Schumacher Corner
Tech Legend
Trader Rating: 51 (100%+)
Can't say enough how pleased I am with this car. It is the best car I have used to date (I have had a ton of cars over the years) and is the best effort from Schumacher. They really did their homework on this car. SO easy to work on and adjust it is scary.
Tech Legend
I also ran at the Full Throttle Race, I ran stock and my car was money!!
The car was easy to drive and held its settings/tweek all day. I got to play around with my setup and the car got better each time I ran it. I qualified
5th in the "A" and ended up with 3rd. I'm really looking forward to the eXpress race at Jackson next week
Great job on your A main finish.
I can't wait for Jackson because my MI3 is just starting to heat up. The more I run it the better it gets. It is just so much fun to run this car and race for Schumacher. Now I need to get that order ready for Monday for a few spares and I'm good to go.
...so I guess both of your cars were good then
I ran my Mi3 yesterday at Frederick, MD Ran 5 packs and made a change to the car each pack. The car was awesome. To bad I couldn't race with you guys yesterday. For only having 5 packs on this car and it is running the same lap times as the Mi2EC. I can't wait for next weekend. eXpress Race is going to be awesome.
Tech Legend
Yeah. One the best working cars I have had in 19T. I'm just amazed how the car works and what little changes I had to make going from super high bite indoor asphalt to an outdoor track and the car still hooked up. Especially since I run alot of stock and thru a 19t in it and it still worked great.
Gave the Mi3 its first run today at Cotswolds in 19t. Track is fast but also has some tight and slow corner. Was using Jon Kerr's Reedy set-up (1mm more rear droop) and it was really really good . Car was planted. Could let off the power late and it would get into the corner with little effort. Can't wait for the BRCA national there, going to be fast. Even with old cells, naff brushes and RP30's which had about 5runs on already i've already just about beaten my PB! With some new cells and tyres etc it'll be on the money . Next is to try the Mazda Speed 6 and see how it compares to my regular Mazda 6
Charles
Charles
guys, can you remind me how to obtain 3 degree toe in, for the rear of an Mi2 EC?
Part numbers would also really help.
Cheers
Cheers
Super Moderator
Well after my 2nd full race day with the MI3 was great , i ran the type R also to compare and i must say that the MI3 was a full second faster per lap than the Type R (both with i dentical electronics) ran a full lap faster with the MI3, long story short the Type R is for sale now!!!
There are supposed to be some alloy rear hubs coming that can give the extra 1 deg outboard, I don't think they're out yet.
Skiddins
Guys, can anyone point me in the direction of Jon Kerrs Reedy setup for the Mi3.
I think I found out when I got home why my car was coming around off-power. I either had too much or too little droop in the rear and my tires were rubbing the rear arms, and I mean BAD. My left side rear arm is so gouged it probably should be replaced Anyone have any ideas on why the wheels would rub the arms. I am not good with setting up cars
Marcos - thanks for letting me borrow your tent and power, very much appreciated! Oh and the battery that fell apart It was a good time!
Tony P - thank you for loaning me the dog bone, I'll get it back to you if you are in Daytona! It looked like your car was doing similar to mine in the main, jumping side ways at the end of the straight, were your arms hitting your tires at all?
Thanks guys,
Skip
Super Moderator
Marcos i'm going to have to call you "flip-flop" now
Thanks guys,
Skip
Thanks guys,
Skip
sorry for the battery I had to get ahead of you one way or another
Super Moderator
both car had identical esc and motors and final drive ratios i ran one qualifier each!! Losi is 1.83 internal and MI3 is 1.8 so the FDR were almost indentical
Super Moderator
