Old 05-29-2007, 11:23 AM   #19726
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Originally Posted by yyhayyim
Just making sure...you wont belive how many "good" drivers down here give some strange explanation of what that means...some measure droop using the Xray manual method, which instructs one to remove shocks and use droop gauge. Others use the magic "David Jun" formula, etc...others have some other methods, but opposite of this...just making sure...
well i got it from PW himself so I wouldnt steer you wrong
Old 05-29-2007, 11:28 AM   #19727
Elboogie's Avatar
[QUOTE=yyhayyim]Thanks Jon...well the Hb Cyclones run 2.5 deg block of front inboard toe, or as you refer to it "sweep", and it comes stock like that. I have driven them and they have lots of steering...it seems to work fine for their cars...QUOTE]
I happen to run a cyclone WCE and thinking about switching to a MAch. the cyclone does come with 2.5 degree pivot block and a 3 degree in the back. I run on carpet so the only change that I did was in the front. I changed it to a 0 degree pivot block.
I know that when you use pivot blocks in the front of the HB cyclone the lower the number the less steering that you will have. That is the reason why i went to a 0 degree in the front because I didn't want my cart to be darty on Carpet. 2.5 in the front is great for rubber tire onroad. so the more degrees you add to the front, the more steering you get.
In the rear, the higer the degree on the pivot block, the more rear traction you have. The cyclone came with stock 3.0 in the back and I haven't changed it because I need the grip in the rear of the car.
Now I don't know what effects this has on the Mach but I just wanted to add some input since I drive a cyclone.
CYCLONE WCE
Jaco / Airtronics
Much More / Team Orion
"Drive Hard or Go Home"
Elboogie is offline   Reply With Quote
Old 05-29-2007, 11:29 AM   #19728
Elboogie's Avatar
CYCLONE WCE
Jaco / Airtronics
Old 05-29-2007, 11:30 AM   #19729
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Thanks...good stuff...get the Mi3...look at it as the new version of what a Cyclone should be like...
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-29-2007, 11:34 AM   #19730
Default Setups
When you go about setting up your car what order do you perform your setup in? This is what I do below (in order) but is this way ideal or do you recommend something better?
1. Droop - With the chassis flat on the ground measuring to the top of the drive axle.
2. Camber (front and rear)
3. Toe In/Out (front)
4. Ride Height
5. Check tweak between runs by pushing the car up in the center of the chassis with an exacto knife and then adjusting the droop screws accordingly
Schumacher | Novak | P-dub Racing | Orion | Airtronics | Team Stream
sf85 is offline   Reply With Quote
Old 05-29-2007, 11:35 AM   #19731
Super Moderator
Marcos.J's Avatar
well X- brand too since they like to copy every thing
Old 05-29-2007, 11:36 AM   #19732
Charles Godwin's Avatar
2
3
1
5
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 05-29-2007, 11:36 AM   #19733
yyhayyim's Avatar
I understand and appreciate your sincere help. I just wanted to make sure, that's all...by the way, I did some research, and it looks like you are tight with PW and Adrian, so...that makes your input that much valuable and credible...supposedly your a very good driver and have every car out in the market...good driver, with deep pockets and a good boss- cant beat that
Old 05-29-2007, 11:38 AM   #19734
Super Moderator
Marcos.J's Avatar
well im good friends with both of them , i do have a few cars, but as good driver?? I wouldnt say that Im far from that and as far as a boss ( the wife )
Old 05-29-2007, 11:39 AM   #19735
yyhayyim's Avatar
4. Ride Height
Get the Xray t2 set-up book. These steps are discussed and explaine in color and with lots of info on set-up theory. They have flow charts and logical steps on how to get your car set up. Its really good stuff...
Old 05-29-2007, 11:46 AM   #19736
Nice find, im going to check it out, thanks
Old 05-29-2007, 11:50 AM   #19737
yyhayyim's Avatar
Talking
its the best info available from a great company and group of top notch racers...their set up book is second to none...you wont be sorry.
Old 05-29-2007, 12:37 PM   #19738
yyhayyim's Avatar
Talking TH NExt big Race
When is the next big race team Schumacher is preparing for?
Old 05-29-2007, 01:00 PM   #19739
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
and will there be alot of groupies there? can i get an official statement from someone on this? preferably within 20 minutes or so.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-29-2007, 01:12 PM   #19740
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
4. Ride Height
Here's the order I do all of this.
1. Set your ride height.
2. Set your droop above ride height.
3. Take tires off and use droop blocks to make sure your droop is even. (This isn't to actually set your droop, only to make sure both sides are even. Use this time to make sure the chassis is flat on the droop blocks and not rocking back and forth.)
4. Put on setup station to check camber and toe.
5. Take off setup station and put on tires.
6. Check tweak on a tweak station or by lifting one end at a time. Don't adjust by droop screws. You've already made sure the droop is equal on both sides. Use your shock collars. If you have to have too much of a difference in your preload, double check your droop settings and that the chassis is flat.
Jon Kerr is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
