Old 05-27-2007, 10:55 AM   #19576
dawgmeat's Avatar
Originally Posted by AdrianM
The pin in the blade end of the dogbone is the problem. If you break one send it back and we will get you a new one at no charge.
do you want the whole assembly or just the bone
dawgmeat is offline   Reply With Quote
Old 05-27-2007, 12:00 PM   #19577
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
well completed my 1st full race day today, and the car with PW's set up is dialed, no problems at all with the cvd's. Car was very easy to drive!!
Old 05-27-2007, 12:06 PM   #19578
Charles Godwin's Avatar
Better than the Type-R ?
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 05-27-2007, 12:15 PM   #19579
Super Moderator
Marcos.J's Avatar
Charles
about the same , i think the R has a little more corner speed, ran both today MI3 has only 1 race the R has 3,ill see next weekend
Old 05-27-2007, 12:23 PM   #19580
chris72983's Avatar
Here is a link to my EC that I have for sale, If anyone knows anyone interested.
chris72983 is offline   Reply With Quote
Old 05-27-2007, 12:34 PM   #19581
Super Moderator
Marcos.J's Avatar
you forgot the link
Old 05-27-2007, 01:36 PM   #19582
Super Moderator
Marcos.J's Avatar
wire layout
too messy at least you are drinking good beer
Old 05-27-2007, 01:37 PM   #19583
dawgmeat's Avatar
wire layout
Old 05-27-2007, 02:07 PM   #19584
rcshark's Avatar
Send a message via Yahoo to rcshark
that car want run it dont have a hub or tire
rcshark is offline   Reply With Quote
Old 05-27-2007, 02:19 PM   #19585
Super Moderator
Marcos.J's Avatar
thats the dawgmeat's set up "3 wheelin"
Old 05-27-2007, 02:31 PM   #19586
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking Race Report
Ran my MI3 for the first time today. I used PW set up for outdoor asphalt as a base set up, but had 2mm washer under the suspension blocks, instead of the 1.5mm. The droop was 5R and 4F, with droop gauge. Also ran 35W oil all around. Those were the only 3 diffrent things from the set up...I ran NOvak 3.5R motor...the car was a bit loose in the rear off power. Also needed more on power steering. Other than that, the car was fast, very quiet, and easy to drive hard. Very impressed over all...
Issues: a few times I slightly taped a corner in or out, and this seemed to really upset the steering of the car. After a slight tap, the car suddenly turned to one side more than the other( like if it had bad torque steer), and I had to stop it and adjust it w/ lots of trim input. This happened several times, and it was anoying. I was running the Futaba servo horn w/ no servo saver( yeah, I'm that good ), and will check if it stripped, or if there is something wrong with the servo...anyone know what could have caused this? Why does the car get the steering so upset that you have to input lots of trim to get it to track straight after light front taps?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-27-2007, 02:34 PM   #19587
Super Moderator
Marcos.J's Avatar
try a servo saver and dont hit anything!!
Old 05-27-2007, 02:45 PM   #19588
yyhayyim's Avatar
Talking
Servo saver doest allow the car to steer for some reason. When its off the ground it turns left and right perfectly...once you set it on the ground, it seems the servo is pulling a brick, as it just barely turns half way to either side...very weird. Tried the servo horn alone, and it turns perfectly, but if you tap something, the steering balance gets thrown off and you have reset the trim to get it tracking straight...dont know what's up with the servo saver...any ideas?
Old 05-27-2007, 02:46 PM   #19589
Super Moderator
Marcos.J's Avatar
dont use the stock servo saver
Old 05-27-2007, 02:52 PM   #19590
Try and keep with the servo arm. I've tried servo savers in the past and i've had trouble with them not staying centred after small taps. Check the chassis tweak, see if the chassis is flat or any other settings are out. There might be binding somewhere in the steering. Maybe in the driveshafts, i had to rebuild one of mine before i installed it because it was binding.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
