Old 06-04-2007, 09:24 AM   #19921
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
Originally Posted by yyhayyim View Post
Thx MJ...what rate are the tamiya yellow springs?
12 lbs ( i think)
Old 06-04-2007, 09:31 AM   #19922
Regional Moderator
Darkseid's Avatar
Tamiya Yellows-13.33lbs
Tamiya short Yellows-13.99lbs
TLR 22...Tamiya F104...
Old 06-04-2007, 09:32 AM   #19923
Super Moderator
Marcos.J's Avatar
my bad
Old 06-04-2007, 10:07 AM   #19924
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
Originally Posted by Marcos.J View Post
my bad
you use tamiya yellows all around or just in rear or front?
yyhayyim is offline   Reply With Quote
Old 06-04-2007, 10:11 AM   #19925
Regional Moderator
Darkseid's Avatar
my bad
I just have it nearly memorized by this point because I still own a Tamiya and a lot of people here ask about the Yellows.
Old 06-04-2007, 10:44 AM   #19926
Super Moderator
Marcos.J's Avatar
i run them front and rear
Old 06-04-2007, 11:01 AM   #19927
redlion's Avatar
Hey,
First thanks to Schumacher, Paul, Adrain, Shawn.
Secound what is a good startng setup for the Mi3 on tight asphalt indoor?
Wes
redlion is offline   Reply With Quote
Old 06-04-2007, 11:30 AM   #19928
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by redlion View Post
Hey,
Wes
If traction is fairly good you might try my setup from the Reedy Race, it should have enough steering to get around a tight track. And if you should need more, just throw in a 1 way.
Old 06-04-2007, 12:15 PM   #19929
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by sf85 View Post
When you say resurface the diff I am guessing you mean sand it down again? How many times can you resurface diff rings? How many re-builds? (if indeed that it was you're saying)
Yes, I mean sanding the rings. I usually use the same rings 4 or 5 times before I replace them. It depends. If I'm having trouble with a diff, I'll just replace everything to eliminate any variables. Outdrives included.
Jon Kerr is offline   Reply With Quote
Old 06-04-2007, 12:45 PM   #19930
Shop Owner
FTTim's Avatar
Trader Rating: 27 (100%+)
Send a message via AIM to FTTim
I need some parts: the #2 steering track rod(shorter one) and 1.2mm sway bars and some diff rings and 1mm and 2mm shims. Any word when these will be in stock?
http://www.fasttrackhobbies.com/cata...roducts_id=970
Just got them in stock!
AWESOMATIX USA | ROCHE USA | TEAM TRINITY
"The man who smiles when things go wrong has thought of someone to blame it on."
"Id rather die on my feet than live on my knees"
FTTim is offline   Reply With Quote
Old 06-04-2007, 12:56 PM   #19931
justin lessard's Avatar
Send a message via AIM to justin lessard
Hey,
Wes
If you race at the colesium, Brian Reigle aka (wyd) should be able to hook you up with a good setup,He races there often
justin lessard is offline   Reply With Quote
Old 06-04-2007, 01:00 PM   #19932
Wirre's Avatar
Evening people, just thought I'd file a small report since I haven't checked in for a while.
I took the old EC out for a spin last weekend for the first time this summer only to be amazed yet again by the performance of the car. Even though I was only running a 4.5T with 5 cells and a GM Genuis 80, the acceleration and corner speeds were out of the roof even though the car was seriously overweight at 1440g.
Only problem was really mid-corner steering whilst the on-power steering was really on top of things. I can imagine the Mi3 being a lot better when it comes to general consistency through corners, I feel the EC is a bit raw at times.
In the end I actually came within one tenth of my personal record even though the track had a lot less grip this time around.
What's the biggest difference when it comes to balance and steering between the Mi3 and the EC?
Wirre is offline   Reply With Quote
Old 06-04-2007, 01:21 PM   #19933
yyhayyim's Avatar
Talking
Originally Posted by FTTim View Post
Thank you!!! i just order a set of U3135(#2 trackrod)...cant wait to try this out...hopefully it'll give me more steering and a bit more space for electronics.
Old 06-04-2007, 01:25 PM   #19934
yyhayyim's Avatar
Strap a dominican plantain on your EC and try to run it...then run it again with out the plantain...much better with the plaintain or with out? Probably with out it, right? Well, that's how good the Mi3 is compared to yesterday's generation of cars...
Old 06-04-2007, 01:40 PM   #19935
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
