Old 05-28-2007, 04:21 PM   #19666
JayBee's Avatar
Trader Rating: 31 (100%+)
Sweet job Weylin for only having the car a few weeks before Reedy!! There's gonna be a bunch of MI3's around here
Now get me that set-up!!
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-28-2007, 04:22 PM   #19667
JayBee's Avatar
Originally Posted by dawgmeat
Weylin Rose
When it come time for Roar nats and IIC kick'em where they sh!t at
Around here some folks may invite it!!
Old 05-28-2007, 04:27 PM   #19668
dawgmeat's Avatar
My first big race was snowbird 07, racers will peel the FU@K out of you, I remeber when I was about make a clean pass during qualifing some dude flat out cut me off and his teammates cheered for him when he park me on a pass attempt So from hear out I have love for a certain motor team
dawgmeat is offline   Reply With Quote
Old 05-28-2007, 04:45 PM   #19669
Originally Posted by AdrianM
Most of us are running one notch looser than that.
Adrian - when you say you are running one notch looser does that mean for the back belt as well as the front belt?
Also - what effect does it have on the car running the diff high in the rear and running the spool low in the front per PW's setup?
thanks
Schumacher | Novak | P-dub Racing | Orion | Airtronics | Team Stream
sf85 is offline   Reply With Quote
Old 05-28-2007, 04:45 PM   #19670
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
thanks
low in the front will give you a little more steering
Old 05-28-2007, 04:45 PM   #19671
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
You will have to ask Weylin and PW. I won't know untill tomorrow.
Randy and MO are no slouches either...they had very nice runs and they can fill us in as well...right fellas?
Alex, PW, and Weylin all could have easily been and won the mains, and could have also finished top 5 easily in each of their classes...it seems that the other racers were a bit too agressive and had no manners in some instances, and this hurt Alex and PW...thanks for your hard work and sacrifice and the great support and friendship with all of us fellow MI3 drivers...cant wait to hear your takes on the experience and reports and suggestions. This is a major step forward on the MI3 and lots of new knowledge was gained for sure, and this will only help Schumacher R&D keep working to refine the car and help us get even better set-up ideas
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-28-2007, 04:49 PM   #19672
yyhayyim's Avatar
Weylin Rose
You mean hit them in mouth? !
Old 05-28-2007, 04:50 PM   #19673
AdrianM's Avatar
Only if they are talking s#!t right?
Adrian Martinez
Old 05-28-2007, 04:53 PM   #19674
yyhayyim's Avatar
Talking
the Losi drivers like to run their Type R's with the high front, and low rear. They state in their manual that this set-up has found to be the best working overall in the experience...maybe it could work nicely ont he Mi3, also...more testing...
Old 05-28-2007, 04:57 PM   #19675
yyhayyim's Avatar
Then they must have nasty diahrreah!
Old 05-28-2007, 04:58 PM   #19676
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
So...what is the trick to getting this dang nabbed servo saver spring on?!
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 05-28-2007, 04:59 PM   #19677
yyhayyim's Avatar
the manual seems to indicate that the ballstud that joins the front caster blocks and the steering hub, as well as the bottom screw, should not be turned all the way in, but left a minimum of 1mm out...doest this give you exesive play? 2mm of play doesnt seem kosher...maybe .5mm or 1mm, but 2mm? Can someone explain this to me...thx
Old 05-28-2007, 05:11 PM   #19678
Super Moderator
Marcos.J's Avatar
i followed the instructions and mine is just fine
Old 05-28-2007, 05:38 PM   #19679
rtypec's Avatar
EVERYONE there knew Weylin had the fastest car in the 19T class
Not really j/k
Good run Weylin. You definately had a good car.
rtypec is offline   Reply With Quote
Old 05-28-2007, 05:41 PM   #19680
Trader Rating: 237 (99%+)
Originally Posted by mini-dub
What tuning secret are you looking for exactly? I didn't change much from my setup at home actually, maybe 2 things. The car was working well, it just came down to driving (which for some reason I seemed to only be able to do for 4 minutes and 30 seconds). To show you how much it came down to driving, in the 4th round that I finally tq'ed because I didn't blow out there were 9 guys with a 5:11 time. That's less than zero room for error, not only could you not make an error once, simply blowing your line could cost you 4 positions.
PW is not releasing details to racers outside that team at the track for the moment. What we are figuring our out applies to other cars too so we want to keep it on the down low until monday.
This secret
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
