Old 05-29-2007, 09:06 AM   #19711
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking Toe
Is there a difference in when setting toe out using in-board toe out vs tout board toe out? For example, If I wanted 1 deg of front toe out, can I do it either way, meaning:
Option 1: have front in-board toe in of 1 deg., and 0 outboard
Option 2: have 1 deg outboard toe out and 0 deg inboard
Will either way yield the same results perfomance wise, or although both will give me 1 deg toe out, each option will make the car perform differently...thx
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-29-2007, 09:26 AM   #19712
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Inboard and outboard toe are two different adjustments. Especially in the front of the car. In the front we call it arm sweep. And it changes a lot more than front toe. We don't really use it for toe adjustments at all. That's what your steering links are for. It changes the path the suspension travels when compressed. Generally, a little forward arm sweep will give more steering all around. But it's a driver preference thing. A lot of guys don't like the way it feels. I haven't tried it on the new car yet (I had plenty of steering at Reedy!) but I really liked it on the old car. In the rear, we only use inboard toe (right now) to adjust rear toe. I don't know if there's going to be an option for different rear hub carriers for outboard toe adjustments in the rear.
Jon Kerr is offline   Reply With Quote
Old 05-29-2007, 09:31 AM   #19713
Default GET PAID TO DEMONSTRATE NITRO RC VEHICLES for 8 weeks!!
Still looking for someone to travel with a mobile marketing tour for a RC vehicle which will be following the Vans Warped Tour. This is a nicely paid 8 week gig! Starting in the next two weeks and wrapping up July 29th! Need some experienced RC drivers to demonstrate the vehicles to crowds of people! Please call me ASAP if interested for more details at 314-997-0101 x 220 or send me an e-mail to julie.doherty@promotion1.com.
julie.doherty@p is offline   Reply With Quote
Old 05-29-2007, 09:38 AM   #19714
yyhayyim's Avatar
Talking
Thanks Jon...well the Hb Cyclones run 2.5 deg block of front inboard toe, or as you refer to it "sweep", and it comes stock like that. I have driven them and they have lots of steering...it seems to work fine for their cars...just wondering what inboard/outboard toe changes affect. It seems like increasing front inboard toe, will also alter your ackerman, droop and caster and camber...but you can easily re-adjust them to what you had before and increase the front sweep for more steering, I guess...
Have you posted you set-ups from the Reedy yet?
Old 05-29-2007, 09:51 AM   #19715
Jon Kerr's Avatar
I haven't posted anything yet but if you Email me (jkerr0043@cox.net) I'll send you the word doc of the setup. I don't have the right software to make pdf files of the setup sheets.
Old 05-29-2007, 10:13 AM   #19716
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
geez Grandma . . .I told you to stay off the hash.
Please don't pay any attention to her. Were trying to ween her off the internet and she is refusing to take her medication. What a shame to the Doherty name.
Old 05-29-2007, 10:26 AM   #19717
dawgmeat's Avatar
you got mail
dawgmeat is offline   Reply With Quote
Old 05-29-2007, 10:27 AM   #19718
Jon Kerr's Avatar
BTW- anyone who I've sent my setup to. There's a typo on it. Ride height on the rear should be 5mm w/ 8mm droop, chassis to floor. (3mm true droop.)
Old 05-29-2007, 10:28 AM   #19719
Jon Kerr's Avatar
Originally Posted by dawgmeat
you got mail
Back at ya.
Old 05-29-2007, 10:31 AM   #19720
dawgmeat's Avatar
Back at ya.
thanks westside
Old 05-29-2007, 11:31 AM   #19721
yyhayyim's Avatar
Well, just tried messing with rebound on the shocks with o-rings. using HPI P-3 black low friction o-rings on the cap gives about 40% rebound on my shocks...much more than what I expected. Also, they sound a little funny when they compress; they make a slight squishing noise- got scared and thought it was bubbles, but after opening and checking the shocks, there were no bubbles. Rebuild shocks and its just something I'll have to deal with using the o-rings....but so much rebound?
Old 05-29-2007, 11:52 AM   #19722
yyhayyim's Avatar
Talking
just got your mail. Thanks for the set-up. A quick question, when you say the rear is 8mm with chassis to floor, do you mean 3mm above 5mm ride height?
Old 05-29-2007, 12:02 PM   #19723
Jon Kerr's Avatar
Yup.
Old 05-29-2007, 12:17 PM   #19724
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
yes same answer that you got in page 654
Old 05-29-2007, 12:22 PM   #19725
yyhayyim's Avatar
Talking
Just making sure...you wont belive how many "good" drivers down here give some strange explanation of what that means...some measure droop using the Xray manual method, which instructs one to remove shocks and use droop gauge. Others use the magic "David Jun" formula, etc...others have some other methods, but opposite of this...just making sure...
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
