Old 06-06-2007, 09:58 AM   #19981
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking MI3 Gets Lighter
I've heard about Schumacher making some option parts to shave off about 30-40 grams from the current Mi3...supposedly new thinnner and lighter bulkheads, and plastic bodypost holders instead of the aluminum ones...
yyhayyim is offline   Reply With Quote
Old 06-06-2007, 10:03 AM   #19982
Originally Posted by Marcos.J View Post
Hey Skip are you running 5 cells saturday? Im going to change mine over and try it out
I'm actually going back to 6-cell. I think the weight distribution with the 6 cell chassis was off quite a bit to be honest.
I bought a Vortex 4.5 brushless motor so hopefully that will help with the thermal issue
sf85 is offline   Reply With Quote
Old 06-06-2007, 10:04 AM   #19983
Super Moderator
Marcos.J's Avatar
Trader Rating: 167 (100%+)
oh I have an extra Vortex motor, were you able to get a harness for it?? if not i have a one extra
Old 06-06-2007, 10:15 AM   #19984
John_S's Avatar
hey guys was just wondering if anyone could recomend good setup for a large flowing medium grip asphalt track for the mi2ec Thanks
John_S is offline   Reply With Quote
Old 06-06-2007, 10:17 AM   #19985
yyhayyim's Avatar
Talking
What are you guys gearing your GTB/3.5R? I am currently running 114S/20p for 10.40 and its working nicely. No thermal issues, yet, so I'll try a tooth lower and see. On the team driver set up sheets, those running the LRP 4.5 motors were gearing for 8.5-8.8 FDR! How are they pulling this off without thermal issues? Only way I could think of was if they use 5 cell?
Old 06-06-2007, 10:24 AM   #19986
Super Moderator
Marcos.J's Avatar
i was running a 8.17 with my 4.5(Orion) with 6cells with no problems
Old 06-06-2007, 10:28 AM   #19987
yyhayyim's Avatar
Talking
Woooh! That's pretty low...was your Orion 4.5 at 8.17 faster than the Novak 3.5R? What temps were you getting at that FDR from your Orion? Is the Orion 4.5 compatible w/ NOvak GTB?
Old 06-06-2007, 10:33 AM   #19988
Marcos - you have a pm.
Old 06-06-2007, 10:34 AM   #19989
Super Moderator
Marcos.J's Avatar
back to you
or call my cell!
Old 06-06-2007, 10:38 AM   #19990
Charles Godwin's Avatar
I think lightening the bulkheads will save a lot of weight and will benefit the 5 cell cars a lot. I'd still keep the bodypost holders in aluminium just so the posts are more secure. One thing i probably will get are either titanium screws of aluminium screws just to get rid of a few grams.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 06-06-2007, 11:11 AM   #19991
Try Adrian's Mi2EC setup. It is a good setup to start out with. Go on the Schmacher Pit Space Website. You will find it.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-06-2007, 12:20 PM   #19992
John_S's Avatar
i cant find it there man i went into rubber tire asphalt and theres only 1 setup and its not from him
Old 06-06-2007, 01:11 PM   #19993
Regional Moderator
Darkseid's Avatar
...and plastic bodypost holders instead of the aluminum ones...
I think you said this was your first Schumacher, so let me tell you, light weight or not, you DON'T want to use the plastic body mount holders! Unless Schumacher incorparates a major redesign in the holders, the aluminum version is flat out better and more reliable.
The plastic ones seem like they work as well. On the workbench you'll be convinced that they are fine, but the first time you roll your car, or get rolled by someone else, the things will push down in the mounts. Or if you take a tough hit, they may pull up out of the mounts.
My advice, if you MUST lighten your Mi3 (which I guess is a issue if you run NiMH and/or 5 cell), try ti screws, ti turnbuckles, ti suspension shafts, something... but don't switch to the old body mounts. The new ones are better and work better.
TLR 22...Tamiya F104...
Old 06-06-2007, 01:39 PM   #19994
justin lessard's Avatar
Send a message via AIM to justin lessard
i had to add weight to my mi3...42 grams...but with a brushless speedo and motor I can understand the weight issue.
justin lessard is offline   Reply With Quote
Old 06-06-2007, 01:44 PM   #19995
Jonny Aird's Avatar
Is that brushed with 5 cell? Running to a 1350g weight?
Jonny Aird is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
