good.
Is that the P-dub bumper? Do you have to trim it, looks like your tires would hit if you turn the wheels even a little.
TLR 22...Tamiya F104...
Old 06-06-2007, 04:32 PM   #19998
Super Moderator
Marcos.J's Avatar
Originally Posted by Darkseid View Post
Lookin' good.
its the P-Dub bumper and believe it or not the tires do not touch the bumper at all
Old 06-06-2007, 04:44 PM   #19999
Regional Moderator
Darkseid's Avatar
Huh... thats pretty amazing. It looks like if you even think about turning the wheels, that you'll be carving foam.
Old 06-06-2007, 05:15 PM   #20000
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
Yes, its true. I installed the MI3 P-Dub bumper a few days ago and it doesnt interfere at all. It works great and its really tough...
Also: please note that you can add 4mm in shims to the servo mount and get the servo 4mm further inward towards the centerline for much better balance and weight distribution. The 4mm in shims( 2X2mm spacers/shims) work nicely with the stock center trackrod, and the servo horn. If you use the stock servo saver you might use 3mm. With the med/med trackrod, you can use 3.5mm in shims. This allows you to get the servo as far inward as possible, thanks to unique and exquisite design of the MI3, and no car today with similar servo configuration allows you to put the servo so far inside as the Mi3 allows us!!!
yyhayyim is offline   Reply With Quote
Old 06-06-2007, 05:26 PM   #20001
yyhayyim's Avatar
Default MJ's Mi3
Marcos- nice pics of a nice ride...good layout, too. The only think i could think of is this: for better weight distribution and centralization of mass, have you tried sliding the ESC forward, so that it meets with the servo mount. This gives you a gap between the ESC and motor- in this gap, laydown the capacitor. You can lay the capacitor down paralel to the motor and stick it down to the chassis and against the bulkhead. Or you can stad it up in the gap. The space between the GTb and motor is enough to fit the capacitor and should allow you to also slide the ESC a few mm further towards the center line- you can get it within 3mm of the belt
Old 06-06-2007, 06:02 PM   #20002
yyhayyim's Avatar
Talking
I want to order some spare diff rings. Anyone know if U3140 comes with 2 diff rings per pack or just one per pack?
Old 06-06-2007, 06:07 PM   #20003
Super Moderator
Marcos.J's Avatar
the car is pretty balanced from left to tright and front to rear, i need the room between the esc and the motor to fit my 52t pinion
Old 06-06-2007, 06:21 PM   #20004
PW
PW's Avatar
Send a message via AIM to PW
They come in pairs.
PW is offline   Reply With Quote
Old 06-06-2007, 06:25 PM   #20005
JayBee's Avatar
Trader Rating: 31 (100%+)
Picked up a spare racing shock set and one of the shock caps has only (1) vent hole Does anyone know what size hole it is...I want to drill it out myself
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-06-2007, 06:25 PM   #20006
yyhayyim's Avatar
Originally Posted by PW View Post
They come in pairs.
Thanks PW...by the way- have you tested with the med/med track rod? What hole? What are the differences between that one vs the stock one(long/med)?
Old 06-06-2007, 07:01 PM   #20007
PW
PW's Avatar
Not sure. Shoot me an e-mail and I will try and get you a new cap and or the size of the hole paul@schumacherusa.net
I would like to test it some more because at my home track it gave the car more steering, but the stock link was more steering at the Reedy Race
Old 06-06-2007, 08:26 PM   #20008
JayBee's Avatar
Thanks PW
Old 06-06-2007, 11:16 PM   #20009
MikeR's Avatar
Trader Rating: 14 (100%+)
So will the oneways come out for the car (seems complicated to work on the current layshaft system) or is Schumacher going full tilt towards the spool?
MikeR is offline   Reply With Quote
Old 06-07-2007, 03:15 AM   #20010
Are you serious? There is a front oneway system available for the car, that's all you need.
olev is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
