Old 05-28-2007, 06:54 PM   #19696
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by AdrianM
To save time I will just put you down for one of everything new as soon as I find out about it
now you are talking!!
Old 05-28-2007, 07:05 PM   #19697
Default 5 cell chassis
what thickness will the 5 cell chassis be available in?
Butters37 is offline   Reply With Quote
Old 05-28-2007, 07:31 PM   #19698
AdrianM's Avatar
2.0mm
Adrian Martinez
Old 05-28-2007, 08:41 PM   #19699
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Jon Kerr
Don't run it. If you need one, put a Kimbrough on. That's what Weylin had on his car this week and it fit just fine.
That's what I have on mine too, the mid-size with no holes and put a hole about 3mm from the top/center......
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-28-2007, 09:18 PM   #19700
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default chassis question
any pics of the 2.5 decks and will servo placement change..
what type of weight increase will it give the car.
olhipster1 is offline   Reply With Quote
Old 05-28-2007, 10:27 PM   #19701
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Just found a couple cool pics of my car from the RROC taken by Jason Boulanger..
Schumacher Corner-157256167_jasonb_070526_41025_dv.jpg   Schumacher Corner-157254916_jasonb_070526_40956_dv%5B1%5D.jpg
Old 05-28-2007, 10:54 PM   #19702
STLNLST's Avatar
Trader Rating: 21 (100%+)
Mine looked better..... Good run at the RROC bro.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-29-2007, 12:44 AM   #19703
Originally Posted by yyhayyim
the manual seems to indicate that the ballstud that joins the front caster blocks and the steering hub, as well as the bottom screw, should not be turned all the way in, but left a minimum of 1mm out...doest this give you exesive play? 2mm of play doesnt seem kosher...maybe .5mm or 1mm, but 2mm? Can someone explain this to me...thx
Well, build it this way and tell us if you do get 2mm play by doing that? Some creative thinking and looking at the parts would perhaps reveal that the hub won't have near as much play in the caster block, so it won't actually matter much if you leave them 0.5 or 2.5mm out.
Having said that, I leave minimum play there, so it still turns freely end-to-end and doesn't bind, but I don't see a reason to leave much more... unless you want to "fine-tune" your camber link outer location this way
One of the things I had problem with was the wheelbase clips/spacers. I had no way of getting 4mm of spacers in there without severe binding, so I ended up using 3,75mm, good thing that the thin quick clips were included.
olev is offline   Reply With Quote
Old 05-29-2007, 04:29 AM   #19704
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
For the quick clips I just used a piece of emery cloth and just lightly sanded one of the clips on each side and they fit perfect. Took about 30 seconds to do each side. I also did this when I shortened my rear wheel base 1mm. I used a 2mm and 1mm clip in the rear of the arms and then the 1mm clip for the front I again gently sanded with emery cloth and had a perfect fit. I just took a small peice of emery cloth and keep in my tool box now.
ST Racing Concepts (STRC)
Old 05-29-2007, 05:19 AM   #19705
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by mini-dub
But not to say it was only other peoples fault, I did blow out for no reason several times.
But it's ok, I beat the track record lap time for 19t of 13.4 with a 13.3 .
so you did come away with something from racing at our halloween classic last year. our philosophy! look, if you can't put a qualifier together, at least hot lap 'em! nah, it's out of the way now, so that vegas will be a repeat. good to hear the car was that fast.
props to randy c for a sweet showing, and to all the schumacher drivers that represented, yo. it was fun to check in on the progress every few rounds.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-29-2007, 05:30 AM   #19706
chris72983's Avatar
http://www.rctech.net/forum/showthre...67#post3346667
REPOST FOR GREAT DEAL AND PRICE DROP
chris72983 is offline   Reply With Quote
Old 05-29-2007, 06:51 AM   #19707
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default Wing Placement
How far back should I put my wing for low-med traction out door asphalt? At the 2006 worlds, it seems lots of drivers had them as far back as possible...at the Reedy 2007 race, Reinard and others also ran it far back...I'd love find out how Weylin, Randy, PW and Alex ran theirs and who that effects their set up...thx
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-29-2007, 06:56 AM   #19708
mini-dub's Avatar
Trader Rating: 16 (100%+)
Running the wing farther back gives you more rear bite. In medium to low bite I run the wing back for more rear traction. If I need more steering I can move it forward. It will help the car rotate with it forward. At the Reedy we all ran the wing at the back though.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 05-29-2007, 07:24 AM   #19709
yyhayyim's Avatar
Talking
Thanks for the insight...when you say "we all" you mean MI3 team drivers or everyone at the Reedy race?
Also, would anyone know what the front and rear track width is for PW asphalt set-up? Maybe the set up sheet can be eddited to include this as well as wheel base...
Old 05-29-2007, 07:31 AM   #19710
mini-dub's Avatar
Yeah, "we all" was referring to our team. I have no idea what everyone at the race was doing .
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
